LZ近期想做一个TCS230颜色传感器的测试,因为代码基础薄弱,所以想利用labview做自动检测系统。时间较为紧迫,学习2周赶鸭子上架,目前遇到问题了。就是visa read buffer与数组、簇之间的传输吧。如图
我想知道中间部分该怎么连线啊?用了很多图标测试,都连不对。我的arduino程序是打开串口后,先进行白平衡再不断输出RGB值的。 附上RGB检测例程: #include <timerOne.h> #define S0 6 #define S1 5 #define S2 4 #define S3 3 #define OUT 2 int g_count = 0; int g_array[3]; int g_flag = 0; float g_SF[3]; void TSC_Init() { pinMode(S0, OUTPUT); pinMode(S1, OUTPUT); pinMode(S2, OUTPUT); pinMode(S3, OUTPUT); pinMode(OUT, INPUT); digitalWrite(S0, LOW); digitalWrite(S1, HIGH); } // Select the filter color void TSC_FilterColor(int Level01, int Level02) { if(Level01 != 0) Level01 = HIGH; if(Level02 != 0) Level02 = HIGH; digitalWrite(S2, Level01); digitalWrite(S3, Level02); } void TSC_Count(){ g_count ++ ; } void TSC_Callback() { switch(g_flag) { case 0: Serial.println("->WB Start"); TSC_WB(LOW, LOW); break; case 1: Serial.print("->Frequency R="); Serial.println(g_count); g_array[0] = g_count; TSC_WB(HIGH, HIGH); break; case 2: Serial.print("->Frequency G="); Serial.println(g_count); g_array[1] = g_count; TSC_WB(LOW, HIGH); break; case 3: Serial.print("->Frequency B="); Serial.println(g_count); Serial.println("->WB End"); g_array[2] = g_count; TSC_WB(HIGH, LOW); break; default: g_count = 0; break; }} void TSC_WB(int Level0, int Level1) { g_count = 0; g_flag ++; TSC_FilterColor(Level0, Level1); Timer1.setPeriod(1000000); } void setup() { TSC_Init(); Serial.begin(9600); Timer1.initialize(); Timer1.attachInterrupt(TSC_Callback); attachInterrupt(0, TSC_Count, RISING); delay(4000); for(int i=0; i<3; i++) Serial.println(g_array[i]); g_SF[0] = 255.0/ g_array[0]; //R Scale factor g_SF[1] = 255.0/ g_array[1] ; //G Scale factor g_SF[2] = 255.0/ g_array[2] ; //B Scale factor Serial.println(g_SF[0]); Serial.println(g_SF[1]); Serial.println(g_SF[2]); } void loop() { g_flag = 0; for(int i=0; i<3; i++) Serial.println(int(g_array[i] * g_SF[i])); delay(4000); } 这一段是例程,打开串口后先进行白平衡。 而这一段例程该怎么配合我的labview改呢?求各位高手不吝赐教。 问题总结: 1:labview的串口通信编程,用什么框图连接? 2:arduino程序的优化
3个回答
自己顶一下,不要沉了
已经找到突破口 完成后再上传上来
240 浏览 0 评论
303 浏览 1 评论
663 浏览 6 评论
1196 浏览 2 评论
2160 浏览 3 评论
GMT+8, 2024-9-30 15:54 , Processed in 0.529871 second(s), Total 78, Slave 59 queries .
