电子发烧友论坛|
早上好,
我在使用12和8高斯范围的磁力计时遇到了一些麻烦。 我正在使用SPI通信。来自accellerometer和陀螺仪的所有数据都是正确的,磁力计的刻度设置为2和4高斯,但没有12和8。 特别是通过使用外部磁铁,我无法通过此刻度设置获得任何设备饱和度。我使用的不是STM32来驱动传感器,但我可以自由分享我的所有设置并注册配置以了解问题是什么 问候, Marco Beccani 以上来自于谷歌翻译 以下为原文 Good morning, I am having some trouble in working with the magnetometer with the 12 and 8 gauss range. I am using an SPI communication. All the data from accellerometer and gyroscope are correctly as well as for the magnetometer with the scale setted up to 2 and 4 gauss but not with 12 and 8. In particular by using an external magnet I can not get any saturation of the device with this scales settings . I am using not an STM32 to drive the sensor but I am free to share all my settings and register configurations to understand what is the problem regards, Marco Beccani |
3个回答
我做了更多的测试,使用永久磁铁,设备在12气程范围内没有正常工作,从不饱和。我认为永磁体会以某种方式混淆设备,即使其磁场强度低于12 Gass范围。
不幸的是,这只是猜测,因为我不知道模拟模块是如何工作的。我测试了其中3个并且它们具有相同的行为。我希望有人能解决这个问题。 以上来自于谷歌翻译 以下为原文 I did more testing, the device is not properly working in 12 gass range using a permanent magnet and never saturates. I think the permanent magnet messes up somehow the devices even tough its magnetic field is below the 12 Gass range. This is unfortunately only a guess as I don't know how the analog module works . I tested 3 of them and they have same behavior. I hope somebody will address this issue. |
你好马可,
我目前正在验证您的问题,我应该尽快给出答案。 如果我能做任何其他事情来支持你,请告诉我。 非常感谢你, 蒂亚戈雷斯 以上来自于谷歌翻译 以下为原文 Hello Marco, I am currently verifying your question, and I should provide an answer shortly. Please let me know if there is anything else that I can do to support you. Thank you very much, Thiago Reis |
你好马可,
我相信问题出在你正在使用的设备上,通常传感器应该在所有可用的FS中按预期工作。 如果您愿意,可以给我发一封电子邮件,其中包含下面列出的信息,我可以帮助您获取几个样品进行测试。 - 电子邮件 - 位置 - 公司 - 申请说明 谢谢, Thiago Reis - mailto:thiago.reis@st.com 以上来自于谷歌翻译 以下为原文 Hello Marco, I believe that the problem is on the devices that you are using, normally the sensor should work as expected in all FSs available. If you want, can you please send me an email with the information listed below and I can help you on getting a couple of samples for testing. - location - company - application description Thank you, Thiago Reis - mailto:thiago.reis@st.com |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1465 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1518 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3664 浏览 1 评论
3856 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2475 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
745浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
678浏览 5评论
723浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
962浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
763浏览 5评论
/9
GMT+8, 2025-12-9 16:58 , Processed in 0.892973 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1875
