在Vivado WebPACK安装结束时,VC ++ 2012可再发行组件安装程序将启动,并显示从安装程序收到错误返回值的消息。
无论如何我继续安装它,它什么也没做,因为我已经安装了它(我安装了最新版本的Visual Studio)。 Vivado安装程序告诉我从Vivado目录运行VC ++ redist安装程序,我这样做。 再次,这成功地迅速完成。 但是,当我启动Vivado时,再次出现VC ++ 2012 redist安装的相同提示。 我告诉它继续,它再次完成。 但是,过了一段时间后,我收到关于某些Vivado批处理文件的超时消息......并且应用程序永远不会启动。 我怎样才能解决这个问题? 我有一个闪亮的新Artix 7明天到来,我很想开始开发它。 我已经将ISE用于我的Mojo,但需要Vivado用于新的主板。 有人可以帮忙吗? 戴夫 以上来自于谷歌翻译 以下为原文 At the end of the Vivado WebPACK install, the VC++ 2012 redistributable installer launches, along with a message that a bad return value was received from the installer. I proceed to install it anyway, and it does nothing, as I already have it installed (I have the latest version of Visual Studio installed). The Vivado installer tells me to run the VC++ redist installer from the Vivado directory, which I do. Again, this finishes quickly with success. However, when I launch Vivado, the same prompt comes up for the VC++ 2012 redist install again. I tell it to go ahead, and it once again completes. However, after some time, I get a timeout message regarding some Vivado batch file...and the app never launches. How can I fix this? I have a shiny new Artix 7 arriving tomorrow, and am anxious to start dev on it. I already use ISE for my Mojo, but need Vivado for the new board. Can somebody please help with this? Dave |
5个回答
看起来添加环境变量可以解决问题。
不幸的是,我无法卸载Visual Studio 2015,因为我积极使用它。 我使用的修复程序的详细信息可以在这里找到: https://forums.xilinx.com/t5/Installation-and-Licensing/Problem-when-installing-vivado-2014-4-on-win8-1pro/m-p/571907#M10721 戴夫 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 It looks like adding the environment variable resolves the issue. Unfortunately, I cannot uninstall Visual Studio 2015, as I actively use it. Details of the fix I used may be found here: https://forums.xilinx.com/t5/Installation-and-Licensing/Problem-when-installing-vivado-2014-4-on-win8-1pro/m-p/571907#M10721 Dave View solution in original post |
我刚刚在论坛上发现了一篇题为“在win8.1pro上安装vivado 2014.4时出现问题”的文章,该文章描述了一个非常类似的问题。
让我尝试通过遵循那里的建议来解决我的问题。 戴夫 以上来自于谷歌翻译 以下为原文 I just found an article on the forum entitled, "Problem when installing vivado 2014.4 on win8.1pro" that describes a very similar issue. Let me try to resolve my problem by following the advice there. Dave |
嗨@ dnovick,
我在系统中安装了更高版本的Visual C ++时看到了这个问题,因此不允许Vivado打开。 卸载Visual C ++的更高版本有帮助。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @dnovick, I have seen this issue when later version of Visual C++ are installed in system thus not allowing the Vivado to open. There uninstalling the later version of Visual C++ helped. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
OK ...按参考文章中的描述设置环境变量可解决问题。
以上来自于谷歌翻译 以下为原文 OK...Setting the environment variable as described in the referenced article fixed the problem. |
看起来添加环境变量可以解决问题。
不幸的是,我无法卸载Visual Studio 2015,因为我积极使用它。 我使用的修复程序的详细信息可以在这里找到: https://forums.xilinx.com/t5/Installation-and-Licensing/Problem-when-installing-vivado-2014-4-on-win8-1pro/m-p/571907#M10721 戴夫 以上来自于谷歌翻译 以下为原文 It looks like adding the environment variable resolves the issue. Unfortunately, I cannot uninstall Visual Studio 2015, as I actively use it. Details of the fix I used may be found here: https://forums.xilinx.com/t5/Installation-and-Licensing/Problem-when-installing-vivado-2014-4-on-win8-1pro/m-p/571907#M10721 Dave |
只有小组成员才能发言,加入小组>>
2414 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3371 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2458 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1077浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
579浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
438浏览 1评论
2000浏览 0评论
723浏览 0评论
GMT+8, 2024-12-20 02:37 , Processed in 1.303076 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
