扫一扫,分享给好友
// ti File $Revision: /main/4 $ // Checkin $Date: December 3, 2004 13:58:42 $ //########################################################################### // // FILE: Example_280xECanBack2Back.c // // TITLE: DSP280x eCAN Back-to-back transmission and reception in // SELF-TEST mode // // ASSUMPTIONS: // // This program requires the DSP280x header files. // // This progrm uses the peripheral's self test mode. // Other then boot mode configuration, no other hardware configuration // is required. // // As supplied, this project is configured for "boot to SARAM" // operation. The 280x Boot Mode table is shown below. // For information on configuring the boot mode of an eZdsp, // please refer to the documentation included with the eZdsp, // // Boot GPIO18 GPIO29 GPIO34 // Mode SPICLKA SCITXDA // SCITXB // ------------------------------------- // Flash 1 1 1 // SCI-A 1 1 0 // SPI-A 1 0 1 // I2C-A 1 0 0 // ECAN-A 0 1 1 // SARAM 0 1 0 <- "boot to SARAM" // OTP 0 0 1 // I/0 0 0 0 // // // // DESCRIPTION: // // This test transmits data back-to-back at high speed without // stopping. // The received data is verified. Any error is flagged. // MBX0 transmits to MBX16, MBX1 transmits to MBX17 and so on.... // This program illustrates the use of self-test mode // //########################################################################### // Original Author H.J. // // $TI Release: DSP280x V1.30 $ // $Release Date: February 10, 2006 $ //########################################################################### #include "DSP280x_Device.h" // DSP280x Headerfile Include File #include "DSP280x_Examples.h" // DSP280x Examples Include File // Prototype statements for functions found within this file. void mailbox_check(int32 T1, int32 T2, int32 T3); void mailbox_read(int16 i); // Global variable for this example Uint32 ErrorCount; Uint32 PassCount; Uint32 MessageReceivedCount; Uint32 TestMbox1 = 0; Uint32 TestMbox2 = 0; Uint32 TestMbox3 = 0; void main(void) { Uint16 j; // eCAN control registers require read/write access using 32-bits. Thus we // will create a set of shadow registers for this example. These shadow // registers will be used to make sure the access is 32-bits and not 16. struct ECAN_REGS ECanaShadow; // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP280x_SysCtrl.c file. InitSysCtrl(); // Step 2. Initalize GPIO: // This example function is found in the DSP280x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // InitGpio(); // Skipped for this example // For this example, configure CAN pins using GPIO regs here // This function is found in DSP280x_ECan.c InitECanGpio(); // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP280x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP280x_DefaultIsr.c. // This function is found in DSP280x_PieVect.c. InitPieVectTable(); // Step 4. Initialize all the Device Peripherals: // This function is found in DSP280x_InitPeripherals.c // InitPeripherals(); // Not required for this example // Step 5. User specific code, enable interrupts: MessageReceivedCount = 0; ErrorCount = 0; PassCount = 0; //InitECana(); // eCAN control registers require 32-bit access. // If you want to write to a single bit, the compiler may break this // access into a 16-bit access. One solution, that is presented here, // is to use a shadow register to force the 32-bit access. // Read the entire register into a shadow register. This access // will be 32-bits. Change the desired bit and copy the value back // to the eCAN register with a 32-bit write. // Configure the eCAN RX and TX pins for eCAN transmissions EALLOW; ECanaShadow.CANTIOC.all = ECanaRegs.CANTIOC.all; ECanaShadow.CANTIOC.bit.TXFUNC = 1; ECanaRegs.CANTIOC.all = ECanaShadow.CANTIOC.all; ECanaShadow.CANRIOC.all = ECanaRegs.CANRIOC.all; ECanaShadow.CANRIOC.bit.RXFUNC = 1; ECanaRegs.CANRIOC.all = ECanaShadow.CANRIOC.all; EDIS; // Disable all Mailboxes // Since this write is to the entire register (instead of a bit // field) a shadow register is not required. ECanaRegs.CANME.all = 0; ECanaShadow.CANTRR.all = ECanaRegs.CANTRR.all; ECanaShadow.CANTRR.all=0xFF; ECanaRegs.CANTRR.all = ECanaShadow.CANTRR.all; // Mailboxs can be written to 16-bits or 32-bits at a time // Write to the MSGID field of TRANSMIT mailboxes MBOX0 - 15 ECanaMboxes.MBOX0.MSGID.all = 0x9555AAA0; ECanaMboxes.MBOX1.MSGID.all = 