% 安防多斜率 多目标配对 % n目标 n个斜率 +MTD % fs=1e6; % 1M % 8倍抽取 Fs=125k % # % # 缺陷: % # 1.信号源是三角调制波平移和上下移得到,不是通过公式得到 % # 2.多目标配对写的方法较复杂,效果也不是很好 % # 3.无Mti MTD算法 % ------------------------------------------------------------------------------ clc; clear all; close all; %% B=250e6; fs=500e6; % 1M dt=1/fs; c=3e8; fc=34.5e9; n_MTI=4; n_MTD=n_MTI; T=[40e-3 ,50e-3 ,60e-3 ,70e-3 ]; n_slope=length(T); R=[ 20 ,40 ,60 ,80 ];% 单位:m V=[ 1 ,2 ,3 ,4 ];% 单位:m/s n_target=length(R); for i=1:n_target tao(i)=2*R(i)/c; n_tao(i)=fix(tao(i)/dt); % 目标1的时间延迟 end t_delay_max=1e-4; n_delay_max=t_delay_max/dt+1; t_total_1=t_delay_max; % 15000m时间延迟 n_T_total=0; f_add=zeros(n_slope,n_target); for i=1:n_slope T_half(i)=T(i)/2; K(i)=B/T_half(i); eval(['t',num2str(i),'=0:dt:T(i);']); n_T(i)= T(i)/dt+1; n_T_half(i)= fix(n_T(i)/2); t_total_1=t_total_1+T(i); for j=1:n_target f_add(i,j)=(tao(j)-n_tao(j)*dt)*K(i); end n_T_total=n_T(i)+n_T_total; % 三角波调制时间点数,不含延迟时间 end % 怎么处理处理连续时间和离散时间的关系 t_total=0:dt:t_total_1+n_slope*dt; n_t_total=n_delay_max+n_T_total; % tao(1)=2*(R(1)+V(1)*t1)/c; %% 发射 for i=1:n_slope eval(['Sm_T_up_',num2str(i),'=K(i)*t',num2str(i),'(1:n_T_half(i));']); eval(['Sm_T_down_',num2str(i),'=-K(i)*(t',num2str(i),'(n_T_half(i)+1:n_T(i))-T(i));']); eval(['Sm_T_',num2str(i),'=[Sm_T_up_',num2str(i),',Sm_T_down_',num2str(i),'];']); end Sm_T=zeros(1,n_t_total); n_T_start=1; n_T_end=0; for i=1:n_slope n_T_end=n_T_end+n_T(i); eval([ 'Sm_T(n_T_start:n_T_end)=Sm_T_',num2str(i),';' ]); n_T_start=n_T_start+n_T(i); end figure; hold on; plot(Sm_T); % t = 0:ts_bb:T(1)+T(2)+T(3)+T(4); % Sm_T = 2*pi*(fc + Sm_T).*(t - n_t_half*T_half) + 0;% 发射信号相位 %% 接收 Sm_R=zeros(n_target,n_t_total); for i=1:n_target Sm_R(i,:)=[zeros(1,n_tao(i)),Sm_T(1:(n_t_total-n_tao(i)) )]; f_IF(i)=2*K(1)*R(i)/c; %目标1的距离频移 f_d(i)=2*fc*V(i)/c; %目标1的多普勒频移 end for j=1:n_target n_***_t=n_tao(j); for i=1:n_slope %eval([]); Sm_R(j,n_***_t+1:n_***_t+n_T_half(i))=Sm_R(j,n_***_t+1:n_***_t+n_T_half(i))-f_add(i,j); Sm_R(j,n_***_t+n_T_half(i)+1:n_***_t+n_T(i))=Sm_R(j,n_***_t+n_T_half(i)+1:n_***_t+n_T(i))+f_add(i,j); % 因为n_tao1取整平移后,有量化损失,上面加减f_add就是补偿这种损失 n_***_t=n_***_t+n_T(i); end Sm_R(j,:)=Sm_R(j,:)+f_d(j); end % figure; plot(Sm_R(1,:),'r'); plot(Sm_R(2,:),'k'); %% 差拍 for j=1:n_target Sm_B(j,:)=Sm_T-Sm_R(j,:); Sm_B(j,:)=abs(Sm_B(j,:)); end plot(Sm_B(1,:),'y'); plot(Sm_B(2,:),'g'); %axis([1,n_T(1)+n_tao(1),-5e6,5e6]); hold off; % n_Sm_B=length(Sm_B(1,:)); % n_t_total=(n_Sm_B-1)*dt; % t_total=0:dt:n_t_total; ***_temp=zeros(n_target,n_t_total); for j=1:n_target ***_temp(j,:)=cos(2*pi*Sm_B(j,:).