全部 - 为了省去一点麻烦,这是我将现有的电源板(由ST停产)迁移到新的IHM023V2电源板时发现的:
1)STM32F10X-128K-EVAL的连接器引脚是相同的。 2)但是,下部IGBT驱动信号的极性反转。这需要软件改变timer1输出的极性。 3)电气设计存在缺陷:电源总线需要在每个桥臂处进行高频去耦。我在3个支路的每一个上使用了一个1uF,200v的陶瓷盖(上部的漏极到下部的源极;在电路板的背面,正好在引脚上。你可以在更高的电压下使用更低的值,但它需要高频去耦。不这样做会导致严重的EMI问题。 4)W16的跳线文档错误。通过观察PCB上的铜是显而易见的。该跳线控制霍尔传感器或编码器的电源。 除此之外它似乎工作。 alohA,DaveF 以上来自于谷歌翻译 以下为原文 All - to save you a bit of trouble, here is what I found when I migrated my existing power board (discontinued by ST) to the new IHM023V2 power board: 1) The connector pin-out to the STM32F10X-128K-EVAL is identical. 2) However, the polarity of the lower IGBT drive signals is inverted. This requires a software change to the polarity of the timer1 outputs. 3) There is a flaw in the electrical design: the power bus requires high frequency decoupling at each of the bridge legs. I used a 1uF, 200v ceramic cap across each of the 3 legs (drain of upper to source of lower; on the back of the board, right on the pins. You may be able to go with a lower value at higher voltage but it NEEDs high frequency decoupling. Not doing this will cause major EMI headaches. 4) The jumper documentation for W16 is wrong. It is obvious by looking at the copper on the PCB. This jumper controls the power to Hall sensors or encoder. Other than that it seems to work. alohA, DaveF |
1个回答
Ciao DaveF
非常感谢你分享这样的信息。 我想补充一点,在STMC Workbench v4.0示例项目中可以找到IHM023V2的设置,特别是在: SDK40x-STM32100B-EVAL-IHM023V2-Shinano.stmc projet基于STM32100B-EVAL,但您可以将功率级参数从该项目复制到您的。 最后,我可以请你用正确的MB459替换代码MB549的主题吗?因此,使用网络搜索工具将更容易找到。 再次感谢 再见 梁咏琪 以上来自于谷歌翻译 以下为原文 Ciao DaveF Thank you very much to share such kind of informations. I want to add that in the STMC Workbench v4.0 example project is possible to find the setting for the IHM023V2 and in particular in the: SDK40x-STM32100B-EVAL-IHM023V2-Shinano.stmc that projet is based on STM32100B-EVAL but you can just copy the power stage parameters from that project to your. Finally, may I ask you to change the subject replacing the code MB549 with the right one MB459? So it will be more easy found using web searching tools. Again thanks Ciao Gigi |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1465 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1518 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3664 浏览 1 评论
3856 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2475 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
746浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
679浏览 5评论
724浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
963浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
764浏览 5评论
/9
GMT+8, 2025-12-9 23:57 , Processed in 0.580572 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2056
