电子发烧友论坛|
Hello all,
我最近在看TMS570的初始化的报告如下: http://www.ti.com/lit/an/spna106d/spna106d.pdf 根据文件中,共有57个步骤。 1. Enable the floating-point unit (FPU) inside the Cortex-R4F CPU (Section 2.1). 2. Initialize the CPU registers and FPU registers, including stack pointers (Section 2.2). 3. Enable the flash interface module's response to an ECC error indicated by the CPU on accesses to flash (Section 2.3). 4. Enable the CPU's Event Bus export mechanism (Section 2.4). 5. Enable the CPU's Single-Error-Correction Double-Error-Detection (SECDED) logic for accesses to Flash memory (CPU's ATCM interface) (Section 2.5). 6. Handle the cause of reset to determine whether or not to continue with the start-up sequence (Section 2.6) 7. Check if any ESM group3 error was indicated during power-up. If any ESM group3 error occurred during the power-up, it is not safe to continue code execution and the microcontroller initialization process can be stopped at this point. The subsequent steps in this sequence assume that there was no ESM group3 error during power-up. 8. Configure PLL control registers with the largest value for the last-stage of the dividers (R-dividers) (Section 2.7). ........... 我的问题如下,譬如第一个步骤,要开启FPU、或是第二个步骤,要初始化CPU的register。但我在执行范例程式时,都并未有执行此步骤。 观看CCS,也找不到这个过程。这是因为他是CPU内部会自己执行,而不用工程师去写code执行的吗? |
2 个讨论
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2783浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 15:18 , Processed in 1.285092 second(s), Total 57, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3256
