公司自己开发的一个产品,基于820核心板做的外围电路,但是上电一直重启
1 ( 楼主 ) 2017-4-7 19:46:25  只看该作者 倒序浏览
公司自己开发的一个产品,基于820核心板做的外围电路,但是上电一直重启,因为有一些电路是参考的别家的开发板电路,(别家开发板一切ok,功能齐全),我们的电路去掉了一些外围功能,列如硬盘、音频电路等。但是调试一起重启,我是做硬件的,软件看不懂。下面是捞出来的log文件,帮忙看看?
[   65.791500] acc_release
[   65.949089] msm_vidc: info: Opening video instance: ffffffc0ef92c000, 0
[   65.959477] subsys-restart: __subsystem_get(): Changing subsys fw_name to venus
[   65.972732] subsys-pil-tz ce0000.qcom,venus: venus: loading from 0x0000000090f00000 to 0x0000000091400000
[   66.045273] subsys-pil-tz ce0000.qcom,venus: venus: Brought out of reset
[   66.077556] msm_vidc: info: Closed video instance: ffffffc0ef92c000
[   66.085720] msm_vidc: info: Opening video instance: ffffffc0f0236000, 0
[   66.097873] msm_vidc: info: Closed video instance: ffffffc0f0236000
[   66.106650] msm_vidc: info: Opening video instance: ffffffc0336fc000, 0
[   66.117541] msm_vidc: info: Closed video instance: ffffffc0336fc000
[   66.125554] msm_vidc: info: Opening video instance: ffffffc033ab6000, 0
[   66.136318] msm_vidc: info: Closed video instance: ffffffc033ab6000
[   66.144043] msm_vidc: info: Opening video instance: ffffffc0eb962000, 0
[   66.154852] msm_vidc: info: Closed video instance: ffffffc0eb962000
[   66.172252] msm_vidc: info: Opening video instance: ffffffc0336fa000, 1
[   66.194049] msm_vidc: info: Closed video instance: ffffffc0336fa000
[   66.207752] msm_vidc: info: Opening video instance: ffffffc0eb962000, 1
[   66.217390] FUSE: SHORTCIRCUIT enabled [sdcard : 1456]!
[   66.217591] FUSE: SHORTCIRCUIT enabled [sdcard : 1458]!
[   66.217713] FUSE: SHORTCIRCUIT enabled [sdcard : 1457]!
[   66.224835] msm_vidc: info: Closed video instance: ffffffc0eb962000
[   66.227606] msm_vidc: info: Opening video instance: ffffffc0729d2000, 1
[   66.235548] msm_vidc: info: Closed video instance: ffffffc0729d2000
[   66.238584] msm_vidc: info: Opening video instance: ffffffc0ed838000, 1
[   66.245985] msm_vidc: info: Closed video instance: ffffffc0ed838000
[   66.248682] msm_vidc: info: Opening video instance: ffffffc0eed9a000, 1
[   66.254790] msm_vidc: info: Closed video instance: ffffffc0eed9a000
[   66.257197] msm_vidc: info: Opening video instance: ffffffc0ef92c000, 1
[   66.264907] msm_vidc: info: Closed video instance: ffffffc0ef92c000
[   66.268111] msm_vidc: info: Opening video instance: ffffffc0ed83c000, 1
[   66.275633] msm_vidc: info: Closed video instance: ffffffc0ed83c000
[   66.278712] msm_vidc: info: Opening video instance: ffffffc0ed864000, 1
[   66.284712] msm_vidc: info: Closed video instance: ffffffc0ed864000
[   66.287536] msm_vidc: info: Opening video instance: ffffffc0ee412000, 1
[   66.295276] msm_vidc: info: Closed video instance: ffffffc0ee412000
[   66.298045] msm_vidc: info: Opening video instance: ffffffc0eb966000, 1
[   66.306725] msm_vidc: info: Closed video instance: ffffffc0eb966000
[   66.309686] msm_vidc: info: Opening video instance: ffffffc0336fc000, 1
[   66.317325] msm_vidc: info: Closed video instance: ffffffc0336fc000
[   66.320094] msm_vidc: info: Opening video instance: ffffffc0eed9c000, 1
[   66.327773] msm_vidc: info: Closed video instance: ffffffc0eed9c000
[   66.330173] msm_vidc: info: Opening video instance: ffffffc0ed864000, 1
[   66.337949] msm_vidc: info: Closed video instance: ffffffc0ed864000
[   66.340881] msm_vidc: info: Opening video instance: ffffffc06f424000, 1
[   66.347418] msm_vidc: info: Closed video instance: ffffffc06f424000
[   66.350412] msm_vidc: info: Opening video instance: ffffffc0ee416000, 1
[   66.363924] msm_vidc: info: Closed video instance: ffffffc0ee416000
[   66.366981] msm_vidc: info: Opening video instance: ffffffc0336fc000, 1
[   66.375895] msm_vidc: info: Closed video instance: ffffffc0336fc000
[   67.220539] msm-dwc3 7600000.hsu***: DWC3 in low power mode
[   67.300452] type=1400 audit(311.519:45): avc: denied { net_admin } for pid=1876 comm="c.wbcserviceapp" capability=12 scontext=u:r:system_app:s0 tcontext=u:r:system_app:s0 tclass=capability permissive=0
[   67.323038] ipa ipa_uc_state_check:296 uC is not loaded
[   67.327515] ipa ipa_sps_irq_control_all:932 EP (5) not allocated.
