电子发烧友论坛|
我启动setup exe并显示“提取”窗口,然后显示权限提升请求。
当我按“是”时,设置只是静默停止,没有任何反应。 任何想法如何解决它? 以上来自于谷歌翻译 以下为原文 I start the setup exe and it shows the "extracting" window, and then it shows the privilege elevation request. When I press "yes", the setup just stops silently and nothing happens. Any ideas how to fix it? |
23个回答
你好@ petersmith1954,
感谢您让我们知道。 很高兴这也对你有帮助。 实际上,我们将尝试在“已知问题”AR中使其更加明显,并且还将在安装和许可论坛板上创建并添加新的安装调试流程。 亲切的问候,Anatoli Curran,Xilinx技术支持----------------------------------------- --------------------------------不要忘记回复,工作,并接受解决方案.---- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 Hello @petersmith1954, Thanks for letting us know. Glad this was helpful to you too. Indeed, we will try to make it much more visible in the ‘known issues’ AR and also will create and add a new install debug flow sticky on install and licensing forum board. Kind Regards, Anatoli Curran, Xilinx Technical Support ------------------------------------------------------------------------- Don’t forget to reply, kudo, and accept as solution. ------------------------------------------------------------------------- |
我尝试安装Vivado 2018.2时遇到了同样的问题。
我已禁用Symantec Endpoint保护和System Center Endpoint Protection。 服务器服务未运行,因此我启用了它(甚至重新启动)。 该服务现在显示为已启动,就像您的屏幕截图一样。 这仍然没有解决我的问题; 安装程序解压缩然后静默失败。 我已经失去了与我的IT部门打交道并且自己研究解决方案的工作时间。 请帮忙。 谢谢, 罗恩海恩博士 副教授 城堡 以上来自于谷歌翻译 以下为原文 I have been having exactly the same problem trying to install Vivado 2018.2. I have disabled Symantec Endpoint protection and System Center Endpoint Protection. The Server service was not running, so I enabled it (and even rebooted). The service now shows as Started just like your screen shot. This still HAS NOT solved my problem; the installer unpacks and then fails silently. I have already lost hours of productivity dealing with my IT department and researching a solution on my own. Please help. Thanks, Dr. Ron Hayne Associate Professor The Citadel |
我下载了17 GB单文件安装程序并以管理员身份运行它,现在有一个安装屏幕。
祝我好运。 Xilinx信息中心的安装仍然失败,作为一个可用的更新(我到目前为止一直运行2016.2)。 以上来自于谷歌翻译 以下为原文 I downloaded the 17 GB single file installer and ran it as Administrator and now have an install screen. Wish me luck. The install still fails from the Xilinx Information Center, as an available update (I've been running 2016.2 up until now). |
当以管理员身份手动运行时,使用完全下载或自解压安装程序成功安装。
我仍然需要与我的IT部门合作以默认启用服务器服务(我必须在退出系统后重新启动它)。 需要在安装说明中更好地记录此“要求”,以节省搜索解决方案的时间。 以上来自于谷歌翻译 以下为原文 Installation was successful using either the full download or the self-extracting installer when run manually as Administrator. I will still need to work with my IT department to enable the Server service by default (I had to restart it after logging out of my system). This "requirement" needs to be better documented in the installation instructions to save hours of searching for a solution. |
只有小组成员才能发言,加入小组>>
3137 浏览 7 评论
3433 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2895 浏览 9 评论
4094 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3079 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1353浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1191浏览 1评论
/9
GMT+8, 2025-12-9 18:04 , Processed in 0.846062 second(s), Total 47, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4892
