电子发烧友论坛|
你好
我安装了XS62ESP1009,其中包含2014-08-22发布的驱动程序包更新。 这对任何麻烦都是正确的。 但是,如果我使用此Windows驱动程序更新虚拟机并通过Receiver连接,它会工作一段时间,有时则不会。 如果它不起作用,我无法启动NVIDIA控制中心。 重新启动(1-2x)后,它可以工作,并在重新启动后不起作用。 我们使用PVS Streaming,因此所有图像都是相同的。 随着2014-04-的Nvidia驱动程序包 - ?? 我没有麻烦。 我安装了XD710ICAWSWX64004之后,我重新安装了所有Citrix的东西和这些麻烦。 我的大问题是,我删除了旧的驱动程序包。 你能否在2014-04之前寄给我司机包裹? 档案馆只有2013-12或2014-08套餐...... 谢谢 帕斯卡尔 以上来自于谷歌翻译 以下为原文 Hi I've install XS62ESP1009 with updates from driver package released at 2014-08-22. That works correct with any troubles. But if I update a virtual machine with this windows driver and connect via Receiver, it works some time and sometime not. If it doesn’t work, I can’t start the NVIDIA control central. After reboots (1-2x) it works and after new reboot doesn’t work. We use PVS Streaming, so all Images are identical. With Nvidia driver package from 2014-04-?? I’ve no troubles. I’ve reinstall all Citrix things and these troubles come after I’ve install the XD710ICAWSWX64004. My big problem are, I’ve delete the old driver packages. Can you send me the driver packages from 2014-04? The Archive has only the 2013-12 or 2014-08 packages… Thx Pascal |
5个回答
嗨Pascal,
您可以通过在网站上进行高级搜索来获取较旧的驱动程序。 http://www.nvidia.co.uk/Download/Find.aspx?lang=en-uk 但是,我想调查你在这里遇到的问题。 您是否已将更新的vGPU管理器安装到XenServer并确认它存在? (您应该会看到GPU选项卡中列出的K120Q或K220Q配置文件) 您是否使用干净的单个图像重新创建了问题,即不是使用配置服务创建的? 以上来自于谷歌翻译 以下为原文 Hi Pascal, You can get the older drivers by going through an advanced search on the website. http://www.nvidia.co.uk/Download/Find.aspx?lang=en-uk However, I'd want to investigate the problems that you're having here. Have you installed the updated vGPU manager into XenServer and confirmed it's present? (You should see the K120Q or K220Q profiles listed in the GPU tab) Have you recreated the issue with a clean single image, i.e not one created using provisioning services? |
None
以上来自于谷歌翻译 以下为原文 I can't find the driver packages from April. Where are this driver? We have a GRID K1 card with updated vGPU Manager. So I can see the K120Q profile but we use the K140Q Profile. Only the golden image is a single VM without PVS, but I connect to this computer with RDP. RDP dosn't have this problem. I think it is a problem from Citrix XDA and this version of driver. I have cleanup the nvidia driver from VM over install option, but it dosn't have a effect. I've I don't install the XD710ICAWSWX64004 but I use the registry hack for mouse Troubles, It have the same troubles as I had installed the Hotfix. Why I can't download the driver packages from April over the archive? greets Pascal |
在我们确认它是驱动程序之前,您需要从等式中消除PVS,因为它在重新启动后是间歇性的。
您是否可以使用vGPU配置文件创建新的独立VM,然后查看当前驱动程序版本是否出现相同问题。 以上来自于谷歌翻译 以下为原文 You need to eliminate PVS from the equation before we can confirm it's the driver as it's intermittent after reboots. Can you create a new standalone VM with a vGPU profile and then see if the same issue happens with the current driver release. |
嗨Pascal,
您是否设法使用非PVS VM重新创建问题? 以上来自于谷歌翻译 以下为原文 Hi Pascal, Did you manage to recreate the issue with a non PVS VM? |
嗨Jason_Southern,
我不能。 我没时间用新安装检查一下。 所以我从来没有遇到过PVS的麻烦。 我希望新的XenServer和驱动程序可以解决这个问题。 几次之后,我在旧图像上遇到了同样的问题。 现在我认为这是新的Nvidia vCPU Manager。 我可以重新启动主机,它可以工作2-5天。 那是我现在的解决方法...... 以上来自于谷歌翻译 以下为原文 Hi Jason_Southern, I can't. I've no time to check that with new install. So I had never troubles with PVS. I hope that the new XenServer and driver fix that troubles. After several times, I had the same issue on old Image. Now I think it's the new Nvidia vCPU Manager. I can restart the Host and it work for 2-5 days. Thats my workaround at the moment... |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3398 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 18:01 , Processed in 0.661672 second(s), Total 52, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
454
