DISPBUF EQU 5AH SecCoun EQU 59H SpCoun EQU 57H ? Count EQU 56H SpCalc bit 00h Hidden EQU 16 ORG 0000H AJMP START ORG 1BH JMP tiMER1 ORG 30H START: MOV SP,#5FH MOV P1,#0FFH MOV P0,#0FFH MOV P2,#0FFH MOV TMOD,#00010101B MOV TH1,#HIGH(65536-5000) MOV TL1,#LOW(65536-5000) SETB TR1 SETB ET1 SETB EA LOOP:JNB SpCalc ,LOOP MOV R2,SpCoun MOV R3,SpCoun+1 MOV R6,#0 MOV R7,#60 call MULD MULD: MOV A,R3 MOV B,R7 MUL AB MOV R4,B MOV R5,A MOV A,R3 MOV B,R6 MUL AB ADD A,R4 MOV R4,A CLR A ADDC A,B MOV R3,A MOV A,R2 MOV B,R7 MUL AB ADD A,R4 MOV R4,A MOV A,R3 ADDC A,B MOV R3,A CLR A RLC A XCH A,R2 MOV B,R6 MUL AB ADD A,R3 MOV R3,A MOV A,R2 ADDC A,B MOV R2,A RET MOV A,R4 MOV R6,A MOV A,R5 MOV R7,A CALL HB2 HB2: CLR A MOV R3,A MOV R4,A MOV R5,A MOV R2,#10H HB3: MOV A,R7 RLC A MOV R7,A MOV A,R6 RLC A MOV R6,A MOV A,R5 ADDC A,R5 DA A MOV R5,A MOV A,R4 ADDC A,R4 DA A MOV R4,A MOV A,R3 ADDC A,R3 MOV R3,A DJNZ R2,HB2 RET CBCD: MOV DISPBUF,R3 MOV A,R4 ; ANL A,#0F0H SWAP A MOV DISPBUF+1,A MOV A,R4 ANL A,#0FH MOV DISPBUF+2,A MOV A,R5 ANL A,#0F0H SWAP A MOV DISPBUF+3,A MOV A,R5 ANL A,#0FH MOV DISPBUF+4,A CLR SpCalc JMP LOOP TIMER1: PUSH ACC PUSH PSW SETB RS0 JNB TR0,SETTR0 JMP GO1 SETTR0: SETB TR0 GO1: INC SecCoun MOV A,SecCoun CJNE A,#251,Go2 CLR TR0 MOV SpCoun,TH0 MOV SpCoun+1,TL0 CLR A MOV TH0,A MOV TL0,A SETB SpCalc MOV SecCoun,#0 Go2: INC COUNT MOV A,COUNT CLR C SUBB A,#6 JZ N1 JMP N2 N1: MOV COUNT,#0 N2: MOV A,#DISPBUF ADD A,COUNT MOV R0,A MOV A,@R0 MOV DPTR,#DISPTAB MOVC A,@A+DPTR MOV P0,A MOV A,COUNT MOV DPTR,#BitTab MOVC A,@A+DPTR ORL P2,#11110000B ANL P2,A MOV TH1,#HIGH(65536-5000) MOV TL1,#LOW(65536-5000) POP PSW POP ACC SETB RS0 RETI BitTab: DB 07Fh,0BFH,0DFH,0EFH,0F7H,0FBH DISPTAB:DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H END
8个回答
{:1:}
第一次上论坛。发帖。谢谢你的提醒 |
看得有点花
汇编的不懂,C的我倒是有
使用Keil建立完整的工程,并使用外部中断0触发数码管显示903
418 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-使用AHT20进行环境监测之AHT20传感器介绍
1083 浏览 0 评论
846 浏览 0 评论
886 浏览 1 评论
基于瑞萨FPB-RA4E2智能床头灯项目——1编译环境搭建与点亮驱动ws2812全彩LED
882 浏览 0 评论
11832 浏览 31 评论
GMT+8, 2024-12-1 01:21 , Processed in 0.702110 second(s), Total 90, Slave 70 queries .
