扫一扫,分享给好友
想模仿这个教程做个mp3http://www.geekfans.com/article-4670-1.html
可是sd卡一直都初始化不了,求助一下大家,都是自学的 //***********模拟spi写函数 void SPI_W(unsigned char Data){ unsigned char i; for(i = 0; i<8; i++){ Data <<= 1; CLK = 0; DI = CY; CLK = 1; }; DI = 1; } //***********spi读函数 unsigned char SPI_R(){ unsigned char Data,i; DO = 1;//设置DO接口为输入状态 for(i = 0; i<8; i++){ Data <<= 1; CLK = 0; CLK = 1; Data |= DO; }; return Data; } //**************读sd卡回应 unsigned char SD_Response(){ unsigned char i,Response; for(i = 0; i<10; i++){ Response = SPI_R(); if(Response == 0x00) break; if(Response == 0x01) break; }; return Response; } //***************向SD发命令 void SD_Cmd(unsigned char Cmd, unsigned long Argument, unsigned char CRC){ unsigned char arg[4]; arg[0] = (unsigned char)Argument; arg[1] = (unsigned char)(Argument >> 8); arg[2] = (unsigned char)(Argument >> 16); arg[3] = (unsigned char)(Argument >> 24); SPI_W(Cmd | 0x40); SPI_W(arg[3]); SPI_W(arg[2]); SPI_W(arg[1]); SPI_W(arg[0]); SPI_W(CRC); } //*************SD卡初始化 unsigned char SD_Init(){ unsigned int delay = 0; unsigned char i; unsigned char Response = 0xff; CS = 1; for(i = 0; i<10; i++){ SPI_W(0xff);//上电后给74个以上的时间脉冲 }; CS = 0; SD_Cmd(0x00, 0, 0x95);//命令CMD0,复位SD卡 //等待复位成功 i = 0; while(SD_Response() != 0x01){//等待SD卡回应信号 i++; if(i > 100){ return 0;//失败返回0 }; }; CS = 1; SPI_W(0xff);//关片选后写8个空脉冲,SD卡复位完毕 //设置SPI i = 0; CS = 0; while(Response != 0x00){//循环等待成功回应,若成功,回应信号为0x00 SD_Cmd(0x01, 0, 0xff);//CMD1,将SD卡设置为SPI模式,无需CRC校验,填入0xff Response = SD_Response(); if(i > 100){ return 0;//尝试100次,失败返回0 }; }; CS = 1; SPI_W(0xff);//给8个空脉冲 return 1; } //****************从sd卡读数据块 void SD_Block_R(unsigned char* block, unsigned long address){ unsigned int i; CS = 0; SD_Cmd(0x11, address, 0xff);//CMD11,数据块读写命令, while(SD_Response()!=0x00);//循环等待命令回应0x00 while(SPI_R() != 0xfe); //0xfe为块读出的头, 后面紧跟512字节的数据块+2字节的CRC for(i=0; i<512 ; i++){ block = SPI_R();//读数据 }; SPI_R(); SPI_R();//两个字节的CRC。舍弃 CS =1; SPI_R();//8个空脉冲 } 发cmd0复位后,一直没有收到01回应,在此求助一下大家 |
3个回答
是不是写入速度太高了 具体怎么调呢 谢谢大家了
//等待复位成功
i = 0; while(SD_Response() != 0x01){//等待SD卡回应信号 i++; if(i > 100){ return 0;//失败返回0 }; }; 执行完这一句就返回0 导致后面读取不成功 实在不懂为什么求助各位大神 |
求助大家
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【每周推荐】采用11代Intel CPU,基于youyeetoo X1开发板搭建少儿AI智能STEAM积木平台
776 浏览 0 评论
2265 浏览 2 评论
【youyeetoo X1 windows 开发板体验】+ 影音处理和AI模型移植
2124 浏览 5 评论
I.MX6ULL-飞凌 ElfBoard ELF1板卡- 移植zbar的方法
1682 浏览 0 评论
2786 浏览 3 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
5528 浏览 31 评论
GMT+8, 2024-4-19 23:54 , Processed in 0.571630 second(s), Total 67, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
