大家好,最近购买了这种类型的示波器,但是通过测试模拟电源,它显示风扇的电源不工作,LED没有点亮,设定点显示没有电压存在。
还有18岁以上的人没有任何想法吗? 亚历克斯 以上来自于谷歌翻译 以下为原文 Hi all, recently acquired this type of scope, however from testing the analogue power supply it shows that the supply for the fans is not working, the led is not lit and the set points show there is no voltage present. Also the 18+ is not working Any Ideas ? Alex |
5个回答
电路图有用,如果这些可用,它们不包含在服务手册中,如果它可以是一个简单的修复,这似乎是浪费!
以上来自于谷歌翻译 以下为原文 The Circuit diagrams would help if these were available, they are not included in the service manual, it seems a waste if it could be a simple fix ! |
您好redders03您是否找到了模拟电源的电路图? 我有一台必须相同的HP54112D。 如果你感兴趣 ? 我的HP54112D上的电源也有类似的问题。 U1 PWM控制器与其他一些HS组件分道扬.. 我正在寻找这个IC(U1是XR 1826-1120)。 但它并不容易获得。 如果有人对此电路有任何信息,我会很高兴。 对不起我的英文,我是法国人问候Pulsingwave1编辑:Pulsingwave1于2013年8月3日9:22 AM 以上来自于谷歌翻译 以下为原文 Hi redders03 Did you find the circuit diagram of the analog power supply? I have one of the HP54112D which must be the same. If you are interested ? I have a similar problem with the power supply on my HP54112D. U1 PWM controller has exploded with some other HS components. I'm looking for this IC (U1 is XR 1826-1120). But it is not readily available. If anyone has any info on this circuit, I'll be happy. Sorry for my english, I'm french Regards Pulsingwave1 Edited by: Pulsingwave1 on Aug 3, 2013 9:22 AM |
嗨Pulsingwave1感谢您的回复,到目前为止我还没有找到图表,所以如果你能把我现有的那个发给我,我将不胜感激。 还有这个网站,我发现可能能够帮助的部分http://www.qservice.eu/shopdisplaycategories.asp?id=42希望这有帮助,谢谢Redders03 以上来自于谷歌翻译 以下为原文 Hi Pulsingwave1 Thanks for the response, so far I have not found the diagrams so if you could send me the one that you currently have that would be greatly appreciated. Also there is this site which I found which may be able to help with the part http://www.qservice.eu/shopdisplaycategories.asp?id=42 Hope this helps and thanks Redders03 |
nywerwer 发表于 2019-1-14 20:20 嗨redders03请在“收件箱”下的这个论坛中查看您的私信,我发了一条消息。 关心Pulsingwave1 以上来自于谷歌翻译 以下为原文 Hi redders03 Please, look at your private message in this forum under "inbox" I put a message. Regards Pulsingwave1 |
我也对hp 54112电源的原理图感兴趣。 这还能用吗? 谢谢。 以上来自于谷歌翻译 以下为原文 I too am interested in the schematic for the hp 54112 power suppply. Is it still available? Thanks. |
只有小组成员才能发言,加入小组>>
1240 浏览 0 评论
2352 浏览 1 评论
2163 浏览 1 评论
2030 浏览 5 评论
2914 浏览 3 评论
983浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
713浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
813浏览 0评论
1240浏览 0评论
GMT+8, 2024-11-29 15:56 , Processed in 1.560543 second(s), Total 87, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
