电子发烧友论坛|
嗨,我们有关键视线N9020A-503单元,我们正面临一些测量问题。
我们尝试在1GHz左右馈送各种频率,功率电平为0到-40 dBm。 它显示了施加信号时噪声功率上升但未显示信号。 请帮忙解决此问题。 谢谢,TPO 以上来自于谷歌翻译 以下为原文 Hi, We are having key sight N9020A-503 unit and we are facing some measurement issue with this unit. We tried feeding various frequencies around 1GHz and the power level of 0 to -40 dBm. It shows the noise power going up when the signal is applied, but no signal shown. Kindly need your help to resolve this issue. Thanks, TPO |
1个回答
您能否提供输入0 dBm信号时的屏幕图像?
另外,您输入的是什么类型的信号? 是CW吗? 当您将仪器调到50 MHz并打开内部50 MHz校准器信号(输入/输出,RF校准器,50 MHz)时,它看起来是否正常? 麦克风 以上来自于谷歌翻译 以下为原文 Can you provide a screen image of what it looks like when you input a signal at 0 dBm? Also, what type of a signal are you inputing? Is it a CW? When you tune the instrument to 50 MHz and turn on the internal 50 MHz calibrator signal (Input / Output, RF Calibrator, 50 MHz) does it look normal? Mike |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 14:17 , Processed in 0.729895 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
8621
