大家好,我的名字叫汤姆。
我是达勒姆大学(英国)的工程系学生。 我被分配了一个涉及Vee Pro 6.0的最后一年项目。 基本上,之前的博士项目创建了一个测试装置,使用Vee Pro程序控制的气动装置,使人造脚趾关节受到重力和运动。 博士生已经离开并且无法接受,因此我被赋予了尝试计算该计划如何运作以改进它的任务。 问题是,我在编程方面缺乏经验。 我对C编程有一些经验,但就是这样,所以Vee程序正在我的头脑中(更糟糕的是,由于某种原因,帮助文件不可用)。 我想,不过要问具体的问题,我会先问一下,如果有人可以指导我一个新手友好的教程或类似的补充我下载的完整手册pdf? 如果这篇文章在错误的部分,我很抱歉,但我真的不知道它会被视为什么。 非常感谢你的帮助,汤姆_____认为你知道你的电视,音乐和电影吗? HYPERLINK“https://www.searchcharades.com”尝试搜索字典!---您目前订阅了vrf:ming_meng@agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent .com“在邮件正文中使用了subscribe这个词。 要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“http://www.vrfarchive.com/vrf_archive”上搜索“unofficial vrf archive”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 Hi Everyone, My Name's Tom. I'm an engineering student at Durham University (in the UK). I have been assigned a final year project involving Vee Pro 6.0. Basically a previous PhD project created a testing rig to subject artificial toe joints to relistic forces and movements, using pneumatics controlled by a Vee Pro program. The PhD student has since departed and is uncontactable, so I have been assigned the task of attempting to work out how the program works in order to improve it. The problem is, I am vastly inexperienced in programming in general. I have a bit of experience with C programming but that's it, so the Vee program is going way over my head (and to make matters worse, the help files are unavailable for some reason). I thought that rather than asking specific questions, I would first ask in case someone could direct me to a newbie-friendly tutorial or similar to supplement the full manual pdf I downloaded? Apologies if this post is in the wrong section, but I really don't know what it would count as. Many thanks in advance for your help, Tom _____ Think you know your TV, music and film? HYPERLINK "https://www.searchcharades.com"Try Search Charades! --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
>博士生已离开>并且无法接受,所以我已经被分配了尝试>计算程序如何工作的任务>以便改进它。恭喜!
您已经接触过真实场景。 我无法计算我听过的次数“我们无法联系作者......”: - 0>问题是,我对编程工作总体上缺乏经验。你很幸运 - VEE 目标工程师,不一定是程序员。>我会先问一下,有人>可以指导我一个新手友好的>教程或类似补充>我下载的完整手册pdf?Welp,我有一个适度的VEE集合 - http://www.vrfarchive.com/vrf_archive/VEELinks.htm上的面向网络产品当您有特定问题时,您可以在http://www.vrfarchive.com/vrf_archive/SearchVRF.htm找到答案。 打算一起得到一个FAQ,但从来没有。 我想有人可能会有这种性质的东西。 其中一些条目可能包括:Q。 我可以使用PC并行端口进行数据采集吗? 是的,但你需要其他软件。 有一些不同的解决方案,但我最喜欢的是inpout:http://logix4u.net/Q。 我可以在公式中使用名为“xyzzy”的变量吗? 不,但如果你超过40岁,那么这种尝试可能会很有趣。 我可以用PC来更换仪器吗? 是的,但要准备接受*严格的*限制& 不要指望来自Windows.Q的准确计时。 用户功能和用户功能之间的区别是什么? 用户对象? 用户功能是被调用的对象集合的一个副本。 用户对象是每个使用对象的对象副本的集合。 用户功能类似于C或Pascal功能,用户对象类似于宏。 亲切的.Q。 我必须声明变量吗? 不,但这样做有一定的好处。 另外,为了使用ActiveX Events,必须声明对象变量.Q。 VEE可以使用其他语言的库吗? 明确地。 在二进制级别,VEE几乎可以调用任何C API,包括几乎所有的Windows API以及为Win32编译的数千个其他库。 VEE也是一个ActiveX容器,可以使用大多数ActiveX控件和 自动化库。 VEE也支持.NET。 VEE是否支持远程过程调用? 是。 显然,VEE使用它自己的远程api,称为veeRPC,它也包含在ActiveX中作为CallVEE库(现在也可能是.NETable - 我还没有检查过一段时间)。 隐式地,VEE可以调用任何远程服务器ActiveX或.NET控件或库.Q。 如何让VEE发布Excel?删除所有包含Excel引用的变量& 关闭调试功能。 如果您使用的是Excel 97,请调用TerminateProcess。 您可以使用KillExcel.vee或pskill.exe或其他任何方式。 调用TerminateProcess是不是很糟糕? 是的S! 只有你尝试过其他所有事情才能做到这一点。 停止一个过程绝对是非常关键的*。 这就是FAQ的全部内容吗? 是。 这是晚了& 我仍然有工作要做。-SHAWN ----您目前订阅了vrf:ming_meng@agilent.com要订阅,请发送电子邮件至:“vrf-request@lists.it.agilent.com” 订阅邮件正文。要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“http://www.vrfarchive.com/vrf_archive”上搜索“非官方vrf档案”。 在“http://vee.engineering.agilent.com”上搜索Agilent vrf存档。 