扫一扫,分享给好友
嗨,大家好。
我在这结束了。我在大学的项目中使用这些设备没有任何问题。现在我正试着用我的个人笔记本来处理我目前的项目,我一无所获! 我花了3天的时间在电脑上重新安装所有CyPress软件,拖网论坛,看教程视频(它总是微风吹过我的问题所在),并阅读文档。 我试过2个PSOC,以确保它没有被破坏,是的,我正在按下血腥按钮。该设备在设备管理器中显示为“USB串行(单通道)供应商MFG”。 还有“USB串行适配器”,但从来没有作为COM端口。该设备在串行配置实用程序中是可见的,并且显然是可编程的,但对于任何其他的CyPress软件,包括引导加载程序主机,都是不可见的。 我认为PSoC4可以很好地解决我在一个非常特别的项目中遇到的一个特定问题,我很高兴再次与PSoC合作,但是在所有这些压力之后,我考虑使用其他的东西。我不确定我是否愿意承担产生数千个单位包含8个PSoC,如果我有这么多的麻烦只是上传一个基本的代码位! 以上来自于百度翻译 以下为原文 Hi people. I am at my Wits end here. I have used these devices in projects at university without any issue. Right now I'm trying to get one to work with my personal laptop for my current project and I am getting nowhere! I've spent the last 3 days reinstalling all Cypress software on the computer, trawling the forums, watching the tutorial videos (Which always just breeze past where my problems are), and reading the documentation. I've tried 2 Psocs, to ensure it isn't broken and yes I am pressing the bloody button. The device shows up in device manager as 'USB-Serial (Single Channel) Vendor MFG' and also 'u*** serial adapter' but never as a com port. The device is visible in the serial configuration utility, and apparently programmable, yet never visible to any other cypress software, including the bootloader host. I thought that the PSOC4 could elegantly solve a specific problem I'm having with a very particular project and I was really excited about working with PSOC again but after all of this stress I'm considering using something else. I'm not sure I'm willing to take the risk of producing thousands of units containing 8 Psocs each if I'm having this much trouble just uploading a basic bit of code! |
4个回答
当你把它插入USB端口时,你一直在按住按钮吗?蓝色LED闪烁得很快吗?当你打开Bootloader主机时,你会看到Bootloader主机窗口中的设备吗?正如你有两个设备,这似乎奇怪的是,这两个设备有问题,但他们可以。请参见使用CY8CKIT-049编写另一个PSoC®4—KBA935441赛普拉斯半导体
以上来自于百度翻译 以下为原文 Are you holding the button all the time while you are plugging it into the USB Port? Is the Blue LED blinking quickly? When you open the bootloader host do you see the device in the window of the bootloader host? As you have two devices it seems strange that both of the devices have and issue but they could. see this Using the CY8CKIT-049 to Program Another PSoC® 4 - KBA93541 | Cypress Semiconductor |
单击Bootloader主机工具中的筛选器按钮,并启用“显示USB设备”选项。看看Bootloader主机工具现在列出了工具包。
以上来自于百度翻译 以下为原文 Click on the Filters button in the Bootloader Host tool and enable the Show USB Device option. See if the Bootloader Host tool lists the kit now. |
你好,杰米,
USB串行设备充当CY8CKIT-0494XXX开发工具包的UB-UART桥。您尝试更改默认设置吗? 您想使用任何其他配置控件,如GPIO、SPI和I2C,使用PC上的CyPress供应商驱动程序吗?如果是,请使用HTTP://CyPress .COM/FIL/141306/下载的“USB串行设备的附加功能”部分。 最好的问候, 吉娜玛丽 以上来自于百度翻译 以下为原文 Hello Jamie, The USB-Serial device acts as a USB-UART bridge for the CY8CKIT-049-4xxx development kit. Have you tried to change the default settings? Do you want to use any other configuration controls such as GPIO, SPI, and I2C that use the Cypress vendor driver on the PC? If yes, please make use of section: 'Additional Features of the USB-Serial Device' of http://www.cypress.com/file/141306/download Best Regards, Geona Mary |
zhushanyu262 发表于 2018-11-14 12:06 因此,这是由于一个枚举问题。 在设备管理器中,我必须显示隐藏的设备和手动卸载和删除(这是至关重要的,除非您想重新启动您的机器每5个引导负载左右)驱动程序对应于所有的“鬼”COM端口设备,以及“USB串行供应商MFG”设备出现在UnVERSAL串行总线控制器。 此时PSoC将再次识别该设备。有时你可能不得不重复这样做,但出于某种原因,我已经几天没有这样做了(没有抱怨)。 还要注意的是,如果你像我一样,在玩弄其他USB可编程设备,比如ARDUINO Bootloader主机,它喜欢用你的波特率来玩弄某个时间,并且把它设置为9600! 以上来自于百度翻译 以下为原文 So it turns out this was due to an enumeration problem. In device manager I had to show hidden devices and manually uninstall AND DELETE (This is crucial unless you want to reboot your machine every 5 bootloads or so) the drivers corresponding to all of the 'ghost' COM port devices, as well as the 'u***-serial vendor MFG' devices which appear under universal serial bus controllers. At this point PSOC will once again recognise the device. Sometimes you may have to do this repeatedly, but for some reason I haven't had to do this for a few days (not complaining). Also take note that if you, like myself, are toying with other USB programmable devices such as arduino Bootloader host likes to toy with your baud rate for no apparent reason sometime and set it to 9600! |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7255 浏览 0 评论
2482 浏览 1 评论
2176 浏览 1 评论
4037 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2082 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7761浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6319浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
753浏览 2评论
726浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8154浏览 2评论
/9
GMT+8, 2025-12-10 01:27 , Processed in 0.824799 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1842
