发 帖
ST NUCLEO-L476ZG开发板免费试用
STM32L4产品兼备高性能处理器的优异性能和超低功耗技术的能效,具有其它超低功耗微控制器没有的功能。了解更多>>
价值:¥100元提供:8 已申请:40
剩余时间:
分享
  • 试用详情
  • 试用名单
  • 试用报告
  • 讨论区
STM32L4微控制器介绍
STM32L4产品兼备高性能处理器的优异性能和超低功耗技术的能效,具有其它超低功耗微控制器没有的功能。273分的EEMBC®[1] CoreMark®测试成绩高于其它超低功耗处理器内核,同时217分的ULPBench测试成绩证明新微控制器的能效更高。37µA/MHz的工作电流有助于延长小电池的续航时间,扩大以环境能源为动力的零能耗产品的范围。
意法半导体还提高了STM32L4功率架构的灵活性,让设计人员能够选择用外部直流/直流转换器供给处理器内核,以进一步提升能效。STM32L4 FlexPowerControl架构新增一个关断模式,提供多个独立的内核电源、外设电源和一个独立的有充电电路的VBAT电压域,根据情况选择使用电池供电还是给电池充电。STM32L4支持七种主要低功耗模式,有I/O电平保持和SRAM内容保留等选项,每种功耗模式还细分成多个子模式,根据具体应用需求精准调节功耗。
The STM32L476xx devices are the ultra-low-power microcontrollers based on the high-performance ARM Cortex-M4 32-bit RISC core operating at a frequency of up to 80 MHz. The Cortex-M4 core features a Floating point unit (FPU) single precision which supports all ARM single-precision data-processing instructions and data types. It also implements a full set of DSP instructions and a memory protection unit (MPU) which enhances application security.
The STM32L476xx devices embed high-speed memories (Flash memory up to 1 Mbyte, up to 128 Kbyte of SRAM), a flexible external memory controller (FSMC) for static memories (for devices with packages of 100 pins and more), a Quad SPI flash memories interface (available on all packages) and an extensive range of enhanced I/Os and peripherals connected to two APB buses, two AHB buses and a 32-bit multi-AHB bus matrix.
The STM32L476xx devices embed several protection mechanisms for embedded Flash memory and SRAM: readout protection, write protection, proprietary code readout protection and Firewall.
The devices offer up to three fast 12-bit ADCs (5 Msps), two comparators, two operational amplifiers, two DAC channels, an internal voltage reference buffer, a low-power RTC, two general-purpose 32-bit timer, two 16-bit PWM timers dedicated to motor control, seven general-purpose 16-bit timers, and two 16-bit low-power timers. The devices support four digital filters for external sigma delta modulators (DFSDM).
In addition, up to 24 capacitive sensing channels are available. The devices also embed an integrated LCD driver 8x40 or 4x44, with internal step-up converter.
They also feature standard and advanced communication interfaces.
The STM32L476xx operates in the -40 to +85 °C (+105 °C junction), -40 to +105 °C (+125 °C junction) and -40 to +125 °C (+130 °C junction) temperature ranges from a 1.71 to 3.6 V VDD power supply when using internal LDO regulator and a 1.05 to 1.32V VDD12 power supply when using external SMPS supply. A comprehensive set of power-saving modes allows the design of low-power applications.
Some independent power supplies are supported: analog independent supply input for ADC, DAC, OPAMPs and comparators, 3.3 V dedicated supply input for USB and up to 14 I/Os can be supplied independently down to 1.08V. A VBAT input allows to backup the RTC and backup registers. Dedicated VDD12 power supplies can be used to bypass the internal LDO regulator when connected to an external SMPS.
The STM32L476xx family offers six packages from 64-pin to 144-pin packages.