*t_total); %调制,产生已调信号 end ***=***_temp(1,:); for i=1:n_target-1 ***=***+***_temp(i+1,:); end figure; plot(***); ***=***/max(***); %信号归一化 ***=awgn(***,10); figure; plot(***); %% FFT变换 N_fft=1024; tao_max=t_delay_max; % win_fft = window(@hamming,N_fft); % fft窗函数 hamming rectwin gausswin % % 加窗,压制旁瓣,同时也会展宽通带 n_fft_t_start=fix(tao_max/dt) + 1; take_up=zeros(n_slope,N_fft); take_down=zeros(n_slope,N_fft); ***_fft_up=zeros(n_slope,n_MTI+1,N_fft); ***_fft_down=zeros(n_slope,n_MTI+1,N_fft); % win_fft = window(@hamming,N_fft); % fft窗函数 hamming rectwin gausswin % FFT数据点抽取 ext_number=8; for i=1:n_slope take_up(i,:)=***(n_fft_t_start+1:ext_number:n_fft_t_start+N_fft*ext_number); take_down(i,:)=***(n_fft_t_start+1+n_T_half(i):ext_number:n_fft_t_start+n_T_half(i)+N_fft*ext_number); n_fft_t_start=n_fft_t_start+n_T(i); end Fs=fs/ext_number; freq=linspace(0,Fs/2,N_fft/2); up_mat=zeros(4,1024); down_mat=zeros(4,1024); for i=1:n_slope up_mat(i,:)=abs(fft(take_up(i,:),1024)); down_mat(i,:)=abs(fft(take_down(i,:),1024)); end figure hold on plot(up_mat(3,:)); plot(down_mat(3,:),'r'); % axis([0 Fs/5 0 1000]) legend('1','2') title('fft') grid on hold off %% 恒虚警处理 WIN=10; PRO=2; %%% 减少保护单元PRO,需要增加参考单元的数目 N_cfar=N_fft; first =WIN+PRO+1; last = N_cfar-WIN-PRO; cfar_up=up_mat; cfar_down=down_mat; MEN_up= NaN*ones(n_slope,N_cfar); MEN_down= NaN*ones(n_slope,N_cfar); for i=1:n_slope for k=1:first-1 MEN_up(i,k)=sum(cfar_up(i,k+PRO+1:k+WIN+PRO))/WIN; end for k=first:last % MEN(k) = mean([u(k-WIN-PRO:k-PRO-1);u(k+PRO+1:k+WIN+PRO)]); sum1=sum(cfar_up(i,k-WIN-PRO:k-PRO-1))/WIN; sum2=sum(cfar_up(i,k+PRO+1:k+WIN+PRO))/WIN; MEN_up(i,k)=(sum1+sum2)/2; end for k=last+1:N_cfar MEN_up(i,k)=sum(cfar_up(i,k-WIN-PRO:k-PRO-1))/WIN; end for k=1:first-1 MEN_down(i,k)=sum(cfar_down(i,k+PRO+1:k+WIN+PRO))/WIN; end for k=first:last % MEN(k) = mean([u(k-WIN-PRO:k-PRO-1);u(k+PRO+1:k+WIN+PRO)]); sum1=sum(cfar_down(i,k-WIN-PRO:k-PRO-1))/WIN; sum2=sum(cfar_down(i,k+PRO+1:k+WIN+PRO))/WIN; MEN_down(i,k)=(sum1+sum2)/2; end for k=last+1:N_cfar MEN_down(i,k)=sum(cfar_down(i,k-WIN-PRO:k-PRO-1))/WIN; end end % 输出高于门限值的距离单元和幅度值 pfa=10^(-3); % 恒虚警概率 n2=2*WIN; n3=-1/n2; % alfa=n2*(pfa^n3-1); % alfa=n2*(pfa^n3-1)/3.5; alfa=2; u_MEN_up=alfa*MEN_up; u_MEN_down=alfa*MEN_down; freq=linspace(-Fs/2,Fs/2,N_cfar); % 画门限图 %{ %} for