电子发烧友论坛|
早上好,
所以我最近搬了,带着我的定制PC。 突然间,即使是在Chrome中打开新标签等轻微过程,它仍然落后。 它连接的唯一新硬件是互联网。 到目前为止我有: - 通过离线尝试进程,无论是否有互联网连接,都可以解决互联网问题。 - 通过断开连接并仅使用处理器运行计算机,排除了视频卡的问题。 - 使用Malwarebytes扫描,没有问题。 - 删除和重新安装处理器。 - 取下并更换主板上的电池 - 检查哪些程序正在占用CPU空间,它不是一个程序,而是其中许多程序飙升。 当我输入这个我有一个youtube视频运行,我的CPU从50-100%波动。 记忆是23%是有帮助的。 热量在50度左右徘徊。 任何帮助将不胜感激。 以上来自于谷歌翻译 以下为原文 Good Morning, So I moved recently and took my custom built PC with me. Suddenly it's lagging even doing minor processes such as opening a new tab in Chrome. The only new hardware it is connect to is the internet. So far I have: -Ruled out an internet issue by trying processes offline, with and without an internet connection. -Ruled out an issue with the video card by disconnecting it and running the computer with just the processor. -Scanning using Malwarebytes, no issues. -Removing and reseating the processor. -Removing and replacing the battery on the motherboard -Checking what programs are hogging CPU space, it's not one program, rather many of them spiking. As I type this I have a youtube video running, my CPU is fluctuating from 50-100%. Memory is at 23% is that helps. Heat is hovering around 50 Degrees. Any help would be greatly appreciated. |
10个回答
你好rlaird:我们会尽力帮助你解决这个问题。
什么是主板的型号?内存RAM的型号是什么? 请提供棒数量和它们的速度。您使用的是哪个Windows版本?您当时只使用一个记忆棒测试了PC吗? 我们有一个名为英特尔®处理器诊断工具的工具,它对设备进行了全面测试,如果处理器通过了测试,那么它应该可以正常工作:https://downloadcenter.intel.com/download/19792/ 英特尔处理器诊断工具 您是否有机会在不同的电路板上测试处理器,或者使用不同的处理器测试电路板? 有任何问题,请告诉我。 此致,Alberto R. 以上来自于谷歌翻译 以下为原文 Hello rlaird: We will do our best to assist you with this scenario. What is the model of the motherboard? What is the model of the memory RAM? Please provide the quantity of sticks and the speed of them. Which Windows version are you using? Did you test the PC using just one memory stick at the time? We do have a tool that is called Intel® Processor Diagnostics tool, it does an overall test on the unit, if the processor passed the test then it should be working fine: https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool By any chance, do you have the option to test your processor on a different board, or test your board with a different processor? Any questions, please let me know. Regards, Alberto R |
jerry1978 发表于 2018-11-20 09:42 主板:MSI Z97 PC Mate Ram:2个XPG V2 DRAM每个8 GB 使用Windows 10 我运行了英特尔处理器诊断工具,每一个看起来都很好,我必须去,但我会用1记忆棒再次测试并回复你。 以上来自于谷歌翻译 以下为原文 Motherboard: MSI Z97 PC Mate Ram: 2 XPG V2 DRAM stick 8 GB each Using Windows 10 I ran them Intel Processor Diagnostics tool and everythign looks good, I have to go but I will test again with 1 memory stick and get back to you. |
你知道,移动PC会导致各种各样的问题。 每当我这样做时,我会重新进入并重置(或重置)所有连接,只是为了确保从发生的变换中一切正常。 希望这可以帮助, 内容S 以上来自于谷歌翻译 以下为原文 You know, moving PCs around can cause all sorts of issues. Whenever I do so, I go back in and reset (or reseat) all connections, just to be sure that everything is ok from the shakeup that occurred. Hope this helps, ...S |
jerry1978 发表于 2018-11-20 09:59 谢谢! 这对这个问题没有帮助,但我走动了很多,这听起来像是最好的做法。 以上来自于谷歌翻译 以下为原文 Thanks! It didn't help this issue but I move around a lot and this sound like best practice when it comes to this things. |
jerry1978 发表于 2018-11-20 09:42 嗨Alberto, 我现在已经用每根棒子单独测试了计算机,不幸的是,这并没有影响到这个问题。 以上来自于谷歌翻译 以下为原文 Hi Alberto, I have now tested the computer with each stick in individually and unfortunately, this did not affect the issue. |
我会尝试删除CPU风扇并重做导热膏。 我知道你说你重新安装了处理器,但我会再试一次。 文件 以上来自于谷歌翻译 以下为原文 I would try removing the cpu fan and redoing the thermal paste. I know you said you reseated the processor, but I would try again. Doc |
将在今晚晚些时候做。 即使在保持良好温度的同时,导热膏应用是否会影响性能? 我会尝试再次重新整理整个事情。 以上来自于谷歌翻译 以下为原文 Will do later tonight. Can the thermal paste application affect performance even while maintaining good temperatures? I'll try reseating the whole thing again all the same. |
jerry1978 发表于 2018-11-20 09:42 我还应该说,遗憾的是我没有第二块主板。 以上来自于谷歌翻译 以下为原文 I should also say, I unfortunately do not have a second motherboard. |
所有这些和一个简单的Windows Update解决了它。
已经推迟了大约6个月,因为我的启动驱动器太满,最后被删除,更新,我的使用恢复正常。 但这是否意味着Windows会限制我的电脑速度? 可能是一个众所周知的问题,但我已经推迟了多年的更新,这个问题只出现在几天前。 以上来自于谷歌翻译 以下为原文 All that and a simple Windows Update solved it. Have been putting it off for about 6 month because my boot drive was too full, finally deleted enough, updated, and my usage is back to normal. But does this mean Windows was throttling my computer speed? Might have been a known issue but I have been putting off that update for ages and the issue only appeared a few days ago. |
60user88 发表于 2018-11-20 11:12 很高兴你修好了。 关于Windows 10更新,谁知道MS做什么来惹恼用户。 如果你的驱动器非常满,可能是在颠簸并试图找到足够的连续空间来完成工作。 文件 以上来自于谷歌翻译 以下为原文 Glad you have it fixed. Regarding windows 10 updates, who knows what MS does to mess with users. If your drive was very full, it could have been thrashing and trying to find enough contiguous space to do work. Doc |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 17:21 , Processed in 0.994311 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
769