[   67.335550] ipa ipa_sps_irq_control_all:932 EP (5) not allocated.
[   67.341230] ipa ipa_uc_state_check:296 uC is not loaded
[   67.353476] ipa ipa_uc_state_check:296 uC is not loaded
[   67.358052] ipa ipa_sps_irq_control_all:932 EP (5) not allocated.
[   67.368683] ipa ipa_sps_irq_control_all:932 EP (5) not allocated.
[   67.374239] ipa ipa_uc_state_check:296 uC is not loaded
[   67.747415] init: Service 'per_proxy' is being killed...
[   67.754304] init: Service 'per_proxy' (pid 526) killed by signal 9
[   67.759804] init: Service 'per_proxy' (pid 526) killing any children in process group
[   68.404764] IPA received MPSS BEFORE_SHUTDOWN
[   68.408705] ipa ipa_uc_state_check:296 uC is not loaded
[   68.413369] ipa ipa_sps_irq_control_all:932 EP (5) not allocated.
[   68.426074] rmnet_ipa started deinitialization
[   68.429496] ipa ipa2_teardown_sys_pipe:1413 bad parm.
[   68.435342] ipa-wan ipa_wwan_remove:2103 Failed to teardown IPA->APPS pipe
[   68.441807] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister rmnet_ipa0
[   68.490135] [RMNET:HI] rmnet_config_notify_cb(): Kernel is trying to unregister rmnet_ipa0
[   68.499195] ipa-wan ipa_del_dflt_wan_rt_tables:377 Deleting Route hdl:(0x9) with ip type: 0
[   68.507888] ipa-wan ipa_del_dflt_wan_rt_tables:386 Deleting Route hdl:(0xb) with ip type: 1
[   68.518966] rmnet_ipa completed deinitialization
[   68.523516] IPA BEFORE_SHUTDOWN handling is complete
[   68.627880] pil-q6v5-mss 2080000.qcom,mss: Port ffffff80020f4000 halt timeout
[   68.734068] pil-q6v5-mss 2080000.qcom,mss: Port ffffff80020f6000 halt timeout
[   68.744329] IPA received MPSS AFTER_SHUTDOWN
[   68.748042] ipa ipa_q6_post_shutdown_cleanup:2019 uC is not loaded, won't reset Q6 pipes
[   68.755744] IPA AFTER_SHUTDOWN handling is complete
[   68.760717] smem:mpss glink_open: Error 0 - unable to find transport
[   68.767464] smem:mpss:LOOPBACK_CTL_APSS glink_lbsrv_open_worker: unable to open channel
[   69.411206] mdss_fb_release_all: try to close unopened fb 2! from pid:1 name:init
[   69.417682] mdss_fb_release_all: try to close unopened fb 1! from pid:1 name:init
[   69.786339] mdss_dsi_panel_reset:321, IC6211_en_gpio line not configured
[   69.793805] reboot: Power down
[   69.795832] Powering off the SoC
[   69.799672] qcom,qpnp-power-on qpnp-power-on-ffffffc0f8450c00: PMIC@SID2: configuring PON for res▒
Format: Log Type - Time(microsec) - Message - Optional Info
Log Type: B - Since Boot(Power On Reset),  D - Delta,  S - Statistic
S - QC_IMAGE_VERSION_STRING=BOOT.XF.1.0-00298
0个回复
您需要登录后才可以回帖 登录 | 注册
本版积分规则
关闭
站长推荐上一条 /6 下一条
小黑屋|手机版|Archiver|电子发烧友 ( 湘ICP备2023018690号 )
GMT+8, 2024-4-25 02:35 , Processed in 0.539572 second(s), Total 67, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
微信扫描
快速回复 返回顶部 返回列表
