大家好,回到以前的公司,我得到了一个模拟文件,允许我将测量的S参数分成两个S参数文件。
假设是两个文件背靠背或S11A = S22B S22A = S11B(需要)S21A = S12A(需要)S21B = S12B(需要)并且如果需要S21A = S21B我认为它是迭代解决方案。 这样做的原因是去嵌入。 我有一个评估板,测量范围从100 kHz到9 GHz,我需要数据到设备。 我有一个删除设备的直通线。 是的,会出现一些错误,但由于低频和端口扩展不能用于高频,因此不能使用TRL校准。 由于我不再为前公司工作,我无法访问模拟。 有没有人记得或有这个解决方案。 我当时确实是从安捷伦那里得到的。 提前致谢。 Mike Virostko集成设备技术 以上来自于谷歌翻译 以下为原文 Hello All, Back at a previous company I had gotten a simulation file that allowed me to split a measured S-parameter into two S-parameter files. The assumption was the two files were back to back or S11A = S22B S22A = S11B (required) S21A = S12A (required) S21B = S12B (required) and if needed S21A=S21B I believe it was an iterative solution. The reason for doing this is is for de-embedding. I have an evaluation board which is being measured from 100 kHz to 9 GHz and I need the data to the device. I have a through line that has the the device removed. Yes there will be some error to this, but TRL calibration can not be used due to the low frequency and port extension can not be used to to the high frequency. Since I no longer work for the former company I have no access to the simulations. Does anyone remember or have this solution. I did get it from Agilent at the time. Thanks in advance. Mike Virostko Integrated Device Technology |
2个回答
知识中心上的以下文档包含一个描述和一个示例工作空间,用于“使用ADS优化将S参数数据拆分为两个相等的一半”。
http://edadocs.software.keysight.com/display/eesofkcads/Split+S-parameter+half+two 以上来自于谷歌翻译 以下为原文 The following document on the Knowledge Center contains a decription and an example workspace for "Splitting S-Parameter data into two equal halves using ADS optimization". http://edadocs.software.keysight.com/display/eesofkcads/Split+S-parameter+half+two |
411easdd*** 发表于 2018-10-4 11:52 谢谢 ! Mike Virostko 以上来自于谷歌翻译 以下为原文 Thanks ! Mike Virostko |
只有小组成员才能发言,加入小组>>
1224 浏览 0 评论
2348 浏览 1 评论
2158 浏览 1 评论
2024 浏览 5 评论
2904 浏览 3 评论
970浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
703浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
803浏览 0评论
1226浏览 0评论
GMT+8, 2024-11-23 18:42 , Processed in 1.325400 second(s), Total 79, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
