电子发烧友论坛|
PIC16F68 8的数据表没有说明内部电压基准是如何连接到比较器-倒相或非倒相输入的?http://WW1.Microchip .com……N/DeviceDoc /4120 3E.PDFAL,我只想使用一个比较器,但我不希望输出在外部引脚上——我只需要在代码中看到它,无论是通过中断还是轮询。“一个独立的比较器CM & lt;2:0& gt;=101”将输出放在外部引脚上。我不想为比较器的输出浪费一个引脚。有可能吗?综上所述,我想使用一个带有内部电压基准的比较器,并用软件处理比较器输出。
以上来自于百度翻译 以下为原文 The datasheet for the PIC16F688 does not say how the internal voltage reference is connected to the comparators - inverted or non-inverted inputs? http://ww1.microchip.com/...n/DeviceDoc/41203E.pdf Also, I would like to use only one comparator but I do not want the output on an external pin - I only need to see it in code, whether by an interrupt or by polling. "One Independent Comparator CM<2:0> = 101" puts the output on an external pin. And I do not want to waste a pin for the comparator output. Is it possible? So, to sum up, I want to use a single comparator, with internal voltage reference, and process the comparator output in software. Total I/O pins used: 1 Thanks. |
11个回答
似乎模式“四个输入多路复用到两个比较器CM & lt;2:0&gt=010正好是你想要的,顺便说一下,CM=101没有输出。只有一个输出是110。
以上来自于百度翻译 以下为原文 seems like mode "Four Inputs Multiplexed to Two Comparators CM<2:0> = 010 is exactly what you want and, by the way, cm=101 does not have an output. The only one with outputs is 110. |
好的,谢谢。我忽略了图中的“来自CVREF模块”的信号,这些比较器是开漏的吗?
以上来自于百度翻译 以下为原文 Ok, thank you. I overlooked the "From CVREF Module" signal at the diagram. Are these comparators open drain? Attached Image(s) |
它们是CMCON0寄存器中的位。只有CM=110将输出连接到引脚,如图7- 5所示。
以上来自于百度翻译 以下为原文 They are bits in the CMCON0 register. Only CM=110 connects the outputs to pins as shown in figure 7-5 |
对。我的意思是,如果我想使用一个外部引脚,与CM = 110,缓冲区是一个开放的排水或推挽?端口图只显示一个缓冲器,端口端口和比较器使用该缓冲器。
以上来自于百度翻译 以下为原文 Yes. I meant, if I wanted to use an external pin, with CM=110, is the buffer an open drain or push-pull? The port diagram only shows one buffer, that is used by the port pin and the comparator. |
从图中不清楚,RC0/AN4/C2IN +引脚现在是否可用于通用数字I/O?ADC呢?
以上来自于百度翻译 以下为原文 It is not clear from the diagrams. Is the RC0/AN4/C2IN+ pin now available for general purpose digital I/O? What about the ADC? Attached Image(s) |
我试着把第二张图片嵌入到帖子中,但是一直保持“访问被拒绝”。!!!
以上来自于百度翻译 以下为原文 I tried to embed the second image in the post, but kept getting "Access denied" garbage. WTH?!! |
应该是;ADC可能会有另一个寄存器开始使用。
以上来自于百度翻译 以下为原文 Should be; ADC may have another register coming into play |
ADC可能会有另一个寄存器进入,既可用于数字I/O作为RC0,又可作为AN4的模拟输入?谢谢。
以上来自于百度翻译 以下为原文 Should be; ADC may have another register coming into play Should be available for both digital I/O as RC0 and analog input as AN4? Thanks. |
在数据表部分4.2.5—注1中检查图4-1的例子。如果通过比较器模式或由安塞尔选择PIN为模拟,则关闭数字输入。如果TIIS对于该位来说是低的,即使模拟输入被启用,数字输出也被启用。因此,如果比较器模式不使用端口A引脚,并且安塞尔不使该PIN模拟(ADC),那么PIN可以用作数字输入。
以上来自于百度翻译 以下为原文 Check for example figure 4-1 in datasheet section 4.2.5 - note 1. If a pin is selected by the comparator mode or by ANSEL to be analog, then digital input is turned off. If TRIS is low for that bit, the digital output is enabled even if analog input is enabled. So if the comparator mode doesn't use a port A pin, and ANSEL doesn't make that pin analog (for ADC), then the pin can be used as digital input. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1098浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 09:29 , Processed in 1.075556 second(s), Total 91, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1393