i=1:n_slope figure hold on plot(cfar_up(i,:),'*'); plot(u_MEN_up(i,:),'r'); %axis([0 Fs/5 0 1000]) legend('up','CAFR门限') title(['up',num2str(i)]) grid on hold off figure hold on plot(cfar_down(i,:),'*'); plot(u_MEN_down(i,:),'r'); %axis([0 Fs/5 0 1000]) legend('down','CAFR门限') title(['down',num2str(i)]) grid on hold off end %% 目标信息判决 % target_max=100; HXJ_up =zeros(n_slope,N_cfar/2); INDEX_up =zeros(n_slope,N_cfar/2); INDEX_temp1=0; INDEX_temp2=0; count_1=zeros(n_slope,1); count_2=zeros(n_slope,1); HXJ_down =zeros(n_slope,N_cfar/2); INDEX_down =zeros(n_slope,N_cfar/2); for j=1:n_slope for i=1:N_cfar/2 % 选出大于门限的点 if (cfar_up(j,i)>u_MEN_up(j,i)) && (cfar_up(j,i)>60) count_1(j)=count_1(j)+1; HXJ_up(j,count_1(j))=cfar_up(j,i); INDEX_up(j,count_1(j))=i; end end count_2(j)=0; for i=1:N_cfar/2 % 选出大于门限的点 if (cfar_down(j,i)>u_MEN_down(j,i)) && (cfar_down(j,i)>60) count_2(j)=count_2(j)+1; HXJ_down(j,count_2(j))=cfar_down(j,i); INDEX_down(j,count_2(j))=i; end end end count_1_max=max(count_1); count_2_max=max(count_2); UpDown1=zeros(n_slope,count_1_max+1); UpDown2=zeros(n_slope,count_2_max+1); Top1=zeros(n_slope,count_1_max); Top2=zeros(n_slope,count_2_max); for i=1:n_slope % 上扫频 标出频点间是 断开 上升 下降 for j=1: count_1(i)-1 if INDEX_up(i,j)==(INDEX_up(i,j+1)-1) if HXJ_up(i,j)>HXJ_up(i,j+1) UpDown1(i,j+1)=1; % 下降 else UpDown1(i,j+1)=2; % 上升 end end end end for i=1:n_slope % 标出频点 是否为顶点 for j=1: count_1(i) if UpDown1(i,j)==0 && UpDown1(i,j+1)==0 Top1(i,j)=1; % 顶点 elseif UpDown1(i,j)==0 && UpDown1(i,j+1)==1 Top1(i,j)=1; elseif UpDown1(i,j)==0 && UpDown1(i,j+1)==2 Top1(i,j)=2; elseif UpDown1(i,j)==1 && UpDown1(i,j+1)==0 Top1(i,j)=2; elseif UpDown1(i,j)==1 && UpDown1(i,j+1)==1 Top1(i,j)=2; elseif UpDown1(i,j)==1 && UpDown1(i,j+1)==2 Top1(i,j)=2; elseif UpDown1(i,j)==2 && UpDown1(i,j+1)==0 Top1(i,j)=1; elseif UpDown1(i,j)==2 && UpDown1(i,j+1)==1 Top1(i,j)=1; elseif UpDown1(i,j)==2 && UpDown1(i,j+1)==2 Top1(i,j)=2; end end end for i=1:n_slope % 去除不是顶点的点 j=1; while j<=count_1(i) if Top1(i,j)==2 for h=j:count_1(i) HXJ_up(i,h)=HXJ_up(i,h+1); INDEX_up(i,h)=INDEX_up(i,h+1); if h+1<=count_1(i) Top1(i,h)=Top1(i,h+1); elseif h+1==count_1(i)+1 Top1(i,h)=0; end end count_1(i)=count_1(i)-1; % 减少一点 j=j-1; end j=j+1; end end for i=1:n_slope % 下扫频 标出频点间是 断开 上升 下降 for j=1: count_2(i)-1 if INDEX_down(i,j)==(INDEX_down(i,j+1)-1) if HXJ_down(i,j)>HXJ_down(i,j+1) UpDown2(i,j+1)=1; % 下降 else UpDown2(i,j+1)=2; % 上升 end end end end