电子发烧友论坛|
dm368 (omap l138)
使用dvsdk的demo没有使用 passthrough,而是进行编解码动作。打印信息如下: root@dm368-evm:/usr/share/ti/dvsdk-demos# DMAI_DEBUG=2 ./encodedecode -y 2 -I 1 -k 1 Encodedecode demo started. @0x00045d14:[T:0x4001f040] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to DMAI tracing behavior. @0x0004969d:[T:0x4001f040] ti.sdo.dmai - [Display] Found width=720 height=576, yres_virtual=576,xres_virtual=720, line_length=384 @0x000497c3:[T:0x4001f040] ti.sdo.dmai - [Display] Setting width=720 height=576, yres_virtual=576, xres_virtual=720 @0x00049882:[T:0x4001f040] ti.sdo.dmai - [Display] New width=720, height=576, yres_virtual=576,xres_virtual=720, line_length=384 @0x0004995f:[T:0x4001f040] ti.sdo.dmai - [BufTab] Allocating BufTab for 1 buffers @0x00049aad:[T:0x4001f040] ti.sdo.dmai - [Buffedavinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124 r] Set user poindavinci_previewer davinci_previewer.2: ipipe_set_preview_config ter 0x40309000 (vpfe-capture vpfe-capture: IPIPE Chained physical 0x82600vpfe-capture vpfe-capture: Resizer present 000) @0x00049f6EVM: switch to tvp5146 SD video input f:[T:0x4001f040] ti.sdo.dmai - [chip id detected m***:0x47 l***:0x46 Display] Displaytvp514x 1-005d: tvp5146 (Version - 0x07) found at 0xba (DaVinci I2C adapter) buffer 0 mapped to 0x40309000 has physical address 0xb1d8 @0x00053d46:[T:0x4133e490] ti.sdo.dmai - [BufTab] Allocating BufTab for 3 buffers @0x00053edf:[T:0x4133e490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x4133f000 (0x83c00000 phys) @0x000540d2:[T:0x4133e490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x413db000 (0x83c9c000 phys) @0x00054289:[T:0x4133e490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x41477000 (0x83d38000 phys) @0x0005444c:[T:0x4133e490] ti.sdo.dmai - [Resize] Successfully set mode to continuous in resizer @0x00055bbb:[T:0x4133e490] ti.sdo.dmai - [Resize] Resizer initialized @0x00055cf6:[T:0x4133e490] ti.sdo.dmai - [Resize] Operating mode changed successfully to continuous in previewer @0x0005776a:[T:0x4133e490] ti.sdo.dmai - [Resize] Previewer initialized @0x0005a01c:[T:0x4133e490] ti.sdo.dmai - [Capture] Composite input selected @0x0007c85b:[T:0x41d12490] ti.sdo.dmai - [Vdec2] Video decoder instance created @0x0007ca20:[T:0x41d12490] ti.sdo.dmai - [Vdec2] Made XDM_SETPARAMS control call @0x0007cb1b:[T:0x41d12490] ti.sdo.dmai - [Vdec2] Made XDM_GETBUFINFO control call @0x0007cce6:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 1024000 at 0x4208a000 (0x83f38000 phys) @0x0007cdb3:[T:0x41d12490] ti.sdo.dmai - [Venc1] Creating encoder mpeg4enc for max 736x576 bitrate 0 ratectrl 4 @0x00095747:[T:0x41d12490] ti.sdo.dmai - [Venc1] Setting dynParams size 736x576 bitrate 0 @0x0009594e:[T:0x41d12490] ti.sdo.dmai - [Venc1] Made XDM_SETPARAMS control call @0x00095a62:[T:0x41d12490] ti.sdo.dmai - [BufTab] Allocating BufTab for 11 buffers @0x00095c40:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x42341000 (0x841ee000 phys) @0x00095e53:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x423dd000 (0x8428a000 phys) @0x0009602f:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x42479000 (0x84326000 phys) @0x0009620a:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x42515000 (0x843c2000 phys) @0x0009642d:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x425b1000 (0x8445e000 phys) @0x0009660c:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x4264d000 (0x844fa000 phys) @0x0009680d:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x426e9000 (0x84596000 phys) @0x00096a05:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x42785000 (0x84632000 phys) @0x00096be1:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x42821000 (0x846ce000 phys) @0x00096de3:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x428bd000 (0x8476a000 phys) @0x0009704b:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 635904 at 0x42959000 (0x84806000 phys) @0x00097116:[T:0x41d12490] ti.sdo.dmai - [BufTab] Allocating BufTab for 7 buffers @0x0009733a:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x429f5000 (0x848a2000 phys) @0x00097519:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x42aa0000 (0x8494d000 phys) @0x0009771f:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x42b4b000 (0x849f8000 