电子发烧友论坛|
大家好,我的系统上有ISE Webpack。
但是对于我的项目需求,我已经转移到14.4。我已经为ISE webpack生成并安装了Liscence。转换到14.4后我也有了liscence ..现在我为XC6sslx100运行我的项目..合成不是问题但是 我无法生成编程文件。这是我的Liscence ********************************* ************************************** *#-----删除上面的线路 - ------------------------ ##此许可证有效期自2015年6月16日星期四16:28:22。#...(由管理员删除 )... ## -----在这下面删除线路--------------------------我知道我的笔记本电脑仍在显示ISE webpack 在“xinfo”我怎么能解决这个问题?谢谢和问候,Gaurav xinfo.txt 65 KB 以上来自于谷歌翻译 以下为原文 Hello All, I have had ISE Webpack on my system. But for my project requirnment I have shifted to 14.4. I had generated and installed Liscence for ISE webpack. After shifting to 14.4 I have got liscence for it also.. Now when I run my project for XC6sslx100.. Synthesizing is not a problem but I am not able to generate programing file. Here is my Liscence *************************************************************************** # ----- REMOVE LINES ABOVE HERE -------------------------- # # This license is valid from Thu Jun 04 16:28:22 UTC 2015. # ... (removed by administrator)... # # ----- REMOVE LINES BELOW HERE -------------------------- I know my laptop is still showing ISE webpack in "xinfo" How can I solve this????????????? Thanks and regards, Gaurav xinfo.txt 65 KB |
9个回答
嗨@gsarode
从最新的xinfo,我了解到你获得了Zynq板的许可证。 使用此许可证,您无法通过定位Spartan-6 LX100设备在ISE中运行实施。 您可以在早期帖子中Syed突出显示的设备上运行实现,即xc6slx4-xc6slx75t 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @gsarode From the latest xinfo, I understand that you got this license with Zynq board. With this license, you cannot run Implementation in ISE by targeting Spartan-6 LX100 device. You can run implementation on the devices that are highlighted by Syed in earlier post i.e., xc6slx4-xc6slx75t Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
@gsarode,
Webpack License不支持您使用的设备XC6sslx100。 ISE 14.7发行说明中的第8页: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf 您可以在此设备上运行综合和实施,因为您的许可证具有以下特征: 使用此许可证,您应该只能为Webpack列下列出的设备生成编程文件。 问候, 赛义德 -------------------------------------------------- --------------------------------------------请注意 - 请注明 如果提供的信息有用,请回答“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢K-- -------------------------------------------------- --------------------- -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @gsarode, The device which you are using XC6sslx100 is not supported with Webpack License. Page number 8 in release note of ISE 14.7: http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf You were able to run synthesis and implementation on this device as your License has these features: With this License you should be able to generate programming files only for the devices listed under Webpack column. Regards, Syed ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
我现在在笔记本电脑上安装了ISE 14.4。
我也有它的韵味。 ISE 14.4成功地安装了liscence。 但当我实现我的项目生成编程文件时,它显示以下错误************************************ ************************************************** **********************************安全:12 - 没有'xc6slx100'功能版本2012.12可用(-5 ),错误:地图:258 - 尝试获取此体系结构的许可证时遇到问题。 ************************************************** ************************************************** *********************我现在已从网站上删除了我的ISE webpack Liscence ..并重新安装了ISE 14.4 Liscence。 Bur仍然遇到同样的问题。 以上来自于谷歌翻译 以下为原文 I now have ISE 14.4 on my laptop. I also have the liscence for it. Installation of the liscence was succesful for ISE 14.4. But when I implement my project to generate Programming file it showing following errors ************************************************************************************************************************ Security:12 - No 'xc6slx100' feature version 2012.12 was available (-5), ERROR:Map:258 - A problem was encountered attempting to get the license for this architecture. ************************************************************************************************************************* I have now deleted my ISE webpack Liscence from the website.. and reinstalled the ISE 14.4 Liscence. Bur still getting the same problems. |
@gsarode,
请生成最新的xinfo报告并在此处分享。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @gsarode, Please generate the latest xinfo report and share it here. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨@gsarode
从最新的xinfo,我了解到你获得了Zynq板的许可证。 使用此许可证,您无法通过定位Spartan-6 LX100设备在ISE中运行实施。 您可以在早期帖子中Syed突出显示的设备上运行实现,即xc6slx4-xc6slx75t 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @gsarode From the latest xinfo, I understand that you got this license with Zynq board. With this license, you cannot run Implementation in ISE by targeting Spartan-6 LX100 device. You can run implementation on the devices that are highlighted by Syed in earlier post i.e., xc6slx4-xc6slx75t Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
大家好,我如何从这里删除我的数据...我没有在选项中看到任何内容
以上来自于谷歌翻译 以下为原文 Hello all, How do I delete my data from here ... I dont see anything in the options |
@gsarode,
你是说要删除这个论坛帖子吗? 如果是的话,你为什么要这样做? 我没有看到您帖子中的任何机密信息。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @gsarode, Are you saying that you want to delete this forum thread? If yes, why would you want to do that? I dont see any confidential information from your post. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
Syed,我只想删除/编辑包含我的许可证文件的第一篇文章。感谢您(所有需要时间帮助的人)的时间和支持。
我很感激。 以上来自于谷歌翻译 以下为原文 Syed, I just want to delete/edit that first post that has my licence file. Thanks for your (all who take time to help out) time and support. I appreciate it. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 10:53 , Processed in 0.818466 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2684