以上来自于谷歌翻译 以下为原文 > The PhD student has since departed > and is uncontactable, so I have > been assigned the task of attempting > to work out how the program works > in order to improve it. Congratulations! You're already being exposed to a real-world scenario. I can't count the number of times I've heard "we can't contact the author..." :-0 > The problem is, I am vastly > inexperienced in programming in general. You're in luck - VEE targets Engineers, not necessarily programmers. > I would first ask in case someone > could direct me to a newbie-friendly > tutorial or similar to supplement > the full manual pdf I downloaded? Welp, I've got a modest collection of VEE-oriented web offerings at http://www.vrfarchive.com/vrf_archive/VEELinks.htm When you do have specific questions, you can look for the answers at http://www.vrfarchive.com/vrf_archive/SearchVRF.htm I've always intended to get a FAQ together, but never have. I suppose somebody might have something of that nature. Some of it's entries might include: Q. Can I use the PC parallel port for data acquisition? A. Yes, but you need other software. There are a few different solutions but my favorite is inpout: http://logix4u.net/ Q. Can I use a variable named "xyzzy" in a formula? A. No, but the attempt can be entertaining if you're over 40. Q. Can I use a PC to replace instrumentation? A. Yes, but be prepared to accept *stringent* limitations & don't expect accurate timing from Windows. Q. What's the difference between a User Function & User Object? A. A User Function is one copy of a collection of objects that's called. A User Object is a collection of a copy of objects every where it's used. A User Function is analogous to a C or Pascal Function, a User Object is analogous to a macro. Kind of. Q. Do I have to declare variables? A. No, but there are certain advantages to doing so. Also, in order to use ActiveX Events object variables must be declared. Q. Can VEE use libraries from other languages? A. Most definitely. At the binary level, VEE can call nearly any C API including almost all of the Windows API as well as thousands of other libraries compiled for Win32. VEE is also an ActiveX container and can use most ActiveX controls & Automation libraries. VEE supports .NET too. Q. Does VEE support Remote Procedure Call? A. Yes. Explicitly, VEE uses it's own remote api known as veeRPC which is also wrapped in ActiveX as the CallVEE library (this is probably also .NETable now too - I haven't checked in a while). Implicitly, VEE can call any remote server ActiveX or .NET control or library. Q. How do I get VEE to release Excel? Delete all variables that hold Excel references & turn off debugging features. If you're using Excel 97, call TerminateProcess. You can use KillExcel.vee or pskill.exe or any of a number of other ways. Q. Is it bad to call TerminateProcess? A. Y E S! Only do this if you've tried everything else & it's absolutely, vitally *critical* to stop a process. Q. Is this all there is to the FAQ? A. Yes. It's late & I still have work to do. -SHAWN- --- You are currently subscribed to vrf as: ming_meng@agilent.com To subscribe please send an email to: "vrf-request@lists.it.agilent.com" with the word subscribe in the message body. To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "http://www.vrfarchive.com/vrf_archive". Search the Agilent vrf archive at "http://vee.engineering.agilent.com". |
2097 浏览 1 评论
1854 浏览 1 评论
1713 浏览 5 评论
2579 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1559 浏览 4 评论
502浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
363浏览 0评论
1411浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
272浏览 0评论
2258浏览 0评论
GMT+8, 2024-4-25 06:49 , Processed in 1.007173 second(s), Total 73, Slave 57 queries .
