emWin任务的具体实现(在MainTask.c文件里面):
#include "MainTask.h"
#include "includes.h"
* 宏定义
#define ID_FRAMEWIN_0 (GUI_ID_USER + 0x00)
#define ID_EDIT_0 (GUI_ID_USER + 0x01)
#define ID_EDIT_1 (GUI_ID_USER + 0x02)
* GUI_WIDGET_CREATE_INFO类型数组
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
{ FRAMEWIN_CreateIndirect, "Framewin", ID_FRAMEWIN_0, 0, 0, 800, 480, 0, 0x64, 0 },
{ EDIT_CreateIndirect, "Edit", ID_EDIT_0, 38, 49, 81, 27, 0, 0x64, 0 },
{ EDIT_CreateIndirect, "Edit", ID_EDIT_1, 41, 105, 79, 27, 0, 0x64, 0 },
* 函 数 名: _cbDialog
* 功能说明: 对话框回调函数
* 形 参: pMsg 回调参数
* 返 回 值: 无
static void _cbDialog(WM_MESSAGE * pMsg)
WM_HWIN hItem;
int NCode;
int Id;
switch (pMsg->MsgId)
case WM_INIT_DIALOG:
// 初始化框架窗口
hItem = pMsg->hWin;
FRAMEWIN_SetFont(hItem, GUI_FONT_32B_ASCII);
FRAMEWIN_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
FRAMEWIN_SetText(hItem, "armfly");
// 初始化编辑框
hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_0);
EDIT_SetText(hItem, "1024");
EDIT_SetFont(hItem, GUI_FONT_24B_ASCII);
// 初始化编辑框
hItem = WM_GetDialogItem(pMsg->hWin, ID_EDIT_1);
EDIT_SetText(hItem, "ARM");
break;
case WM_NOTIFY_PARENT:
Id = WM_GetId(pMsg->hWinSrc);
NCode = pMsg->Data.v;
switch(Id)
case ID_EDIT_0:
switch(NCode)
case WM_NOTIFICATION_CLICKED:
break;
case WM_NOTIFICATION_RELEASED:
break;
case WM_NOTIFICATION_VALUE_CHANGED:
break;
break;
case ID_EDIT_1:
switch(NCode)
break;
break;
break;
break;
break;
default:
WM_DefaultProc(pMsg);
break;
* 函 数 名: CreateFramewin
* 功能说明: 创建对话框
* 形 参: 无
* 返 回 值: 返回对话框句柄
WM_HWIN CreateFramewin(void)
WM_HWIN hWin;
hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
return hWin;
* 函 数 名: MainTask
* 功能说明: GUI主函数
* 形 参: 无
* 返 回 值: 无
void MainTask(void)
/* 初始化 */
GUI_Init();
关于多缓冲和窗口内存设备的设置说明
1. 使能多缓冲是调用的如下函数,用户要在LCDConf_Lin_Template.c文件中配置了多缓冲,调用此函数才有效:
WM_MULTIBUF_Enable(1);
2. 窗口使能使用内存设备是调用函数:WM_SetCreateFlags(WM_CF_MEMDEV);
3. 如果emWin的配置多缓冲和窗口内存设备都支持,二选一即可,且务必优先选择使用多缓冲,实际使用
STM32F429BIT6 + 32位SDRAM + RGB565/RGB888平台测试,多缓冲可以有效的降低窗口移动或者滑动时的撕裂
感,并有效的提高流畅性,通过使能窗口使用内存设备是做不到的。
4. 所有emWin例子默认是开启三缓冲。
触摸校准函数默认是注释掉的,电阻屏需要校准,电容屏无需校准。如果用户需要校准电阻屏的话,执行
此函数即可,会将触摸校准参数保存到EEPROM里面,以后系统上电会自动从EEPROM里面加载。
//TOUCH_Calibration();
/* 创建对话框 */
CreateFramewin();
while(1)
GUI_Delay(10);
