嘿,伙计们,
我在Linux上有一个新的SDK 1.3.4关于SPI闪存编程的问题: SDK 1.3.3和CysBuLinux 1.0.4用于将CysBiLixx1.1.0.4/Fx3IIGIs/CyfxFlash Pro。IMG编程到RAM中。之后,我使用了DyLoad fx3示例将我的图像编程为SPI闪存。这对于SDK 1.3.3来说相当不错。 但是一旦我使用了SDK1.3.4和CysBuLinux 1.0.5的CyfxFlash Pro .IMG,它就不再擦除SPI闪存(I2C仍然有效)。我从DuxLoad FX3获得这个输出: 老图像工作 //DeLoad fx3- I/opt/CyPress 1.3.3/Cy***BiLuxx1.1.4/fx3IIGIs/CyfxFlash Pro .IMG-T-RAM FX3固件编程完成RAM //DeLoad fx3- i/MyIcim.img -t SPI 信息:发现FX3闪存程序员 信息:SPI闪存擦除扇区0 信息:SPI闪存擦除扇区1 信息:SPI闪存擦除扇区2 新形象失败: //DeLoad fx3- I/opt/CyPress /Cy***BiLuxx1.1.5/Fx3IIGIs/CyfxFlash Pro .IMG-T-RAM FX3固件编程完成RAM //DeLoad fx3- i/MyIcim.img -t SPI 信息:发现FX3闪存程序员 错误:SPI扇区擦除失败 错误:删除SPI闪存失败 错误:FX3固件编程失败 我使用的柏树S25FL128,这应该是兼容的… FX3在其UART上不打印任何关于SPI的信息,只是 设备初始化。固件ID:50 33、58、46、0、47、4F 52 就好像它从未收到过USB厂商关于SPI的请求。当我从SDK1.3.4编译CyfxFlash PRO.C源代码示例时,我自己的工作非常完美。有人能确认这个问题还是8层问题?J 最好的问候,米迦勒 以上来自于百度翻译 以下为原文 Hey guys, I have a problem regarding SPI flash programming with the new SDK 1.3.4 on Linux: With SDK 1.3.3 and cyu***_linux 1.0.4 I used to program cyu***_linux_1.0.4/fx3_images/cyfxflashprog.img into RAM. Afterwards I used the download_fx3 example to program my image to SPI flash. This worked pretty well for SDK 1.3.3. But as soon as I use the cyfxflashprog.img from SDK 1.3.4 and cyu***_linux 1.0.5, it will not erase the SPI flash anymore (I2C still works). I get this output from download_fx3: Working with old image ./download_fx3 -i /opt/cypress_1.3.3/cyu***_linux_1.0.4/fx3_images/cyfxflashprog.img -t ram FX3 firmware programming to ram completed ./download_fx3 -i ./myimage.img -t spi Info: Found FX3 flash programmer Info: Erased sector 0 of SPI flash Info: Erased sector 1 of SPI flash Info: Erased sector 2 of SPI flash Failing with new image: ./download_fx3 -i /opt/cypress/cyu***_linux_1.0.5/fx3_images/cyfxflashprog.img -t ram FX3 firmware programming to ram completed ./download_fx3 -i ./myimage.img -t spi Info: Found FX3 flash programmer Error: SPI sector erase failed Error: Failed to erase SPI flash Error: FX3 firmware programming failed I am using a Cypress S25FL128,, which should be compatible... The FX3 does not print anything regarding SPI on its UART, just Device initialized. Firmware ID: 50 33 58 46 0 47 4F 52 Just as if it never received the USB vendor requests regarding SPI. When I compile the cyfxflashprog.c source code example from SDK 1.3.4 myself it works perfectly. Can anybody confirm this issue or is it a layer 8 problem? J Best regards, Michael |
1个回答
谢谢通知。
我们会测试并回复你。 当做, 斯里达尔 以上来自于百度翻译 以下为原文 Thank you for notifying. We will test and get back to you. Regards, Sridhar |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7567浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 09:27 , Processed in 0.819149 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3469
