当我尝试从Windows 7 32中的Webpack 12.3运行xsetup.exe时,没有任何反应。
如果我运行完全相同的文件,在同一台机器上的虚拟PC中,但运行XP,它安装正常。 因此tar文件没有任何损坏,问题似乎与操作系统有关。 任何想法? 以上来自于谷歌翻译 以下为原文 When I try to run xsetup.exe from Webpack 12.3 in Windows 7 32, nothing happens. If I run exactly the same file, in a virtual PC on the same machine, but running XP, it installs fine. So the tar file is not corrupt in any way, the problem appears to be with the OS. Anyone any ideas ? |
9个回答
要回答我自己的帖子,我认为问题是我的PC CPU不支持硬件虚拟化,xsetup.exe尝试在XP兼容模式下运行。
所以现在我不得不在虚拟PC上运行,除非我改变我的处理器或Xilinx推出Windows 7版本。 以上来自于谷歌翻译 以下为原文 To answer my own post, I believe that the problem is that my PC CPU does not support hardware virtualisation and xsetup.exe attempts to run in XP compatibility mode. So for now I am stuck with running in a virtual PC, unless I change my processor or Xilinx bring out a Windows 7 version. |
默认情况下,xsetup.exe以虚拟模式运行_not_。
你的Windows 7盒子上有一些设置正试图这样做,但这不是我们最终做的事情。 对于它的价值,我运行WebPACK,从Home Premium到Ultimate的32位和64位Windows 7没有任何问题,除了有线驱动程序的问题之外没有任何困难。 它不是受支持的流程,因为它没有经过回归测试,但我看到它有效。 你在用什么提取TAR文件? 我见过WinZIP的问题。 在提取TAR文件时,我们建议7-ZIP用于基于Windows的用户。 -------------------------------------------这个空间故意留空 以上来自于谷歌翻译 以下为原文 By default, xsetup.exe does _not_ run in virtualized mode. It's possible that there is some setting on your Windows 7 box that is trying to do so but it's not something that we do from our end. For what it's worth, I've run WebPACK with no issues on 32-bit and 64-bit Windows 7 from Home Premium through Ultimate with no difficulties other than issues with the cable driver. It's not a supported flow because it's not been regression tested but I have seen it work. What are you extracting the TAR file with? I've seen issues with WinZIP. 7-ZIP is what we recommend for Windows-based users when extracting the TAR files. ------------------------------------------- this space intentionally left blank |
ZIP或MSI文件是否更容易为Windows用户使用?
以上来自于谷歌翻译 以下为原文 Would a ZIP or MSI file be easier to work with for Windows users? |
1.使用Admin mode2安装。
不要使用WinZip解压缩 以上来自于谷歌翻译 以下为原文 1. Install with Admin mode 2. Do not use WinZip to unzip |
.ZIP不可用,因为.ZIP的最大大小为2GB。
我们的安装程序比这大。 .MSI不可用,因为它不可移植 - 它只是Windows,我们试图通过使它们可移植来简化。 -------------------------------------------这个空间故意留空 以上来自于谷歌翻译 以下为原文 .ZIP isn't usable because .ZIP has a maximum size of 2GB. Our installer is larger than this. .MSI isn't usable because it's not portable -- it's Windows only and we try to make things simple by making them portable. ------------------------------------------- this space intentionally left blank |
看起来如果您正在使用Xilinx可以提供某种窗口兼容安装的窗口。
我宁愿不用加载一些拉链工具来安装。 它不像窗口和linux的下载文件是相同的.... 以上来自于谷歌翻译 以下为原文 It does seem like if you are using window that Xilinx could supply some sort of windows compatible install. I'd rather not have to load some zip tool just to install. It's not like the download file for window and linux are the same anyway.... |
我遇到了同样的问题,并且在挫折中下载了很多次相同的版本,但是没有用。
所以后来我发现,64位窗口有一些设置问题。 因此,点击该安装文件,转到BIN / NT目录,你会发现很少 更多的exe文件,执行它们,然后它将完美地工作。 以上来自于谷歌翻译 以下为原文 I had same problem, and downloaded many times same version in frustation, but didn't work. So later on i found out, the 64-bit windows have some problem with setup. So intead clicking that setup file, go to BIN/NT directory and there you will find few more exe files, execute them, then it will work perfectly. |
我对ISE版本13.4有完全相同的问题。
我也相信这是一个虚拟化问题,因为它对我来说在虚拟机中也很有效,而且我知道我的处理器不支持虚拟化,过去曾遇到类似的问题需要它的其他软件。 建议的其他修复程序对我不起作用。 以上来自于谷歌翻译 以下为原文 I have exactly the same problem with version 13.4 of ISE. I too believe this is a virtualisation problem, as it too works for me in a virtual machine and I know that my processor does not support virtualisation, having had similar problems in the past with other software that requires it. The other fixes suggested do not work for me. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 13:32 , Processed in 1.218226 second(s), Total 88, Slave 71 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2363
