times New="New" Roman'; mso-hansi-font-family: 'Times New="New" Roman'; mso-ansi-language: EN-US; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: 'Times New="New" Roman'">
附件A、三极管的Pspice模型参数 .Model
附件B、 PSpice Goal Function
附件CModeling voltage-controlled and temperature-dependent resistorsAnalog Behavioral Modeling (ABM) can be used to model a nonlinear resistor through use of Ohm抯 law and tables and expressions which describe resistance. Here are some examples. Voltage-controlled resistorIf a Resistance vs. Voltage curve is available, a look-up table can be used in the ABM expression. This table contains (Voltage, Resistance) pairs picked from points on the curve. The voltage input is nonlinearly mapped from the voltage values in the table to the resistance values. Linear interpolation is used between table values. Let抯 say that points picked from a Resistance vs. Voltage curve are:
The ABM expression for this is shown in Figure 1. Figure 1 - Voltage controlled resistor using look-up table Temperature-dependent resistorA temperature-dependent resistor (or thermistor) can be modeled with a look-up table, or an expression can be used to describe how the resistance varies with temperature. The denominator in the expression in Figure 2 is used to describe common thermistors. The TEMP variable in the expression is the simulation temperature, in Celsius. This is then converted to Kelvin by adding 273.15. This step is necessary to avoid a divide by zero problem in the denominator, when T=0 C. NOTE: TEMP can only be used in ABM expressions (E, G devices). Figure 3 shows the results of a DC sweep of temperature from -40 to 60 C. The y-axis shows the resistance or V(I1:-)/1A. Figure 2 - Temperature controlled resistor Figure 3 - PSpice plot of Resistance vs. Temperature (current=1A) Variable Q RLC networkIn most circuits the value of a resistor is fixed during a simulation. While the value can be made to change for a set of simulations by using a Parametric Sweep to move through a fixed sequence of values, a voltage-controlled resistor can be made to change dynamically during a simulation. This is illustrated by the circuit shown in Figure 5, which employs a voltage-controlled resistor. Figure 4 - Parameter sweep of control voltage This circuit employs an external reference component that is sensed. The output impedance equals the value of the control voltage times the reference. Here, we will use Rref, a 50 ohm resistor as our reference. As a result, the output impedance is seen by the circuit as a floating resistor equal to the value of V(Control) times the resistance value of Rref. In our circuit, the control voltage value is stepped from 0.5 volt to 2 volts in 0.5 volt steps, therefore, the resistance between nodes 3 and 0 varies from 25 ohms to 100 ohms in 25 ohm-steps. Figure 5 - Variable Q RLC circuit A transient analysis of this circuit using a 0.5 ms wide pulse will show how the ringing differs as the Q is varied. Using Probe, we can observe how the ringing varies as the resistance changes. Figure 6 shows the input pulse and the voltage across the capacitor C1. Comparing the four output waveforms, we can see the most pronounced ringing occurs when the resistor has the lowest value and the Q is greatest. Any signal source can be used to drive the voltage-controlled resistance. If we had used a sinusoidal control source instead of a staircase, the resistance would have varied dynamically during the simulation. Figure 6 - Output waveforms of variable Q RLC circuit |
13 个讨论
下来看看
多谢了! |
只有小组成员才能发言,加入小组>>
如何用AD844运算放大器完成双二阶滤波器的Pspice仿真
4422 浏览 0 评论
PSPICE二极管Model,修改结电压参数Vj0后,仿真导通电压不变?
3274 浏览 1 评论
4736 浏览 3 评论
3123 浏览 2 评论
我给导线一个网络节点,命名为V2,请问为什么在直流扫描的时候识别不了呢?
3462 浏览 0 评论
Cadence capture原理图中如果有没连接的电源符号,可以通过什么方式检查出来
10214浏览 1评论
5040浏览 1评论
954浏览 0评论
新手做pspice仿真,没有找到C3M0032120K的pspice模型,改用STW56N65M2-4_TN代替,仿真出现一堆问题,求帮助
3181浏览 0评论
GMT+8, 2024-4-19 00:32 , Processed in 0.491486 second(s), Total 53, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