Key Features
1、Ultra-low-power with FlexPowerControl
1.71 V to 3.6 V power supply
-40 °C to 85/105/125 °C temperature range
300 nA in VBAT mode: supply for RTC and 32x32-bit backup registers
30 nA Shutdown mode (5 wakeup pins)
120 nA Standby mode (5 wakeup pins)
420 nA Standby mode with RTC
1.1 μA Stop 2 mode, 1.4 μA with RTC
100 μA/MHz run mode (LDO Mode)
39 μA/MHz run mode (@3.3 V SMPS Mode)
Batch acquisition mode (BAM)
4 μs wakeup from Stop mode
Brown out reset (BOR)
Interconnect matrix
2、Core: ARM 32-bit Cortex-M4 CPU with FPU, Adaptive real-time accelerator (ART Accelerator) allowing 0-wait-state execution from Flash memory, frequency up to 80 MHz, MPU, 100DMIPS and DSP instructions
3、Performance benchmark
1.25 DMIPS/MHz (Drystone 2.1)
273.55 CoreMark (3.42 CoreMark/MHz @ 80 MHz)
4、Energy benchmark
220 ULPBENCH score
5、Clock Sources
4 to 48 MHz crystal oscillator
32 kHz crystal oscillator for RTC (LSE)
Internal 16 MHz factory-trimmed RC (±1%)
Internal low-power 32 kHz RC (±5%)
Internal multispeed 100 kHz to 48 MHz oscillator, autotrimmed by LSE (better than ±0.25 % accuracy)
3 PLLs for system clock, USB, audio, ADC
6、Up to 114 fast I/Os, most 5 V-tolerant, up to 14 I/Os with independent supply down to 1.08 V
7、RTC with HW calendar, alarms and calibration
8、LCD 8× 40 or 4× 44 with step-up converter
9、Up to 24 capacitive sensing channels: support touchkey, linear and rotary touch sensors
10、16x timers: 2x 16-bit advanced motor-control, 2x 32-bit and 5x 16-bit general purpose, 2x 16-bit basic, 2x low-power 16-bit timers (available in Stop mode), 2x watchdogs, SysTick timer
11、Memories
Up to 1 MB Flash, 2 banks read-while-write, proprietary code readout protection
Up to 128 KB of SRAM including 32 KB with hardware parity check
External memory interface for static memories supporting SRAM, PSRAM, NOR and NAND memories
Quad SPI memory interface
12、4x digital filters for sigma delta modulator
13、Rich analog peripherals (independent supply)
3× 12-bit ADC 5 Msps, up to 16-bit with hardware oversampling, 200 μA/Msps
2x 12-bit DAC, low-power sample and hold
2x operational amplifiers with built-in PGA
2x ultra-low-power comparators
14、20x communication interfaces
USB OTG 2.0 full-speed, LPM and BCD
2x SAIs (serial audio interface)
3x I2C FM+(1 Mbit/s), SMBus/PMBus
5x USARTs (ISO 7816, LIN, IrDA, modem)
1x LPUART (Stop 2 wake-up)
3x SPIs (4x SPIs with the Quad SPI)
CAN (2.0B Active) and SDMMC interface
SWPMI single wire protocol master I/F
IRTIM (Infrared interface)
15、14-channel DMA controller
16、True random number generator
17、CRC calculation unit, 96-bit unique ID
18、Development support: serial wire debug (SWD), JTAG, Embedded Trace Macrocell
ST NUCLEO-L476ZG电路原理图
发货清单
STM32L476 Nucleo开发板   1块
申请者请提前加入Elecfans开发板试用qq群:289737626,可第一时间得知试用消息;
活动时间
1. 申请报名:2017/08/15-2017/09/10
2. 公布名单:2017/09/13
3. 发货日期:2016/09/14(以实际为准)
4. 试用期限:收到产品后2个月内
请仔细阅读以下活动规则
活动流程
1. 申请:点击免费申请按钮即可报名。请认真填写申请理由,展现有创意的试用计划和网络影响力,尽快完善论坛个人信息,这样可以大大提高申请通过几率哦~;
2. 筛选:网站根据申请者填写的试用计划和论坛活跃度两个维度进行筛选;
3. 名单公布:试用名单将在活动页公布;
4. 试用通知:名单公布后工作人员将以短信或电话的方式通知申请成功者,2天不回复算弃权;
5. 产品寄送:公布试用名单后第一时间将产品快递给大家;
6. 试用报告:收到货后试用开始,每周至少提交一篇试用报告,试用报告要求100%原创,抄袭会被封杀哦;
7. 产品回收:报告足够优秀,产品赠送.
试用报告要求
试用者收到套件后,进行学习评估,并在STM32版块帖记录STM32L476 开发套件试用过程、分享试用心得。内容可以包括:
  • 1. 开箱评测(从功能特性、系统框图、硬件资源、做工、软件资源、功能演示等方面评测);
  • 2. 各个功能模块使用过后的评测;
  • 3. 连载的入门教程或者说明;
  • 4. 得意的小经验;
  • 5. 完成小项目流程等.....
