Hi3861也提供了相关得GPIO口操作
先看最简单得LED灯闪烁操作
源码结构如下:
BUILD.gn文件内容:
- static_library("led_demo") {
- sources = [
- "led_demo.c"
- include_dirs = [
- "//utils/native/lite/include",
- "//kernel/liteos_m/components/cmsis/2.0",
- "//base/iot_hardware/interfaces/kits/wifiiot_lite"
复制代码
led_demo.c内容:
- #include <unistd.h>
- #include "stdio.h"
- #include "ohos_init.h"
- #include "cmsis_os2.h"
- #include "wifiiot_gpio.h"
- #include "wifiiot_gpio_ex.h"
- #include <hi_types_base.h>
- #include <hi_i2c.h>
- #include <hi_early_debug.h>
- #include <hi_stdlib.h>
- void *LedTask(const char *arg)
- (void)arg;
- while (1)
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 0);
- usleep(300000);
- GpioSetOutputVal(WIFI_IOT_IO_NAME_GPIO_9, 1);
- usleep(300000);
- return NULL;
- void led_demo(void)
- //osThreadAttr_t attr;
- GpioInit();
- //复用引脚为 GPIO
- IoSetFunc(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_IO_FUNC_GPIO_9_GPIO);
- //设置为输出
- GpioSetDir(WIFI_IOT_IO_NAME_GPIO_9, WIFI_IOT_GPIO_DIR_OUT);
- attr.name = "LedTask";
- attr.attr_bits = 0U;
- attr.cb_mem = NULL;
- attr.cb_size = 0U;
- attr.stack_mem = NULL;
- attr.stack_size = 512;
- attr.priority = 26;
- if (osThreadNew((osThreadFunc_t)LedTask, NULL, &attr) == NULL) {
- printf("[LedExample] Falied to create LedTask!n");
- //SYS_RUN(led_demo);
- void oled_test(void)
- SYS_RUN(oled_test);
复制代码
另外GPIO口还可以作为输入,然后使用中断,示例代码如下:
这段示例代码用的开发板上面的user按键。
通过查阅原理图,我们可以看到Hi3861在type-C口附近有一个user按钮,如图,主要不要和复位按钮搞错了。user按钮对应的是GPIO5引脚。
- /* gpio callback func */
- hi_void my_gpio_isr_func(hi_void *arg)
- hi_unref_param(arg);
- printf("----- gpio isr success -----rn");
- /* 设置 按键中断响应 */
- hi_void my_gpio_isr_demo(hi_void)
- hi_u32 ret;
- printf("----- gpio isr demo -----rn");
- (hi_void)hi_gpio_init();
- hi_io_set_func(HI_IO_NAME_GPIO_5, HI_IO_FUNC_GPIO_5_GPIO); /* uart1 rx */
- ret = hi_gpio_set_dir(HI_GPIO_IDX_5, HI_GPIO_DIR_IN);
- if (ret != HI_ERR_SUCCESS) {
- printf("===== ERROR ======gpio -> hi_gpio_set_dir1 ret:%drn", ret);
- return;
- ret = hi_gpio_register_isr_function(HI_GPIO_IDX_5, HI_INT_TYPE_EDGE,
- HI_GPIO_EDGE_RISE_LEVEL_HIGH, my_gpio_isr_func, HI_NULL);
- printf("===== ERROR ======gpio -> hi_gpio_register_isr_function ret:%drn", ret);
复制代码