for i=1:n_slope % 标出频点 是否为顶点 for j=1: count_2(i) if UpDown2(i,j)==0 && UpDown2(i,j+1)==0 Top2(i,j)=1; % 顶点 elseif UpDown2(i,j)==0 && UpDown2(i,j+1)==1 Top2(i,j)=1; elseif UpDown2(i,j)==0 && UpDown2(i,j+1)==2 Top2(i,j)=2; elseif UpDown2(i,j)==1 && UpDown2(i,j+1)==0 Top2(i,j)=2; elseif UpDown2(i,j)==1 && UpDown2(i,j+1)==1 Top2(i,j)=2; elseif UpDown2(i,j)==1 && UpDown2(i,j+1)==2 Top2(i,j)=2; elseif UpDown2(i,j)==2 && UpDown2(i,j+1)==0 Top2(i,j)=1; elseif UpDown2(i,j)==2 && UpDown2(i,j+1)==1 Top2(i,j)=1; elseif UpDown2(i,j)==2 && UpDown2(i,j+1)==2 Top2(i,j)=2; end end end for i=1:n_slope % 去除不是顶点的点 j=1; while j<=count_2(i) % 为什么不用for,因为在matlab中 for循环中不能改变循环变量i if Top2(i,j)==2 for h=j:count_2(i) HXJ_down(i,h)=HXJ_down(i,h+1); INDEX_down(i,h)=INDEX_down(i,h+1); if h+1<=count_2(i) Top2(i,h)=Top2(i,h+1); elseif h+1==count_2(i)+1 Top2(i,h)=0; end end count_2(i)=count_2(i)-1; % 减少一点 j=j-1; end j=j+1; end end %% 计算R V count_1_max=max(count_1); count_2_max=max(count_2); up_target_num_max=count_1_max; down_target_num_max=count_2_max; n_num=up_target_num_max*down_target_num_max; updown_num=count_1.*count_2; index_up=INDEX_up(1:n_slope,1:up_target_num_max); index_down=INDEX_down(1:n_slope,1:down_target_num_max); freq_up=Fs*(index_up-1 )/N_cfar; %%索引指数:N_cfar/2-INDEX(1)+1; freq_down=Fs*(index_down-1 )/N_cfar; % 画RV图 R_plot=1:100; V_plot_up=zeros(n_num ,100,n_slope); V_plot_down=zeros(n_num ,100,n_slope); for j=1:n_slope for i=1:count_1(j) for h=1:count_2(j) V_plot_up((i-1)*count_2(j)+h,:,j)=( freq_up(j,i)*c -4*B*R_plot/T(j))/(2*fc); V_plot_down((i-1)*count_2(j)+h,:,j)=( -freq_down(j,h)*c +4*B*R_plot/T(j))/(2*fc); end end end figure axis([0,100,-20,20]) hold on for j=1:n_slope for i=1:updown_num(j) plot(R_plot,V_plot_up(i,:,j),'r'); plot(R_plot,V_plot_down(i,:,j),'b'); end end title('RV图') xlabel('R,m') %添加x轴标注 ylabel('V,m/s') %添加y轴标注 grid on R_get=zeros(n_slope,n_num ); V_get=zeros(n_slope,n_num ); for j=1:n_slope % 计算出RV(含鬼目标) for i=1:count_1(j) for h=1:count_2(j) R_get(j,count_2(j)*(i-1)+h)=c*(freq_up(j,i)+freq_down(j,h))*T(j)/(8*B); V_get(j,count_2(j)*(i-1)+h)=c*(freq_up(j,i)-freq_down(j,h))/(4*fc); end end end for j=1:n_slope plot(R_get(j,:),V_get(j,:),'og'); end hold off R_get_2=R_get; V_get_2=V_get; Axis_d=zeros(n_slope*n_num,n_num); %距离 Axis_temp2=0; Axis_temp3=0; Axis_x=zeros(n_slope*n_slope*n_num,4); n_count=0; k=1; for k=1:n_slope-1 % 去除鬼目标 for j=1:updown_num(k) for i=k+1:n_slope for