结项报告要求:
经过试用评测学习后,试用者使用板卡完成申请时的项目,并在论坛发帖记录项目过程、心得。
可分为:项目概述、硬件设计、软件调试、视频效果演示,要求不少于500字+5张图片。
试用报告形式:标题格式【STM32L476 Nucleo开发板试用体验+自拟标题
注意事项
1.拉票可提升成功率,第一名直接获得试用机会;
2.30天内不得凭借拉票重复中签试用,以当月首次为准,不得调换,遇有重复则资格顺延;
3.刷票作弊者、不按照要求完成试用者一经查实将拉黑处理;
4.有问题请联系电子发烧友 mm(QQ:3353671470);
5.若因突发状况,无法继续完成试用,以及收到套件的15天内,若没有更新内容,请主动退还套件至ElecFans(PS:运费自理),方便其他网友继续试用;
6.活动过程中,套件所有权归ElecFans,试用者只拥有套件使用权; 若在使用过程中出现恶意损坏开发套件的行为,请原价赔偿;
7.电子发烧友拥有最终解释权!
企业介绍
意法半导体(ST)以业内最广泛的产品组合著称,凭借多元化的技术、尖端的设计能力、知识产权组合、合作伙伴战略和高效的制造能力,意法半导体通过提供创新型半导体解决方案为不同电子应用领域的客户提供服务。
他们正在申请
tyq9702
22:4309-08
申请理由 本人在单片机、DSP等领域有三年多的学习和开发经验,曾完成过变频恒压供水系统的设计,对互联网、物联网技术有过深入的学习和探索。想借助发烧友论坛和ST NUCLEO-L476ZG开发板完善项目的开源设计。 项目计划 ①根据文档,对ST NUCLEO-L476ZG开发板快速入门 ②通过学习ST NUCLEO-L476ZG开发板的软件和系统,了解实际应用案例,熟悉开发过程 ③基于ST NUCLEO-L476ZG开发板的空气质量检测系统的项目筹备(分析软硬件需求) ④项目开展,按时间计划实施。 ⑤项目调试,优化,分享。 预计成果 分享项目的开展,实施,结果过程,展示项目结果
jingsanchuanqi
10:2109-08
申请理由 一直在做机器人底盘驱动工作,想把驱动做进一步升级,悬疑哭按更快速,性能更好的驱动。 项目计划 1.首先学习NUCLEO-L476ZG文档,发掘卡法版优势 2.将先前的调试经验应用到这款开发板上 3.对驱动电机做详细的闭环处理,使驱动机器人更接近理想运动
_涛声依旧_
00:2909-08
申请理由: 本人对STM32系列单片机使用非常熟悉,经常使用HAL库进行开发,能够进行配置系统以及程 序移植调试。本人是一名电子通讯专业大学生,经常参加校内外各种电子比赛,对一些新奇 技术着迷。本人最近学会了一些机械设计,想将其应用于智能机器人项目,希望能够过这次 试用NUCLEO-L476ZG完成项目的开发。 项目计划 了解NUCLEO-L476ZG的特点,定制相关外围电路 参考相关文档资料,快速应用NUCLEO-L476ZG开发 设计智能机器人项目,结合NUCLEO-L476ZG进行程序编写 项目开展实施,调试优化,经验分享 预计成果: 分享使用过程的经验与使用心得,展示项目结果以及相关资料。
理由如下:1目前学生大二阶段,没有太多钱拿去花费2曾用过stm32f103做过小车,现在想用stm32l,也就是该公司所提供的版子制作四旋翼 3 stm32完全能满足要求,最近正学习pid,卡尔曼等算法,以及mpu6050,但仍缺 一个主控。。。。。。
h1654155872.5480
15:3509-01
本人有四年单片机开发经验,精通STM32,MSP430等市场上主流的单片机。贴吧上经常有STM32L和MSP430单片机功耗对比的帖子,对于这两款单片机哪一款耗能更少更是争论不休。 这样的对比本身意义并不大,功耗不仅与单片机硬件与架构有关,更多的是开发者对于芯片的使用,合理配置外设,好的系统框架才是低功耗的根本。本人将使用STM32F4和STM32L4同样完成相同任务,将两种单片机的功耗降到最低;对比两种单片机的功耗,分别在多中断,多外设,休眠等环境中分类对比功耗。 STM32L系列单片机是为了在保证高性能的情况下同时实现低功耗的微处理器,它与STM32F4的功耗对比将给我们什么样的惊喜呢?
