扫一扫,分享给好友
加了颜色的代码什么意思
/*********************************************************************************************** * SPI MASTER * January 2007 ************************************************************************************************/ `timescale 10ns/1ns module SPI_Master ( miso, mosi, sclk, ss, data_bus, CS, addr, pro_clk, WR, RD); inout [7:0] data_bus; // 8 bit bidirectional data bus input pro_clk; // Host Processor clock input miso; // Master in slave out input [1:0] addr; // A1 and A0, lower bits of address bus input CS; // Chip Select input WR, RD; // Write and read enables output mosi; // Master out slave in output sclk; // SPI clock output [7:0] ss; // 8 slave select lines reg [7:0] shift_register; // Shift register reg [7:0] txdata; // Transmit buffer reg [7:0] rxdata; // Receive buffer reg [7:0] data_out; // Data output register reg [7:0] data_out_en; // Data output enable reg [7:0] control, status; // Control Register COntrols things like ss, CPOL, CPHA, clock divider // Status Register is a dummy register never used. reg [7:0] clk_divide; // Clock divide counter reg [3:0] count; // SPI word length counter reg sclk; reg slave_cs; // Slave cs flag reg mosi; // Master out slave in reg spi_word_send; // Will send a new spi word. wire [7:0] data_bus; wire [7:0] data_in = data_bus; wire spi_clk_gen; wire [2:0] divide_factor = control[2:0]; wire CPOL = control[3]; wire CPHA = control[4]; wire [7:0]ss; /* Slave Select lines */ assign ss[7] = ~( control[7] & control[6] & control[5] & (~slave_cs)); assign ss[6] = ~( control[7] & control[6] & ~control[5] & (~slave_cs)); assign ss[5] = ~( control[7] & ~control[6] & control[5] & (~slave_cs)); assign ss[4] = ~( control[7] & ~control[6] & ~control[5] & (~slave_cs)); assign ss[3] = ~(~control[7] & control[6] & control[5] & (~slave_cs)); assign ss[2] = ~(~control[7] & control[6] & ~control[5] & (~slave_cs)); assign ss[1] = ~(~control[7] & ~control[6] & control[5] & (~slave_cs)); assign ss[0] = ~(~control[7] & ~control[6] & ~control[5] & (~slave_cs)); /* clock divide */ assign spi_clk_gen = clk_divide[divide_factor]; /* Clock Divider */ always @ (negedge pro_clk) begin clk_divide = clk_divide + 1; end /* Reading the miso line and shifting */ always @ (posedge (sclk ^ (CPHA ^ CPOL)) or posedge spi_word_send) begin if (spi_word_send) begin shift_register[7:0] = txdata; end else begin shift_register = shift_register << 1; shift_register[0] <= miso; end end /* Writing the mosi */ always @ (negedge (sclk ^ (CPHA ^ CPOL)) or posedge spi_word_send) begin if (spi_word_send) begin mosi = txdata[7]; end else begin mosi = shift_register[7]; end end /* Contolling the interrupt bit in the status bit */ always @ (posedge slave_cs or posedge spi_word_send) begin if (spi_word_send) begin status[0] = 0; end else begin status = 8'h01; rxdata = shift_register; // updating read buffer end end /* New SPI wrod starts when the transmit buffer is updated */ always @ (posedge pro_clk) begin if (spi_word_send) begin slave_cs <= 0; end else if ((count == 8) & ~(sclk ^ CPOL)) begin slave_cs <= 1; end end /* New Spi word is intiated when transmit buffer is updated */ always @ (posedge pro_clk) begin if (CS & WR & addr[1] & ~addr[0]) begin spi_word_send <=1; end else begin spi_word_send <=0; end end /* Generating the SPI clock */ always @ (posedge spi_clk_gen) begin if (~slave_cs) begin sclk = ~sclk; end else if (~CPOL) begin sclk = 0; end else begin sclk = 1; end end /* Counting SPI word length */ always @ (posedge sclk or posedge slave_cs) begin if (slave_cs) begin count = 0; end else begin count = count + 1; end end /* Reading, writing SPI registers */ always @ (posedge pro_clk) begin if (CS) begin case (addr) 2'b00 : if (WR) control <= data_in; 2'b01 : if (RD) data_out <= status; // Void 2'b10 : if (WR) txdata <= data_in; 2'b11 : if (RD) data_out <= rxdata; endcase end end /* Controlling the data out enable */ always @ (RD or data_out) begin if (RD) data_out_en = data_out; else data_out_en = 8'bz; end assign data_bus = data_out_en; initial begin mosi = 0; //sclk = 0; control = 0; count = 0; slave_cs = 1; txdata = 0; rxdata = 0; clk_divide = 0; data_out = 0; end endmodule /********************************************** END ******************************************************************/ |
1个回答
看SPI协议
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1278 浏览 1 评论
368 浏览 0 评论
【星嵌电子XQ138F-EVM开发板体验】(原创)8.安全FPGA防御黑客病毒(芯片设计制造级防护)源代码
1369 浏览 0 评论
【国产FPGA+OMAPL138开发板体验】(原创)7.硬件加速Sora文生视频源代码
2529 浏览 0 评论
【星嵌-XQ138F-试用连载体验】ARM驱动开发示例,LED亮灭,以及内核编译。
587 浏览 0 评论
1068 浏览 22 评论
GMT+8, 2024-3-28 22:21 , Processed in 0.363707 second(s), Total 69, Slave 52 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