h=1:updown_num(i) if abs( V_get_2(k,j)-V_get_2(i,h) )<0.2 if abs(R_get_2(k,j)-R_get_2(i,h) )<0.5 n_count=n_count+1; Axis_x(n_count,:)=[k,j,i,h]; % 将两个相关联的目标的数组位置存储起来 Axis_temp3=Axis_temp3+1; Axis_temp2=Axis_temp2+1; % 找到对应目标,自+1 Axis_d(Axis_temp3,Axis_temp2)=( V_get_2(k,j)-V_get_2(i,h) )^2+( R_get_2(k,j)-R_get_2(i,h) )^2; end end end if Axis_temp2>1 %检验,如果对应的点数大于1,就删除多余的点 [min_d,min_I]=min(Axis_d); Axis_x(n_count-Axis_temp2+1,:)=Axis_x(n_count-Axis_temp2+1+min_I,:); n_count=n_count-Axis_temp2+1; end Axis_temp2=0; end end end Target=zeros(n_count,2,n_count); Target_temp=zeros(n_count,1); % 某个目标对应的 结果数 n_Target=0; % 总共有多少个目标 n_temp1=0; n_temp2=0; %标志位, n_temp3=0; %标志位 n_temp4=0; %第n个目标 n_temp5=0; %第n个目标 j=0; n_RV=0; n_count_temp1=0; for i=1:n_count % 将同一目标的RV平均 if i==1 n_Target=n_Target+1; Target(1,:,n_Target)=Axis_x(1,1:2); Target(2,:,n_Target)=Axis_x(1,3:4); Target_temp(n_Target)=2; else for j=1:n_Target for h=1:Target_temp(j) if Axis_x(i,1:2)==Target(h,:,j) n_temp2=1; n_temp4=j; end if Axis_x(i,3:4)==Target(h,:,j) n_temp3=1; n_temp5=j; end end end if n_temp2==1 && n_temp3==0 Target_temp(n_temp4)=Target_temp(n_temp4)+1; Target(Target_temp(n_temp4),:,n_temp4)=Axis_x(i,3:4); elseif n_temp2==0 && n_temp3==1 Target_temp(n_temp5)=Target_temp(n_temp5)+1; Target(Target_temp(n_temp5),:,n_temp5)=Axis_x(i,1:2); elseif n_temp2==0 && n_temp3==0 n_Target=n_Target+1; Target(1,:,n_Target)=Axis_x(i,1:2); Target(2,:,n_Target)=Axis_x(i,3:4); Target_temp(n_Target)=2; end n_temp2=0; n_temp3=0; n_temp4=0; n_temp5=0; end end R_get_3=zeros(1,n_Target); V_get_3=zeros(1,n_Target); for i=1:n_Target for j=1:Target_temp(i) A=R_get_2(Target(j,1,i),Target(j,2,i)); R_get_3(i)=R_get_3(i)+R_get_2(Target(j,1,i),Target(j,2,i)); V_get_3(i)=V_get_3(i)+V_get_2(Target(j,1,i),Target(j,2,i)); end R_get_3(i)=R_get_3(i)/Target_temp(i); V_get_3(i)=V_get_3(i)/Target_temp(i); end index_up index_down freq_up freq_down % R_get; % V_get; R_get_2 V_get_2 R_get_3 V_get_3 |
2个回答
那个大神可以帮着看下?64行,显示A和B参数不一样,72行显示也有错误
大神在哪里?我在这儿等着你,比较急
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
我用matlab的coder 封装了一个c语言的dll, 但是在用labview调用时,会出现识别不到库的问题,有大神遇到过吗
2673 浏览 0 评论
5246 浏览 0 评论
在matlab中如何计算含有第一类修正的贝塞尔函数的积分算不出的问题?
9043 浏览 0 评论
怎么利用matlab得到95%,80%和70%的置信区间,并生成不同区间下的功率误差贝塔分布?
10485 浏览 0 评论
请问simulink的s-function模块如何添加多输入输出接口
14660 浏览 2 评论
/9
GMT+8, 2025-12-2 22:43 , Processed in 1.188752 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1386
