【MYS-6ULX-IOT试用体验】在MYS-6ULX开发板上安装ssh和sftp - 问答 - 电子技术论坛 - 最好最受欢迎电子论坛!
刘 刚 ( 楼主 ) 2017-6-15 15:23:51  只看该作者 倒序浏览
开发板上没有ssh, 为了方便开发,编译安装Openssh到开发板
编译器
  • linaro.tar.xz
源码
编译
默认全部安装到/home/install目录
编译zlib
$ CC=arm-linux-gnueabihf-gcc AR=arm-linux-gnueabihf-ar LDSHARED=arm-linux-gnueabihf-gcc ./configure --prefix=/home/install/zlib
$ make
$ make install
编译openssl
$ ./Configure --prefix=/home/install/openssl os/compiler:arm-linux-gnueabihf-gcc
$ make
$ make install
编译openssh
$ ./configure --host=arm-linux-gnueabihf --with-libs --with-zlib=/home/install/zlib --with-ssl-dir=/home/install/openssl --disable-etc-default-login
$ make
安装到开发板
建立目录
确保目标板上有以下目录,若没有,则新建:
/usr/local/bin
/usr/local/etc
/usr/libexec
/var/run
/var/empty
复制文件
scp、sftp、ssh sshd、ssh-add、ssh-agent、ssh-keygen、ssh-keyscan共8个文件拷贝到目标板/usr/local/bin
moduli、ssh_config、sshd_config共3个文件拷贝到目标板 /usr/local/etc
sftp-server、ssh-keysign 共2个文件拷贝到目标板 /usr/libexec
修改/etc/passwd
打开 /etc/passwd 文件,在最后添加下面这一行:
sshd:x:74:74:Privilege-separated SSH:/var/empty/sshd:/***in/nologin
如果开发板的 root 用户还没有密码,键入以下命令然输入两次密码来修改,否其他设备无法连接
$ passwd root
sshd 自启动建立启动脚本
$ vi /etc/init.d/sshd.sh
  1. #!/bin/sh
  2. if [ ! -x /usr/local/bin/sshd ]
  3. then
  4.     exit 0
  5. fi
  6. if [ "$1" = "stop" -o "$1" = "restart" ]
  7. then
  8.     echo "Stopping the ssh server: "
  9.     killall sshd
  10. fi
  11. if [ "$1" = "start" -o "$1" = "restart" ]
  12. then
  13.     # assume if one key is missing, all are
  14.     if [ ! -f /usr/local/etc/ssh_host_rsa_key ]
  15.     then
  16.         echo "Generating keys for the ssh server: "
  17.         /usr/local/bin/ssh-keygen -t rsa -f /usr/local/etc/ssh_host_rsa_key -N ""
  18.         /usr/local/bin/ssh-keygen -t dsa -f /usr/local/etc/ssh_host_dsa_key -N ""
  19.         /usr/local/bin/ssh-keygen -t ecdsa -f /usr/local/etc/ssh_host_ecdsa_key -N ""
  20.         /usr/local/bin/ssh-keygen -t dsa -f /usr/local/etc/ssh_host_ed25519_key -N ""
  21.     fi
  22.     for i in ssh_host_rsa_key ssh_host_dsa_key ssh_host_ecdsa_key ssh_host_ed25519_key
  23.     do
  24.         chmod 600 /usr/local/etc/$i
  25.     done
  26.     #echo "Starting the ssh server:"
  27.     /usr/local/bin/sshd
  28. fi
复制代码
添加执行权限
$ chmod +x sshd.sh
建立软链接
$ ln -s /etc/rcS.d/S60sshd.sh /etc/init.d/sshd.sh
到此重启后就可以甩掉串口线,用ssh登陆开发板了
sftp
$ vi /usr/local/etc/sshd_config
修改包含sftp行
Subsystem sftp /usr/libexec/sftp-server
到此重启后就可以用sftp和开发板传输文件了
4个回复
260539160 发表于 2017-6-16 12:07:18
评测还是可以的,但是对于很多初学者可能还是很难理解和看懂,希望可以发布一个详细一点的评测
刘 刚 发表于 2017-6-16 14:26:00
附上编译完的文件,不想编译的可以复制到开发板上直接使用
install.zip
6.39 MB, 下载次数: 9, 下载积分: 积分 -1 分
复制到开发板
没事,新手慢慢来嘛,没有SSH的话,你上篇文章里面要用SCP传播东西是不行的。
杰杰 发表于 2018-5-8 15:50:44
看看学习学习{:12:}{:12:}{:12:}
站长推荐上一条 /6 下一条
GMT+8, 2024-11-29 21:48 , Processed in 1.066359 second(s), Total 77, Slave 53 queries .
