您好,我对Agilent 6651A电源的故障操作有疑问(请参阅操作手册第123页)。
与故障相关的引脚在数字端口连接器上为1和2。 我被agilent apps eng告知,必须对故障状态进行编程,以使引脚按照手册中的说明运行,但在手册中描述“出厂时,数字端口配置为提供故障 指示灯(FLT)输出和远程(INH)输入。“ 此外,跳线在引脚7和8上处于故障/禁止设置。如果我试图使用引脚1和2进行故障操作,我必须编程故障条件或没有编程任何东西,我可以去 通过短接引脚3和4来保护模式以禁止和触发故障? 应用:我正在尝试使用外部12V(类似于手册的图D-3所示)运行外部继电器,并尝试使用引脚1和2作为开关。 参见附图。 这将是伟大的,如果任何有直接亲身经验的人都可以提供帮助。 谢谢,帕维特编辑:cooltools于2014年3月11日下午6:52编辑:cooltools于2014年3月13日下午12:48编辑者:cooltools于2014年3月13日下午12:53 以上来自于谷歌翻译 以下为原文 Hello, I have a question regarding the fault operation of Agilent 6651A power supply (refer to pg 123 of the operating manual). The pins related to fault are 1 and 2 on digital port connector. I was told by agilent apps eng that fault condition has to be programmed, in order for the pins to function as described in the manual but in the manual it is described "As shipped from the factory, the digital port is configured to provide a fault indicator (FLT) output and a remote (INH) input." Also, the jumpers are in fault/inhibit setting on pins 7 and 8. Is it true that if i am trying to use pins 1 and 2 for fault operation, that i have to program the fault conditions or without programming anything, i could go in a protect mode by shorting pins 3 and 4 for inhibit and trigger fault? Application: i am trying to run an external relay with an external 12V (similar to shown in fig. D-3 of the manual) and trying to use pins 1 and 2 as a switch. See the attached schematic. It would be great, If anyone with direct hands on experience can help. Thanks, Pavit Edited by: cooltools on Mar 11, 2014 6:52 PM Edited by: cooltools on Mar 13, 2014 12:48 PM Edited by: cooltools on Mar 13, 2014 12:53 PM 附件 |
3个回答
您好,我使用的是电源,但我对我们销售的新产品更熟悉,但我相信您需要取消屏蔽可疑状态组中导致故障并禁止端口跳闸的条目。
您需要使用STAT:QUES:ENAB命令来执行此操作。 让我知道这个是否奏效。 以上来自于谷歌翻译 以下为原文 Hello, I work with the power supplies but I am much more familiar with the newer ones that we sell but I believe that you need to unmask the entries in the questionable status group that cause the fault and inhibit ports to trip. You need to use the STAT:QUES:ENAB command to do this. Let me know if this works. |
嘿,谢谢你的回复。
我正在通过电话与另一个应用程序工作,他也提出了相同的建议。 所有这些都在编程手册中,但我希望他们能让它更直接一点。 你对编程命令完全正确。 基本上,为了在引脚1和2(故障引脚)上设置一个条件,并启用寄存器,它就像两行命令一样简单,如果我们将它们组合起来就是一个。 STAT:QUES:PTR 512 STAT:QUES:ENAB 512有* SRE 8来启用服务请求,但我不认为这对FLT是必要的。 让针脚1和2工作后我们遇到了另一个问题。 每次事件发生时,我们都必须通过STAT读取事件寄存器:QUES:EVEN? 命令以清除它。 我们可以从前面板清除事件(例如禁止)而不是发送命令并清除下一个事件的寄存器吗? Pavit 以上来自于谷歌翻译 以下为原文 Hey, thanks for the reply. I was working with another apps eng over the phone and he suggested the same as well. All this is in the programming manual but i wish they had made it little bit more direct. You are exactly right regarding the programming command. Basically, in order to put a condition on pins 1 and 2 (fault pins), and enable the registers, it was as easy as two lines command or one if we combine them. STAT:QUES:PTR 512 STAT:QUES:ENAB 512 There is *SRE 8 to enable service request but i don't think this is necessary for FLT. We ran into another problem after getting the pins 1 and 2 to work. Every time the event occurs, we have to read the event register by STAT:QUES:EVEN? command in order to clear it. Could we just clear the event (for example inhibit) form the front panel instead of sending a command and clear the register for next event? Pavit |
我认为你需要读取该寄存器才能清除它,因为它是锁存的。
如果要获取实时值,可以使用条件寄存器。 一旦条件消失,条件寄存器将清除。 以上来自于谷歌翻译 以下为原文 I think that you need to read that register in order to clear it since it is latching. If you want to get a live value,you can use the condition register. The condition register will clear once the condition is gone. |
只有小组成员才能发言,加入小组>>
1070 浏览 0 评论
2306 浏览 1 评论
2093 浏览 1 评论
1967 浏览 5 评论
2838 浏览 3 评论
837浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
616浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
713浏览 0评论
1397浏览 0评论
1071浏览 0评论
GMT+8, 2024-9-30 00:53 , Processed in 1.178785 second(s), Total 70, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