0x9555AAA1; ECanaMboxes.MBOX2.MSGID.all = 0x9555AAA2; ECanaMboxes.MBOX3.MSGID.all = 0x9555AAA3; ECanaMboxes.MBOX4.MSGID.all = 0x9555AAA4; ECanaMboxes.MBOX5.MSGID.all = 0x9555AAA5; ECanaMboxes.MBOX6.MSGID.all = 0x9555AAA6; ECanaMboxes.MBOX7.MSGID.all = 0x9555AAA7; ECanaMboxes.MBOX8.MSGID.all = 0x9555AAA8; ECanaMboxes.MBOX9.MSGID.all = 0x9555AAA9; ECanaMboxes.MBOX10.MSGID.all = 0x9555AAAA; ECanaMboxes.MBOX11.MSGID.all = 0x9555AAAB; ECanaMboxes.MBOX12.MSGID.all = 0x9555AAAC; ECanaMboxes.MBOX13.MSGID.all = 0x9555AAAD; ECanaMboxes.MBOX14.MSGID.all = 0x9555AAAE; ECanaMboxes.MBOX15.MSGID.all = 0x9555AAAF; // Write to the MSGID field of RECEIVE mailboxes MBOX16 - 31 ECanaMboxes.MBOX16.MSGID.all = 0x9555AAA0; ECanaMboxes.MBOX17.MSGID.all = 0x9555AAA1; ECanaMboxes.MBOX18.MSGID.all = 0x9555AAA2; ECanaMboxes.MBOX19.MSGID.all = 0x9555AAA3; ECanaMboxes.MBOX20.MSGID.all = 0x9555AAA4; ECanaMboxes.MBOX21.MSGID.all = 0x9555AAA5; ECanaMboxes.MBOX22.MSGID.all = 0x9555AAA6; ECanaMboxes.MBOX23.MSGID.all = 0x9555AAA7; ECanaMboxes.MBOX24.MSGID.all = 0x9555AAA8; ECanaMboxes.MBOX25.MSGID.all = 0x9555AAA9; ECanaMboxes.MBOX26.MSGID.all = 0x9555AAAA; ECanaMboxes.MBOX27.MSGID.all = 0x9555AAAB; ECanaMboxes.MBOX28.MSGID.all = 0x9555AAAC; ECanaMboxes.MBOX29.MSGID.all = 0x9555AAAD; ECanaMboxes.MBOX30.MSGID.all = 0x9555AAAE; ECanaMboxes.MBOX31.MSGID.all = 0x9555AAAF; // Specify that 8 bits will be sent/received ECanaMboxes.MBOX0.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX1.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX2.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX3.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX4.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX5.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX6.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX7.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX8.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX9.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX10.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX11.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX12.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX13.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX14.MSGCTRL.bit.DLC = 8; ECanaMboxes.MBOX15.MSGCTRL.bit.DLC = 8; // No remote frame is requested // Since RTR bit is undefined upon reset, // it must be initialized to the proper value ECanaMboxes.MBOX0.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX1.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX2.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX3.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX4.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX5.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX6.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX7.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX8.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX9.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX10.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX11.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX12.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX13.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX14.MSGCTRL.bit.RTR = 0; ECanaMboxes.MBOX15.MSGCTRL.bit.RTR = 0; // Configure Mailboxes 0-15 as Tx, 16-31 as Rx // Since this write is to the entire register (instead of a bit // field) a shadow register is not required. ECanaRegs.CANMD.all = 0xFFFF0000; // Enable all Mailboxes */ // Since this write is to the entire register (instead of a bit // field) a shadow register is not required. ECanaRegs.CANME.all = 0xFFFFFFFF; // Write to the mailbox RAM field of MBOX0 - 15 ECanaMboxes.MBOX0.MDL.all = 0x9555AAA0; ECanaMboxes.MBOX0.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX1.MDL.all = 0x9555AAA1; ECanaMboxes.MBOX1.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX2.MDL.all = 0x9555AAA2; ECanaMboxes.MBOX2.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX3.MDL.all = 0x9555AAA3; ECanaMboxes.MBOX3.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX4.MDL.all = 0x9555AAA4; ECanaMboxes.MBOX4.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX5.MDL.all = 0x9555AAA5; ECanaMboxes.MBOX5.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX6.MDL.all = 0x9555AAA6; ECanaMboxes.MBOX6.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX7.MDL.all = 0x9555AAA7; ECanaMboxes.MBOX7.