大家好,我收到错误消息“警告:优化或结果操作期间出错:对象vbic_npn / early_aval / Fwd_early / ib_calc:函数VBIC_dcv_solver():电阻值必须> = 1.0e-009 ***错误:
函数'VBIC_dcv_solver'生成浮点错误**错误:执行转换期间vbic_npn / early_aval / Fwd_early / ib_cal * c *“如何解决此类错误..谢谢 以上来自于谷歌翻译 以下为原文 hello all , i am getting error message "WARNING: Error(s) during Optimization or resulting operations: Object vbic_npn/early_aval/Fwd_early/ib_calc: Function VBIC_dcv_solver(): Resistance values must be >= 1.0e-009*** ERROR: The function 'VBIC_dcv_solver' generated a floating point error** ERROR: During execution of Transform vbic_npn/early_aval/Fwd_early/ib_cal*c*" how to resolve this kind of errors .. thanks |
1个回答
嗨Sandeep,很乐意提供帮助,但是没有办法告诉你如何解决问题,只能从错误信息中解决。
不知何故,模型中的数据和设置会导致这些错误,例如: 浮点错误等建议:1。请联系eesof_support@agilent.com,详细说明问题,例如: 发送您的* .mdl文件和数据以及如何重现问题的说明..(只需执行ib_calc,ic_calc?)(您可以通过电子邮件抄送我:else_schmidt@agilent.com)2。A.一般:如果你 查看包含数据的模型的问题/错误,模板/示例模型不会发生这种情况,将您的数据输入与模板模型的数据输入进行比较。 B.使用VBIC提取时,建议按照宏的顺序进行提取。 最好的问候Else 以上来自于谷歌翻译 以下为原文 Hi Sandeep, Will be glad to help, but there is no way to tell you how to solve the issue, only from the error message. Somehow the data and settings you have in the model are resulting in these errors, e.g. floating point error etc. Suggestions: 1. contact eesof_support@agilent.com with details of the problem, e.g. send your *.mdl file and data with instructions on how to reproduce the issue.. (just execute the ib_calc, ic_calc?) (you can cc me on the email: else_schmidt@agilent.com) 2. A. General: If you see a problem/error with a model with your data in it, that does not occur with the template/example model, compare your data inputs to the function to that of the template model. B. With VBIC extraction, it is recommended to go through the extraction per the order of the Macros. Best regards Else |
只有小组成员才能发言,加入小组>>
1241 浏览 0 评论
2353 浏览 1 评论
2164 浏览 1 评论
2030 浏览 5 评论
2914 浏览 3 评论
985浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
715浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
815浏览 0评论
1242浏览 0评论
GMT+8, 2024-12-1 04:39 , Processed in 1.264279 second(s), Total 46, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
