电子发烧友论坛|
嗨,
Idownloadedwebpack 11.1然后在我的计算机上远程安装(vista 32),然后下载11.2更新完整的ISE设计并离线安装,导航器中的版本说它是11.2但是我不能使用virtex 6 LX75T 作为一种设备因为它不在家庭列表中,也不是斯巴达6。 请帮忙 问候, 以上来自于谷歌翻译 以下为原文 Hi, I downloaded webpack 11.1 and then installed offline it on my computer (vista 32) and then downloaded the 11.2 update the full ISE design and installed it off-line, the version in the navigator say it is 11.2 but yet i can't use virtex 6 LX75T as a device coz it is not in the family list neither spartan 6. Please help Regards, |
3个回答
devox,
除ISE更新外,您是否安装了Spartan-6和Virtex-6器件系列更新? 这些是分开的。 如果没有,您可以运行XilinxUpdate,这些更新应该可用。 以上来自于谷歌翻译 以下为原文 devox, Did you install the Spartan-6 and Virtex-6 Device Family update in addition to the ISE update? These are separate. If not, you can run XilinxUpdate and these updates should be availabe. |
kpatel,
感谢您的回复, 我不知道有一个单独的更新,但是,我运行XilinxUpdate并收到消息说没有新的更新显示! 如果有此更新的链接,请发送它,因为我找不到它。 谢谢 :) 以上来自于谷歌翻译 以下为原文 kpatel, Thanks for your reply, I didn't know that there is a separate update, however, i run XilinxUpdate and get a message saying no new update to display !!! If there is a link for this update please send it coz i can't find it. Thanks :) |
我也遇到了同样的问题。
我刚刚安装了ISE 11.1和11.2。 安装ISE11.2后,我立即尝试启动Spartan 6 EDK项目。 但是,在BSB向导中选择Spartan 6之后,EDK生成了一些“找不到Microblaze核心”,“找不到Microblaze PLB46核心”等错误。 所以我重新启动并尝试再次刷新许可证文件。 之后我甚至不能再选择Spartan 6了。 我注意到选择中也缺少Virtex 6。 我正在使用EVAL许可证。 问候, 新 以上来自于谷歌翻译 以下为原文 I faced the same problem too. I had just installed ISE 11.1 and 11.2 today. Upon installing ISE11.2, I had immediately tried to start a Spartan 6 EDK project. However, EDK generates some "cannot find Microblaze core", "cannot find Microblaze PLB46 core", etc error after I select Spartan 6 in BSB wizard. So I rebooted and tried to refresh the license file again. After which I cannot even select Spartan 6 anymore. I noticed Virtex 6 is missing from the selection too. I am using EVAL license. Regards, Neo |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 09:26 , Processed in 0.697582 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1426