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX8.MDL.all = 0x9555AAA8; ECanaMboxes.MBOX8.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX9.MDL.all = 0x9555AAA9; ECanaMboxes.MBOX9.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX10.MDL.all = 0x9555AAAA; ECanaMboxes.MBOX10.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX11.MDL.all = 0x9555AAAB; ECanaMboxes.MBOX11.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX12.MDL.all = 0x9555AAAC; ECanaMboxes.MBOX12.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX13.MDL.all = 0x9555AAAD; ECanaMboxes.MBOX13.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX14.MDL.all = 0x9555AAAE; ECanaMboxes.MBOX14.MDH.all = 0x89ABCDEF; ECanaMboxes.MBOX15.MDL.all = 0x9555AAAF; ECanaMboxes.MBOX15.MDH.all = 0x89ABCDEF; // Since this write is to the entire register (instead of a bit // field) a shadow register is not required. EALLOW; ECanaRegs.CANMIM.all = 0xFFFFFFFF; // Request permission to change the configuration registers ECanaShadow.CANMC.all = ECanaRegs.CANMC.all; ECanaShadow.CANMC.bit.CCR = 1; ECanaRegs.CANMC.all = ECanaShadow.CANMC.all; EDIS; // Wait until the CPU has been granted permission to change the // configuration registers // Wait for CCE bit to be set.. do { ECanaShadow.CANES.all = ECanaRegs.CANES.all; } while(ECanaShadow.CANES.bit.CCE != 1 ); // Configure the eCAN timing EALLOW; ECanaShadow.CANBTC.all = ECanaRegs.CANBTC.all; ECanaShadow.CANBTC.bit.BRPREG = 9; // (BRPREG + 1) = 10 feeds a 15 MHz CAN clock ECanaShadow.CANBTC.bit.TSEG2REG = 1;//5 ; // to the CAN module. (150 / 10 = 15) ECanaShadow.CANBTC.bit.TSEG1REG = 6;//7; // Bit time = 15 ECanaRegs.CANBTC.all = ECanaShadow.CANBTC.all; ECanaShadow.CANMC.all = ECanaRegs.CANMC.all; ECanaShadow.CANMC.bit.CCR = 0; ECanaRegs.CANMC.all = ECanaShadow.CANMC.all; EDIS; // Wait until the CPU no longer has permission to change the // configuration registers do { ECanaShadow.CANES.all = ECanaRegs.CANES.all; } while(ECanaShadow.CANES.bit.CCE != 0 ); // Configure the eCAN for self test mode // Enable the enhanced features of the eCAN. EALLOW; ECanaShadow.CANMC.all = ECanaRegs.CANMC.all; ECanaShadow.CANMC.bit.STM = 1; // Configure CAN for self-test mode ECanaShadow.CANMC.bit.SCB = 1; // eCAN mode (reqd to access 32 mailboxes) //ECanaShadow.CANMC.bit.ABO = 1; //ECanaShadow.CANMC.bit.SAM = 1; ECanaRegs.CANMC.all = ECanaShadow.CANMC.all;
while(ECanaRegs.CANTRS.all!=0){} EDIS; // Begin transmitting for(;;) { ECanaShadow.CANTA.all=0; //ECanaRegs.CANTRS.all = 0x0000FFFF; // Set TRS for all transmit mailboxes ECanaShadow.CANTRS.all = 0; // Set TRS for all transmit mailboxes ECanaShadow.CANTRS.all=0xFFFF; ECanaRegs.CANTRS.all=ECanaShadow.CANTRS.all;
while(ECanaShadow.CANTA.all != 0x0000FFFF ) {} // Wait for all TAn bits to be set..//////一直停在这。。。。求助 ECanaRegs.CANTA.all = 0x0000FFFF; // Clear all TAn MessageReceivedCount++; //Read from Receive mailboxes and begin checking for data */ for(j=0; j<16; j++) // Read & check 16 mailboxes { mailbox_read(j); // This func reads the indicated mailbox data mailbox_check(TestMbox1,TestMbox2,TestMbox3); // Checks the received data } } } // This function reads out the contents of the indicated // by the Mailbox number (MBXnbr). void mailbox_read(int16 MBXnbr) { volatile struct MBOX *Mailbox; Mailbox = &ECanaMboxes.MBOX0 + MBXnbr; TestMbox1 = Mailbox->MDL.all; // = 0x9555AAAn (n is the MBX number) TestMbox2 = Mailbox->MDH.all; // = 0x89ABCDEF (a constant) TestMbox3 = Mailbox->MSGID.all;// = 0x9555AAAn (n is the MBX number) } // MSGID of a rcv MBX is transmitted as the MDL data. void mailbox_check(int32 T1, int32 T2, int32 T3) { if((T1 != T3) || ( T2 != 0x89ABCDEF)) { ErrorCount++; } else { PassCount++; } } //=========================================================================== // No more. //=========================================================================== |
2个回答
好厉害啊,楼主
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式操作教程_数字信号处理_音频编解码:3-6 AAC音频解码实验
441 浏览 0 评论
数字信号处理实验操作教程:3-3 mp3音频编码实验(AD7606采集)
1333 浏览 0 评论
嵌入式DSP教学实验箱操作教程:2-20 数模转换实验(模拟SPI总线输出电压值)
1377 浏览 0 评论
目前在2837x系列用的最多的、性能最好、性价比最高的是哪一款?
1138 浏览 0 评论
国产嵌入式DSP教学实验箱_操作教程:22-AD采集DA输出实验(采集输出正弦波)
2329 浏览 0 评论
GMT+8, 2024-4-25 17:15 , Processed in 0.420805 second(s), Total 43, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