phys) @0x00097937:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x42bf6000 (0x84aa3000 phys) @0x00097b13:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x42ca1000 (0x84b4e000 phys) @0x00097cf0:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x42d4c000 (0x84bf9000 phys) @0x00097f0d:[T:0x41d12490] ti.sdo.dmai - [Buffer] Alloc Buffer of size 700416 at 0x42df7000 (0x84ca4000 phys) @0x000fdb04:[T:0vpfe-capture vpfe-capture: width = 736, height = 576, bpp = 1 x4133e490] ti.sdvpfe-capture vpfe-capture: adjusted width = 736, height = 576, bpp = 1, bytesperline = 736, sizeimage = 635904 o.dmai - [Capturvpfe-capture vpfe-capture: width = 736, height = 576, bpp = 1 e] Setting videovpfe-capture vpfe-capture: adjusted width = 736, height = 576, bpp = 1, bytesperline = 736, sizeimage = 635904 standard to: 6 @0x000fdcb3:[T:0x4133e490] ti.sdo.dmai - [Capture] Capture input set to Composite:6 @0x000fdd5d:[T:0x4133e490] ti.sdo.dmai - [Capture] Forcing user specified video standard @0x000fdddb:[T:0x4133e490] ti.sdo.dmai - [Capture] Capture dimention is set to 736x576 @0x00106941:[T:0x4133e490] ti.sdo.dmai - [Capture] Video input connected size 736x576 pitch 736 Command [ 'help' for usage ] > @0x00131278:[T:0x41d12490] ti.sdo.dmai - [Venc1] VIDENC1_process() ret 0 inId 0 outID 1 generated 24539 bytes @0x001358aa:[T:0x41d12490] ti.sdo.dmai - [Vdec2] VIDDEC2_process() ret 0 inId 0 inUse 0 consumed 24539 @0x0013b03e:[T:0x41d12490] ti.sdo.dmai - [Venc1] VIDENC1_process() ret 0 inId 1 outID 2 generated 3391 bytes @0x0013da47:[T:0x41d12490] ti.sdo.dmai - [Vdec2] VIDDEC2_process() ret 0 inId 1 inUse 0 consumed 3391 @0x0015d28e:[T:0x41d12490] ti.sdo.dmai - [Venc1] VIDENC1_process() ret 0 inId 2 outID 3 generated 2692 bytes @0x0015fb82:[T:0x41d12490] ti.sdo.dmai - [Vdec2] VIDDEC2_process() ret 0 inId 2 inUse 0 consumed 2692 ARM Load: 34% Video fps: 0 fps Video bit rate: 204 kbps Time: 00:00:01 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:02 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:03 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:04 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:06 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:07 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:08 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:09 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 SARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:10 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 TOP Unknown command: [ STOP ] Command [ 'help' for usage ] > ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:12 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 sdARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:13 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 top ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:14 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 Unknown command: [ sdtop ] Command [ 'help' for usage ] > ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:15 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:16 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 helARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:18 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 p Available commands: play - Play / record video and sound pause - Pause video and sound stop - Quit demo inc - Increase OSD visibility dec - Decrease OSD visibility hide - Show / hide the OSD help - Show this help screen Command [ 'help' for usage ] > ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:19 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 stop ARM Load: 0% Video fps: 0 fps Video bit rate: 0 kbps Time: 00:00:20 Demo: Encode Decode Display: D1 PAL Video Codec: MPEG4 SP Video Resolution: 736x576 输入命令stop后卡死。直接ctrl+c强行退出后打印信息如下: tvp514x 1-005d: Write: retry ... 0 tvp514x 1-005d: Write: retry ... 1 tvp514x 1-005d: Write: retry ... 2 tvp514x 1-005d: Write: retry ... 3 tvp514x 1-005d: Write: retry ... 4 tvp514x 1-005d: Write: retry ... 5 tvp514x 1-005d: Unable to turn off decoder vpfe-capture vpfe-capture: stream off failed in subdev 使用encode明后发现log信息一致。 studying & working! |
2 个讨论
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2783浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 16:56 , Processed in 0.467036 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1549
