我是用vhdl做的一个简单的两位数的加减乘除运算,输入的两个数只能是0-15,就算的结果是0-225,整个程序是没错的,可是总是在连线后,用数码管分别显示输入的两个数和计算的结果时,输入的两个数的十位总是显示0,其他的显示都是对的,求大神帮我看看,万分感谢!!!
模块一:计算模块 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity jisuanqi is Port (num1,num2: in integer range 0 to 15; sel: in STD_LOGIC_VECTOR (1 downto 0); y: out integer range 0 to 225); end jisuanqi; architecture rtl of jisuanqi is signal q1 ,q2: integer range 0 to 15; signal choice: STD_LOGIC_VECTOR (1 downto 0); signal result: integer range 0 to 225; begin choice<=sel; process(q1,q2,result,choice) begin case choice is when "00" => result<=q1+q2; when "01" => if(q1>q2)then result <= q1-q2; else result<=q2-q1; end if; when "10"=> result<=q1*q2; when "11"=> result<=0; end case; end process; q1<=num1; q2<=num2; y <= result; end rtl; 模块二:分为模块,将每个数字的位分离出来 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity fenwei is Port (q1,q2: in integer range 0 to 15; y :in integer range 0 to 225; result_bai: out integer range 0 to 2; result_shi: out integer range 0 to 9; result_ge : out integer range 0 to 9; q1_shi,q2_shi:out integer range 0 to 1; q1_ge,q2_ge: out integer range 0 to 9); end fenwei; architecture a of fenwei is --signal num1,num2:integer range 0 to 15; --signal num1_shi ,num2_shi: integer range 0 to 1; --signal num1_ge,num2_ge: integer range 0 to 9; signal y_bai :integer range 0 to 2; signal y_shi,y_ge :integer range 0 to 9; signal temp :integer range 0 to 99; --中间变量 signal result: integer range 0 to 225 ; begin --num1<=q1;----- --num2<=q2;----- result<=y; q1_shi <= 1 WHEN q1>9 ELSE 0 ; q1_ge <= q1-10 WHEN q1>9 ELSE q1 ; q2_shi <= 1 WHEN q2>9 ELSE 0 ; q2_ge <= q2-10 WHEN q2>9 ELSE q2 ; y_bai <=2 WHEN result>199 else 1 when result>99 else 0; temp <= result-200 WHEN result>199 ELSE result-100 WHEN result>99 ELSE result; y_shi<= 9 WHEN temp>89 ELSE 8 WHEN temp>79 ELSE 7 WHEN temp>69 ELSE 6 WHEN temp>59 ELSE 5 WHEN temp>49 ELSE 4 WHEN temp>39 ELSE 3 WHEN temp>29 ELSE 2 WHEN temp>19 ELSE 1 WHEN temp>9 ELSE 0 ; y_ge<= temp-90 WHEN temp>89 ELSE temp-80 WHEN temp>79 ELSE temp-70 WHEN temp>69 ELSE temp-60 WHEN temp>59 ELSE temp-50 WHEN temp>49 ELSE temp-40 WHEN temp>39 ELSE temp-30 WHEN temp>29 ELSE temp-20 WHEN temp>19 ELSE temp-10 WHEN temp>9 ELSE temp ; --q1_shi<=num1_shi; --q1_ge<=num1_ge; --q2_shi<=num2_shi; --q2_ge<=num2_ge; result_bai<=y_bai; result_shi<=y_shi; result_ge<=y_ge; end a; 显示模块: LIBRARY IEEE; USE IEEE.Std_Logic_1164.ALL; USE IEEE.Std_Logic_Arith.ALL; USE IEEE.Std_Logic_Unsigned.ALL; ENTITY xianshi IS PORT ( result_bai: in integer range 0 to 2; result_shi,result_ge,q1_ge,q2_ge:in integer range 0 to 9; q1_shi,q2_shi:in integer range 0 to 1; clk : IN STD_LOGIC; led7: OUT STD_LOGIC_vector(7 downto 0); sel_out: out STD_LOGIC_vector(6 downto 0) ); END ; ARCHITECTURE b OF xianshi IS SIGNAL led0,led2: integer range 0 to 1; signal led1,led3,led5,led6:integer range 0 to 9; signal led4:integer range 0 to 2; SIGNAL output : integer range 0 to 9; BEGIN led0<=q1_shi; led1<=q1_ge; led2<=q2_shi; led3<=q2_ge; led4<=result_bai; led5<=result_shi; led6<=result_ge; scan: PROCESS (clk) VARIABLE count: integer range 0 to 6; BEGIN if (rising_edge(clk)) then CASE count IS WHEN 0 => output<=led6; sel_out<="1111110"; count:=1; WHEN 1 => output<=led5; sel_out<="1111101"; count:=2; WHEN 2 => output<=led4; sel_out<="1111011"; count:=3; WHEN 3 => output<=led3; sel_out<="1110111"; count:=4; WHEN 4 => output<=led2; sel_out<="1101111"; count:=5; WHEN 5 => output<=led1; sel_out<="1011111"; count:=6; WHEN 6 => output<=led0; sel_out<="0111111"; count:=0; END CASE; end if; END PROCESS scan; WITH output SELECT led7 <= "00111111" WHEN 0, "00000110" WHEN 1, "01011011" WHEN 2, "01001111" WHEN 3, "01100110" WHEN 4, "01101101" WHEN 5, "01111101" WHEN 6, "00000111" WHEN 7, "01111111" WHEN 8, "01101111" WHEN 9, "10000000" WHEN OTHERS; END b;
5个回答
....哪里出问题了看哪部分代码...(吐槽 三点..1.养成多些注释的习惯.这样保证自己的思路清晰,方便检查.2.你的除法何在3.标志符最好用英文..拼音什么的很不舒服)还有你得给出尼的输入阿..输出是数码管显示.你的输入是用的按键还是拨盘 还是其他...
还有你的标志符 最好不要和专用词 重名
然后你的端口是否连接正确
谢谢分享
路过~正在做MUX8_1
1257 浏览 0 评论
2019 浏览 0 评论
7769 浏览 0 评论
写了一个用DMA读取ADC数据的程序,记录下整个过程和一点心得
3149 浏览 0 评论
3421 浏览 0 评论
1207浏览 0评论
GMT+8, 2024-9-1 01:22 , Processed in 0.680243 second(s), Total 89, Slave 68 queries .
