8168+DVRRDK
使用IOUTA~IOUTC,连接到视频放大器,再引出RGB信号,行、场信号用的AR8和AL9。 uboot启动时,没有输出logo。测量IOUTA~IOUTC,都没有波形,一直是0V。行、场信号也没有波形 参考 http://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/716/p/247546/867752#867752 操作如下 mw.b 0x81000000 0xFF 0x300000 tftp 0x81000000 samplelogo_640x480.bmp nand erase 0x00280000 0x300000 nand write 0x81000000 0x00280000 0x300000 setenv bootcmd ' logo on 0x280000 0x81000000 0xA0000000 40 60' 重启之后,uboot无法进入命令行 看到有人说修改device.c中的 omap_mux_init_signal("tsi5_bytstrt", OMAP_MUX_MODE2); omap_mux_init_signal("tsi5_pacval", OMAP_MUX_MODE2); 可是这个c文件是在kernel中的,并不在uboot中,应该不是这个问题。 问题一:RDK是否支持从模拟DAC接口输出boot logo 问题二:如何确认uboot是否对DAC进行了配置 在cmd_logo_816x.c中看到了如下语句 /*enable the DAC_CORE*/ WR_MEM_32(0x48140660, 0x1); /*set the HSYNC/VSYNC for HDCOMP, use DVO1 signal, this is for PG2.0 or above silicon only*/ if ( get_cpu_rev() >= PG2_0) [ /*these settings matches DVR reference, it may not work with DM816X EVM*/ WR_MEM_32(0x4814086c, 0x2); WR_MEM_32(0x48140870, 0x2); WR_MEM_32(0x48140724, 0x2); 可是用md命令读0x4814086c和0x48140870,返回全是0。 https://e2e.ti.com/support/dsp/davinci_digital_media_processors/f/717/t/240982 里边提到可以查看寄存器设置,请问查询命令是什么。试过mdump,提示非法命令。 问题三:管脚复用问题 手册P262中 For example, these are the steps required to use the pins AR8 and AL9 as the DAC_HSYNC and VSYNC signals: 1. Set the PINCTRLx registers for AR8 and AL9 as follows: • 0x4814 0894 = 0x00000001 • 0x4814 0898 = 0x00000001 2. Select analog VENC sync out option as follows: • 0x4814 0724 = 0x00000004 cmd_logo_816x.c中的 REG32(CSL_TI816x_CTRL_MODULE_BASE + 0x0894) = 1; //37 tsi7_bytstrt vout0_fld REG32(CSL_TI816x_CTRL_MODULE_BASE + 0x0898) = 1; //38 tsi7_pacval vout0_avid /*enable the DAC_CORE*/ WR_MEM_32(0x48140660, 0x1); /*set the HSYNC/VSYNC for HDCOMP, use DVO1 signal, this is for PG2.0 or above silicon only*/ if ( get_cpu_rev() >= PG2_0) [ /*these settings matches DVR reference, it may not work with DM816X EVM*/ WR_MEM_32(0x4814086c, 0x2); WR_MEM_32(0x48140870, 0x2); WR_MEM_32(0x48140724, 0x2); 是否需要将WR_MEM_32(0x48140724, 0x2);改为WR_MEM_32(0x48140724, 0x4); 问题四:uboot启动时,会在串口输出如下字符图形,该图形是否可以修改? :,;;:;:;;;;;;;;r;;:,;;:;:;;;;;;;;:,;;:;:;;;;;;;;:,;;:;:;;;;;;;;:;;;;;;;;:,;;:;: ;,;:::;;;;r;;;rssiSiS552X5252525259GX2X9hX9X9XX2325S55252i5:,;;:;:;;;;;;;;:,;;: ;:;;;;;;;rrssSsS52S22h52299GGAAMHMM#BBH#B#HMM#HMBA&&XX2255S2S5Si:,;;:;:;;;;;;;; ;:;;r;;rsrrriiXS5S329&A&MH#BMB#A&9XXA252GXiSXX39AAMMMBB&G22S5i2SSiiiisi:,;;:;:; ;;;;;r;rr2iisiih393HB#B#AA99i22irrrX3X52AGsisss2Xii2299HBMA&X2S5S5iSiisSsi:,;;: r:r;rrsrsihXSi2#MHB&Ahh3AGHGA9G9hH##@@@##MAMMXXX9SSS29&&HGGX2i5iisiiisisi:, ;;rrrrsSiiiA&ABH&A9GAGhAhBAMHA9HM@@@@@@@@@@@@@@@@@@@HHhAh2S2SX9&Gh22SSiisiiisii r:rrssisiS2XM##&h3AGAX&3GG3Ssr5H@M#HM2; ;2X&&&MHMB###GBB#B&XXSSs529XX55iSsisisi r;rsrisSi2XHAhX99A3XXG&&XS;:,rH#HGhAS @@@@3rs2XBM@@A552&&AHA2XiisSS252SSsisSs r;issi5S22&&3iSSX292&hXsr;;:;h@&G339&S9@@@@2@MA&9&HB##Xris29ABMAAX2ir;rsSi5iss5 rrsSi2XhG&9GXh399&X99i;;;;;;r#H&293H9X#@@@@@@@B&9GhAH@XrrsrsiXABHB&HG2rr;rrSiSi ;:rsisS599&AA9XG&3A35r;:::;,;BMh&&2iX5A@@@@@@@&392X5GB2;;;r;iSX393A##A&Xi:::rsi ;:rss552222X553&XHMhir;;::,:,h#HhGSXhG3#@@@@#AXXS2XAHA;::;;;;ss55XShBA3239r:,;; r;ii2S5SSi2i53hirsh2srr::,,,,;MMXX359&Ah3h&Si59SX99A#i:,::::;;sri2,.2r;:SGAr;,: ;:;rrrrssiriXGSi::shs;;;,,,:,,rBBA9h5s5h5iS5isi2SAHB5:,,,:::;rrs5&SrisSX5Srrr:, ;,r;;;;rsriSSrrrr;;5Xrr;;,:,,.,;9AA2SsisS5323XXXG9&i:.,,::;;r;;;srrrrrr;;:;:::: :,;r;r;rrissrrr;:;::;s;;;;,:,,..,r293h222hXXAAGGGX;:,,,:,:,::;:;::,:,,,,...,,,, ;,;;;;rrrrrrrrirr;,.,,:::::::,,,,.,;SX&ABAB2hhXir:,,.,,.,,:,,,,..,,,..,..,,,..: :.:;:;;;:;;;;r;rrs;:.. ,,:::::,:,:,,.::rrsrr;;,,.......,..,....,,,,,,,...,.,,:, :.:::,::::::;;r;rrr;:.......,.,.,,:::,,...............,,::.,,,,:,::,,:,:,,,:,;: ,.::,:,,,,,;;;;;;;;r;;::,..............................;;;:;::::,:::::::,:,:,,, : ,,:,,,,,,,,,,,,,:;rrr;;:;,,,,,,,::,.,.:.,.,;s,:;;;;:;:;;;;;::::,:::,:::,:,:,: ,.,,,,,,,...,,.,,....................................:,............:,,,:,:,,,,, |
相关推荐 |
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
697 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
607 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1069 浏览 1 评论
765 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
532 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
175浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
137浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
132浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
126浏览 12评论
GD32F303RCT6配置PA4 ADC引脚,将PA2代替key功能,PA2连接时无法实现预期功能,为什么?
75浏览 10评论
GMT+8, 2024-12-1 15:17 , Processed in 0.662179 second(s), Total 61, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
