电子发烧友论坛|
typedef struct _ADC_Obj_
[ volatile uint16_t ADCRESULT[16]; //!< ADC result registers volatile uint16_t resvd_1[26096]; //!< Reserved volatile uint16_t ADCCTL1; //!< ADC Control Register 1 volatile uint16_t rsvd_2[3]; //!< Reserved volatile uint16_t ADCINTFLG; //!< ADC Interrupt Flag Register volatile uint16_t ADCINTFLGCLR; //!< ADC Interrupt Flag Clear Register volatile uint16_t ADCINTOVF; //!< ADC Interrupt Overflow Register volatile uint16_t ADCINTOVFCLR; //!< ADC Interrupt Overflow Clear Register volatile uint16_t INTSELxNy[5]; //!< ADC Interrupt Select x and y Register volatile uint16_t rsvd_3[3]; //!< Reserved volatile uint16_t SOCPRICTRL; //!< ADC Start Of Conversion Priority Control Register volatile uint16_t rsvd_4; //!< Reserved volatile uint16_t ADCSAMPLEMODE; //!< ADC Sample Mode Register volatile uint16_t rsvd_5; //!< Reserved volatile uint16_t ADCINTSOCSEL1; //!< ADC Interrupt Trigger SOC Select 1 Register volatile uint16_t ADCINTSOCSEL2; //!< ADC Interrupt Trigger SOC Select 2 Register volatile uint16_t rsvd_6[2]; //!< Reserved volatile uint16_t ADCSOCFLG1; //!< ADC SOC Flag 1 Register volatile uint16_t rsvd_7; //!< Reserved volatile uint16_t ADCSOCFRC1; //!< ADC SOC Force 1 Register volatile uint16_t rsvd_8; //!< Reserved volatile uint16_t ADCSOCOVF1; //!< ADC SOC Overflow 1 Register volatile uint16_t rsvd_9; //!< Reserved volatile uint16_t ADCSOCOVFCLR1; //!< ADC SOC Overflow Clear 1 Register volatile uint16_t rsvd_10; //!< Reserved volatile uint16_t ADCSOCxCTL[16]; //!< ADC SOCx Control Registers volatile uint16_t rsvd_11[16]; //!< Reserved volatile uint16_t ADCREFTRIM; //!< ADC Reference/Gain Trim Register volatile uint16_t ADCOFFTRIM; //!< ADC Offset Trim Register volatile uint16_t resvd_12[13]; //!< Reserved volatile uint16_t ADCREV; //!< ADC Revision Register ] ADC_Obj; //! brief Defines the analog-to-digital converter (ADC) handle //! typedef struct ADC_Obj *ADC_Handle; inline void ADC_clearIntFlag(ADC_Handle adcHandle, const ADC_IntNumber_e intNumber) [ ADC_Obj *adc = (ADC_Obj *)adcHandle; // clear the bit adc->ADCINTFLGCLR = 1 << intNumber; return; ] // end of ADC_clearIntFlag() function |
相关推荐 |
只有小组成员才能发言,加入小组>>
584 浏览 0 评论
1641 浏览 0 评论
2080 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1533 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1372 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1782浏览 29评论
2810浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1742浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1654浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1672浏览 13评论
/9
GMT+8, 2025-12-10 04:22 , Processed in 0.717537 second(s), Total 65, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1326
