电子发烧友论坛|
N5242 PNA-X我要求***入功率为33 dBm。
功率限制在J10到+33,端口1的损耗约为6dB,所以我只能得到+27到DUT(减去电缆损耗)。 有没有办法提高功率? 以上来自于谷歌翻译 以下为原文 N5242 PNA-X I have a request for 33 dBm input power to the DUT. The power is limited at J10 to +33, and the loss to Port 1 would be about 6dB, so I could only get +27 to the DUT(minus cable loss). Is there a way of boosting the power any higher? |
2个回答
我买了这本书。
那里有很多好消息。 在设置“外部测试装置”期间,我需要打开端口1或端口2的源,并改变功率以确保DUT的输入高达33 dBm,并且ET最多为24 输出端的dBm。 我不得不退出NVNA应用程序,退出PNA应用程序,然后重新启动PNA应用程序。 这样我就可以使用“Power and Attenuators”框打开和关闭端口,并调整源功率。 甚至有一个点可以输入DUT的源功率和功率之间的差异。 是否有任何考虑将此框纳入NVNA应用程序? 我在N5242A上运行NVNA固件02.04.03。 以上来自于谷歌翻译 以下为原文 I purchased the book. Lots of good info there. During setup for the "external test set", I needed to turn the source on for either Port 1 or Port 2, and vary the power to insure that the input to the DUT was up to 33 dBm, and the ET was up to 24 dBm on the output side. I had to exit the NVNA app, exit the PNA app, and restart the PNA app. This was so that I could use the "Power and Attenuators" box to turn the ports on and off, and adjust the source power. There is even a spot so that one can enter the difference between the source power and power at the DUT. Has there been any consideration to incorporate this box into the NVNA app? I am running NVNA firmware 02.04.03 on my N5242A. |
nvywerww 发表于 2018-12-5 10:44 我会向NVNA规划师提及您的请求。 一般来说,NVNA的设置没有考虑源和接收器中的任何偏移,因此它更通用。 但事实上,我认为允许输入更多特定偏移量可能会更好,就像在PNA中一样,因此无需校准的功率设置可以更好地对齐。 我认为这样做可以减少使用外部设备时遇到的困难。 以上来自于谷歌翻译 以下为原文 I'll mention your request to our NVNA planner. In general, the NVNA was setup without considering the any offsets in sources and receivers, so that it was more generic. But in fact, I think it might be better to allow more specific offsets to be entered just like in the PNA, so that power settings without calibration are better aligned. I think doing so will reduce the difficulties sometimes found when using external devices. |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 15:45 , Processed in 0.518614 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2882