HUAXD
11:0209-01
给客户开发一款低功耗的腕表,用于北斗导航、定位、测速,以及指南针,温湿度、心率监测等功能。计划今年设计完成,明年投产。stm32L4系列芯片正好功能强大,功耗低适合做这方面应用。
用户协议
09:3709-01
申请理由 本人在电子设计领域有差不多三年的学习和开发经验,曾做过智能花盆,智能物流小车等项目设计,熟悉基于MCU的应用产品开发,对于模式识别也有过专业的学习。此外,对于andriod与.net也有一定的研究,在这两个平台上都开发过应用程序。本次,希望可以借助 NXP LPC54110开发板 设计一款集合语音对话和控制以及其他功能的伴侣机器人。 项目计划 ①根据文档,对NXP LPC54110开发板快速入门 ②通过学习NXP LPC54110开发板,了解实际应用案例,熟悉开发过程 ③基于NXP LPC54110开发板的伴侣机器人 设计的初衷在于现在独居的人比较多,有些人一个人在家里或晚上睡觉的时候会感到不适应,所以本次想设计一个伴侣机器人,可以缓解一人独居时的孤独感和压力感,此外加入一些诸如闹钟,监控等的功能,使使用者的生活更加便利。1 ④项目开展,按时间计划实施。 ⑤项目调试,优化,分享。 预计成果 1、语音识别,语音对话,语音控制 2、夜灯功能,七彩暖光。 3、闹钟功能。 4、全向移动 5、自动充电,无线充电。 附加功能(尽量实现): 实时监控,联网监控
大雨淅淅
08:5208-31
STM32L4xx属于低功耗ARM4系列,非常适用于低功耗的手持设备,本试用计划就是采用此开发板制作低功耗控制设备 ①根据文档,对ST NUCLEO-L476ZG快速入门 ②通过学习ST NUCLEO-L476ZG的软件和系统,了解实际应用案例,熟悉开发过程 ③基于ST NUCLEO-L476ZG+海尔MK-QTWIFI-05云LED控制。 ④项目开展,按时间计划实施。 ⑤项目调试,优化,分享。
w247435089
22:5108-29
我正在做一个电子智能锁项目,客户要求低功耗功能,在网站上看到贵站可以申请免费的开发板试用,希望能申请一块进行测试评估。
1084792967
17:3508-29
1.由于是stm32f103没有USB otg以及功耗不够低,所以现在打算使用低功耗的L系列单片机。计划采用M4单片机,以满足后期可能的功能更新。 2.目前没有使用M4内核的单片机,许要先在开发板上实现基本功能,待测试验证通过后在进一步计划。
小罗abc
00:5608-29
尝试制作智能控制系统
shuchao007
17:0008-28
①根据文档,对ST NUCLEO-L476ZG快速入门 ②通过学习ST NUCLEO-L476ZG的软件和系统,了解实际应用案例,熟悉开发过程 ③基于ST NUCLEO-L476ZG+ESP8266云LED控制。 ④项目开展,按时间计划实施。 ⑤项目调试,优化,分享。
北京四中网校
19:2008-27
安卓无线充电技术
user947
18:4208-27
学习使用
孙光祖
20:4608-25
超低功耗满足要求 需要三路AD采集温度,压力,频谱偏移,需要三个定时器,一路输出2M方波,一路输出75M方波驱动DDS合成正弦波,需要几个IO口,控制电源开关以及相关芯片的开关,以及需要485接口,传输数据到PC机,将数据显示,曾经用过STM32L476VET6调通一些小实验,例如485通信 AD电压采集,定时器,SPI通信等。希望申请到此板之后,一周写两个测试程序,将单片机基本功能都实现,将程序分享给大家,谢谢!
黎专属
13:3308-25
目前学习stm32,想多接触类似的单片机,增加知识的储备量。
武进腾
08:3908-25
测试STM32L476作为扫地机器人主控板是否可行,如果性能可靠,我们将会采购一批用于组装机器人,和教学。
傲笑红尘_011
15:2708-24
做门禁
机器人工作者
08:2808-24
一直比较关注STM32的产品,计划利用本次机会制作一个手持天然气检测仪,测试一下STM32低功耗的性能~
皓宇_666
21:3508-21
本人为辽宁大学信息学院实验教师。在本科现代电子学实验,课程设计和全国大学生电子大赛中带领学生学习、验证、研究各种新型电子设备及技术。收集各种新颖的嵌入式开发板和模块,验证例程、测试性能、研究原理、开发简单系统,给学生讲解。并在合适的情况下应用在科研项目中。
申请合作
