#include "public.h" #include "Systick.h" #include "led.h" #include "usart.h" #include "inputcapture.h" #include "ADC.h" extern float bohelunzhuansu; //extern u32 timer_times;//定时器溢出次数 //extern u16 BOHELUN_PI_STA; //extern u32 BOHELUN_PI_VAL[2]; int main() { u8 i=0; SysTick_Init(72);//初始化时钟源 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//中断优先级分组 LED_Init(); USART1_Init(9600); TIM3_Cap_Init(1000,71); //定时器周期ARR=1000,时钟频率1MHZ,一个更新中断周期1ms while(1) { printf("转一圈时间 %.2fsrn",bohelunzhuansu); if(i%20==0) { led1=!led1; } delay_ms(500); } } #include "inputcapture.h" //采用定时器5的通道1进行输入捕获 float bohelunzhuansu=0; //int gedaosudu=0; //int jiaolongzhuansu=0; u32 timer_times;//定时器溢出次数 u16 BOHELUN_PI_STA; u32 BOHELUN_PI_VAL; TIM_ICInitTypeDef TIM3_ICInitStructure; void TIM3_Cap_Init(u16 arr,u16 psc) { GPIO_InitTypeDef GPIO_InitStructure; TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; NVIC_InitTypeDef NVIC_InitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //使能定时器3 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //设置端口时钟,对时钟使能,根据原理图可以发现TIM3_CH1对应的是PA6管脚 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //设置端口 + GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //设置GPIO输出模式为上拉输入,这样默认电平是高电平,当传感器接收到信号后变成低电平。||*****************************此处需要根据霍尔传感器的特性决定 GPIO_Init(GPIOA, &GPIO_InitStructure); //初始化 GPIO_ResetBits(GPIOA,GPIO_Pin_6); //既然是上拉输入,那么先把电压置1 // GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; // GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; // GPIO_Init(GPIOB, &GPIO_InitStructure); // GPIO_ResetBits(GPIOB,GPIO_Pin_0); TIM_TimeBaseStructure.TIM_Period = arr; //定时器周期 TIM_TimeBaseStructure.TIM_Prescaler =psc; //分频系数 TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //时钟分频,1分频,没有滤波作用 TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数功能 TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //初始化定时器 //设置TIM3_CH1的输入捕获功能 TIM3_ICInitStructure.TIM_Channel = TIM_Channel_1; //通道1 TIM3_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Falling; //下降沿捕获 TIM3_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //直接映射到TI1,因为根据手册200页的框图,IC1会被映射到TI1和TI2,所以需选择 TIM3_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; //不分频 TIM3_ICInitStructure.TIM_ICFilter = 0x00; //无滤波 TIM_ICInit(TIM3, &TIM3_ICInitStructure); //完成TIM3_CH1初始化配置 // TIM3_ICInitStructure.TIM_Channel = TIM_Channel_2; // TIM3_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; // TIM3_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; // TIM3_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; // TIM3_ICInitStructure.TIM_ICFilter = 0x00; // TIM_ICInit(TIM3, &TIM3_ICInitStructure); // TIM3_ICInitStructure.TIM_Channel = TIM_Channel_3; // TIM3_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising; // TIM3_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; // TIM3_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1; // TIM3_ICInitStructure.TIM_ICFilter = 0x00; // TIM_ICInit(TIM3, &TIM3_ICInitStructure); //NVIC结构体初始化,初始化结构体成员 NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); TIM_ITConfig(TIM3,TIM_IT_Update|TIM_IT_CC1,ENABLE); //开启定时器溢出计数的更新中断和通道1的输入捕获中断,这个根据200页的原理图可以看出,每一个输入捕获寄存器可以对应4个中断通道 TIM_Cmd(TIM3,ENABLE ); //使能定时器 } void TIM3_IRQHandler(void)//测频率,对应3路PI { if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //当更新中断产生,继续下面操作 { TIM_ClearITPendingBit(TIM3, TIM_IT_Update); //清除更新中断标志 timer_times++; //产生更新中断的次数加1 BOHELUN_PI_STA++; //拨禾轮状态参数加1 // GEDAO_PI_STA++; // JIAOLONG_PI_STA++; if(BOHELUN_PI_STA>=2000)//转速太低,小于30r/min //如果拨禾轮在两次下降沿捕获之间的更新中断次数大于200,也就是意味着两次霍尔开关打开的时间过长,那么就可以认为拨禾轮转速为0 { bohelunzhuansu=0; } // if(GEDAO_PI_STA>=200)//转速太低,小于30r/min // { // gedaosudu=0; // } // if(JIAOLONG_PI_STA>=200)//转速太低,小于30r/min // { // jiaolongzhuansu=0; // } } if (TIM_GetITStatus(TIM3, TIM_IT_CC1) != RESET) //如果产生下降沿捕获,那么继续下列操作 { TIM_ClearITPendingBit(TIM3, TIM_IT_CC1); //清空下降沿捕获标志 BOHELUN_PI_STA=0; //清空拨禾轮状态标志 BOHELUN_PI_VAL=timer_times*1000+TIM_GetCounter(TIM3);//计算此次拨禾轮转一圈所需时间,单位us bohelunzhuansu=(BOHELUN_PI_VAL/1000000); //计算出拨禾轮转一圈时间,单位s } // if (TIM_GetITStatus(TIM3, TIM_IT_CC2) != RESET) // { // TIM_ClearITPendingBit(TIM3, TIM_IT_CC2); // GEDAO_PI_STA=0; // GEDAO_PI_VAL[0]=GEDAO_PI_VAL[1]; // GEDAO_PI_VAL[1]=timer_times*10000+TIM_GetCounter(TIM3); // gedaosudu=1000000*60/(GEDAO_PI_VAL[1]-GEDAO_PI_VAL[0]); // } // if (TIM_GetITStatus(TIM3, TIM_IT_CC3) != RESET) // { // TIM_ClearITPendingBit(TIM3, TIM_IT_CC3); // JIAOLONG_PI_STA=0; // JIAOLONG_PI_VAL[0]=JIAOLONG_PI_VAL[1]; // JIAOLONG_PI_VAL[1]=timer_times*10000+TIM_GetCounter(TIM3); // jiaolongzhuansu=1000000*60/(JIAOLONG_PI_VAL[1]-JIAOLONG_PI_VAL[0]); // } } |
相关推荐 |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
494 浏览 0 评论
使用Keil建立完整的工程,并使用外部中断0触发数码管显示903
1050 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-使用AHT20进行环境监测之AHT20传感器介绍
1151 浏览 0 评论
887 浏览 0 评论
928 浏览 1 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
11840 浏览 31 评论
GMT+8, 2024-12-2 06:52 , Processed in 0.514864 second(s), Total 33, Slave 27 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
