电子发烧友论坛|
嗨我正在使用K7设备
我得到了以下错误 错误:位置:905 - 由于位置限制导致时钟区域规则被违反,因此无法放置和路由由区域时钟网络驱动的组件。 区域时钟网由BUFR驱动锁定到站点“BUFR_X0Y6”由于此位置约束,只能驱动时钟区域“CLOCKREGION_X0Y1”。 驱动的以下组件已锁定到这些时钟区域之外的站点:inst_channel2_processor / inst_adc_data_interface_top / inst_adc_data_deserialize r_top / inst_data_deserializer / inst_gen_iserdes_data [2] .inst_iserdese2(锁定站点:ILOGIC_X0Y88 CLOCKREGION_X0Y1)请评估BUFR和组件的位置限制 驱动以确保它们遵循架构的时钟区域规则。 有关时钟区域规则的更多信息,请参阅体系结构用户指南。 要使用部分路由设计调试您的设计,请允许mapper / placer完成执行(通过将环境变量XIL_PAR_DEBUG_IOCLKPLACER设置为1)。 BUFR和ILOGIC在同一地区仍然得到同样的错误。请你就此提出建议 谢谢 以上来自于谷歌翻译 以下为原文 Hi i am using K7 device i am getting following error ERROR:Place:905 - Components driven by Regional clock net placed and routed because location constraints are causing the clock region rules to be violated. Regional Clock net driven by BUFR contraint, can only drive clock regions "CLOCKREGION_X0Y1". The following components driven by have been locked to sites outside of these clock regions: inst_channel2_processor/inst_adc_data_interface_top/inst_adc_data_deserialize r_top/inst_data_deserializer/inst_gen_iserdes_data[2].inst_iserdese2 (Locked Site: ILOGIC_X0Y88 CLOCKREGION_X0Y1) Please evaluate the location constraints of both the BUFR and the components driven by ensure that they follow the clock region rules of the architecture. For more information on the clock region rules, please refer to the architecture user's guide. To debug your design with partially routed design, please allow mapper/placer to finish the execution (by setting environment variable XIL_PAR_DEBUG_IOCLKPLACER to 1). BUFR and ILOGIC are in same region still i am getting same error.can u please suggest me on this thanks |
6个回答
嗨,
您使用的是什么版本的ISE版本? 您可以使用变量“XIL_PAR_DEBUG_IOCLKPLACER to 1”并尝试检查设计中元素的位置吗? 问候, Achutha -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hi, What version of ISE version you are using? Can you use the variable "XIL_PAR_DEBUG_IOCLKPLACER to 1" and try to check the placement of the elements in the design? Regards, Achutha --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
我使用的是ISE版本14.7
我试图将该变量设置为1。 以上来自于谷歌翻译 以下为原文 i am using ISE version 14.7 i am trying to set that variable to 1. |
嗨,
检查BUFR是如何驱动的? 它是从IO端口驱动的吗? 如果是,该端口是否锁定时钟IO? 同时启用envoronmental变量并检查放置的设计。 了解负载是如何放置的,它们是否与CCIO的时钟区域位于同一时钟区域。 谢谢, 迪皮卡。 谢谢,迪皮卡.---------------------------------------------- ---------------------------------------------- Google之前的问题 张贴。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(左边的明星) 以上来自于谷歌翻译 以下为原文 Hi, Check how is the BUFR driven? Is it driven from IO port? If yes, is this port locked to clock capable IO? Also enable the envoronmental variable and check the placed design. See how the loads are placed, whether they are placed in same clock region as that of the CCIO or not. Thanks, Deepika. Thanks, Deepika. -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (the star on the left) |
嗨,
根据您的观察,错误消息似乎令人困惑。 您使用的是哪个版本的工具? 我建议使用最新的Vivado 2014.2或ISE 14.7。 您也可以尝试删除BUFR约束。 让我们发布运行和更新。 问候 Sikta 以上来自于谷歌翻译 以下为原文 Hi, Based on your observation, the error message seems confusing. Which version of tools are you using? I would recommend to use the latest one Vivado 2014.2 or ISE 14.7. You can also try by removing the BUFR constraint. Keep us posted with the runs and updates. Regards Sikta |
嗨,您是否尝试过该变量并检查信号的连通性?您能否共享连接片段?问题是否已解决?问候,Achutha
-------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- -------------- 以上来自于谷歌翻译 以下为原文 Hi, Did you try the variable and check the connectivity of the signal? Can you share the snippet of connectivity? Is the issue resolved? Regards, Achutha--------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------- |
嗨Achutha,
谢谢你的回复。 在我的设计中,使用了10个中的9个MMCM,而BUFGCTRL在我的设计中也更多 工具无法理解MMCM的放置位置,因为几乎所有内核都位于FPGA器件的顶层 我为所有MMCM和BUFGCTRL提供了Area约束 之后我能够实现设计 谢谢 以上来自于谷歌翻译 以下为原文 Hi Achutha, Thanks for ur reply. In my design am using 9 MMCMs out of 10.and BUFGCTRLs also more in my design Tool is not able to understand where to place the MMCMs,because almost cores are in top part of the FPGA device i gave Area constraint for all MMCMs and BUFGCTRLs after that i am able to implement the design Thanks |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 14:03 , Processed in 0.752382 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2804
