扫一扫,分享给好友
当我尝试安装软件PSoCuxDealSerial5.3.EXE时,总是发生错误。
错误信息如下:“此安装程序无法下载安装信息。请检查您的代理和Internet连接,然后再试一次。从URL链接下载文件103yStudioCabLogixV3.xml时,详细说明错误。文件:///c:/duMu~(1)/AdMix~ 1 /Loals~/Typ/IXP000 0.tMP/102yApdioCalCudioV3.xml“现在我可以正常连接到Internet。和我的同事可以安装在同一局域网软件。我试着关闭所有的安全保护软件和系统防火墙,但安装失败过。请帮助我集中问题,告诉我如何解决它。 以上来自于百度翻译 以下为原文 While I attempt to install the software psoc_designer_5.3.exe, error always happens. The error information is following: " This installer is unable to download installation information. Please check your proxy and internet connection and try again. Details Error 配置系统未能初始化 while downloading file 103_install_catalog_v3.xml from url link. file:///C:/DOCUME~1/ADMINI~1/LOCALS~/Temp/IXP000.TMP/102_install_catalog_v3.xml " Now I can connect to internet normally. And my colleague can install this software at the same LAN. I try to close all the safety protected software and system firewall, but install failed too. Please help me focus the problem and tell me how to solve it. |
3个回答
尝试安装安装包(740MB ISO文件)HTTP://www. CyPress?COM/?Re= 41083并从CyTuturun文件安装是一个解决问题的替代方案。
当做, 罗伊 以上来自于百度翻译 以下为原文 Trying to donwloading the installation package(the 740MB ISO file) http://www.cypress.com/?rID=41083 and install from cyautorun file is an alternative which might resolve the problem. Regards, Roy |
前一段时间,我遇到了类似的问题,所以我从HTTP://wwwyCysP.com/5.3下载了设计器?ID=2522和;源=头,卸载5.2,然后安装5.3。一切顺利。
开心下载 鲍勃 以上来自于百度翻译 以下为原文 Some time ago I had a similar problem, so I downloaded Designer 5.3 from http://www.cypress.com/?id=2522&source=header , de-installed 5.2 and then installed 5.3. All went well. Happy downloading Bob |
只是一个FYI,没有必要卸载以前版本的设计器,
我们中的一些版本已经回到4.4和早期共存。 在我们的系统上,它们工作得很好。如果你是创造者,也是如此。 曾经在PSoC 3/5上工作过。 问候,Dana。 以上来自于百度翻译 以下为原文 Just a FYI, there is no need to uninstall a prior version of Designer, a number of us have all versions back to 4.4 and earlier coexisting on our system and they work fine. Same is true for Creator if you ever work on PSOC 3/5. Regards, Dana. |
只有小组成员才能发言,加入小组>>
752个成员聚集在这个小组
加入小组2075 浏览 1 评论
1829 浏览 1 评论
3645 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1766 浏览 6 评论
1517 浏览 1 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
517浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
371浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
413浏览 2评论
360浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
868浏览 2评论
GMT+8, 2024-11-29 18:58 , Processed in 1.072258 second(s), Total 83, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
