扫一扫,分享给好友
平台是omap3730使用xdc.tools.configuro帮助编译连接资源。
toolchain是ARM-2009q1/bin/arm-none-linux-gnueabi-gcc 参照例子,xdctarget是gnu.targets.arm.GCArmv5T 报错: js: "./package.bld", line 62: Error: template generation of 'compiler.opt' failed: xdc.services.global.XDCException: gnu.targets.UNDEFINED_EXECUTABLE: 'LONGNAME' must be defined for the target gnu.targets.arm.GCArmv5T 查RTSC文档的确没有gnu.targets.arm.GCArmv5T 于是尝试gnu.targets.MVArm9和UCArm9 gnu.targets.MVArm9: js: "./package.bld", line 62: Error: template generation of 'compiler.opt' failed: Error: /opt/env/toolchain/arm-2009q1/bin/arm_v5t_le-gcc cannot be found. Ensure that rootDir for the MVArm9 target is set correctly in ./config.bld gnu.targets.UCArm9: js: "./package.bld", line 62: Error: template generation of 'compiler.opt' failed: Error: /opt/env/toolchain/arm-2009q1//bin/arm-linux-gcc cannot be found. Ensure that rootDir for the UCArm9 target is set correctly in ./config.bld 都没有去找arm-none-linux-gnueabi-gcc 于是.bld和.cfg尝试添加 var GCArmv5T = xdc.useModule('gnu.targets.XXXXX'); GCArmv5T.platform = 'ti.platforms.evm3530'; GCArmv5T.rootDir = "/opt/env/toolchain/arm-2009q1"; GCArmv5T.LONGNAME = "bin/arm-none-linux-gnueabi-gcc"; 错误依旧... 无解中... 期待回复中... |
3个回答
metaonly module gnu.targets.arm.GCArmv5T:
rtsc.eclipse.org/.../index.html 查到了... 纠正一下 查RTSC文档的确没有gnu.targets.arm.GCArmv5T 的错误 简介一下问题: 使用xdc.tools.configuro帮助编译ARM端调用程序时,-t $(XDCTARGET) 使用gnu.targets.arm.GCArmv5T,make时报错(如下) js: "./package.bld", line 62: Error: template generation of 'compiler.opt' failed: xdc.services.global.XDCException: gnu.targets.UNDEFINED_EXECUTABLE: 'LONGNAME' must be defined for the target gnu.targets.arm.GCArmv5T |
解决办法:
参照rtsc.eclipse.org/.../index.html 自己创建一个config.bld文件,内容如下: /* * ======== config.bld ======== */ var Build = xdc.useModule('xdc.bld.BuildEnvironment'); //var C64P = xdc.useModule('ti.targets.C64P'); var GCC = xdc.useModule('gnu.targets.arm.GCArmv5T'); /* modify to match %c6xtools% */ //C64P.rootDir = "/opt/dvsdk/cgt6x_6_1_14"; //C64P.ccOpts.prefix = "--no_compress"; //C64P.platform = 'ti.platforms.evm3530'; /* modify to match %gcctools% */ GCC.rootDir = "/opt/toolchains/arm-2009q1"; GCC.ccOpts.prefix = "-O2" GCC.platform = 'ti.platforms.evm3530' GCC.LONGNAME = '/bin/arm-none-linux-gnueabi-gcc' Build.targets = [GCC]; 在使用xdc.tools.configuro工具是使用参数-b指定config.bld文件。 |
敬佩楼主的钻研精神 |
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
696 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
605 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1065 浏览 1 评论
760 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
530 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
171浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
133浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
130浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
126浏览 12评论
GD32F303RCT6配置PA4 ADC引脚,将PA2代替key功能,PA2连接时无法实现预期功能,为什么?
64浏览 10评论
GMT+8, 2024-11-29 17:20 , Processed in 0.956690 second(s), Total 82, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
