提示:如果要初始化P2作为紧凑模式高端地址,必须:PPAGEENAGLE=1,PPAGE为P2值,例如指定某页1000H-10FFH,则PPAGE=10H,而且连接时必须如下: L51 PDATA(1080H),其中1080H是1000H-10FFH中的任一个值。 以下是STARTUP.A51代码片断,红色是经常可能需要修改的地方: ;------------------------------------------------------------------------------ ; This file is part of the C51 Compiler package ; Copyright KEIL ELEKTRONIK GmbH 1990 ;------------------------------------------------------------------------------ ; STARTUP.A51: This code is executed after processor reset. ; ; To translate this file use A51 with the following invocation: ; ; A51 STARTUP.A51 ; ; To link the modified STARTUP.OBJ file to your application use the following ; L51 invocation: ; ; L51 , STARTUP.OBJ ; ;------------------------------------------------------------------------------ ; ; User-defined Power-On Initialization of Memory ; ; With the following EQU statements the initialization of memory ; at processor reset can be defined: ; ; ; the absolute start-address of IDATA memory is always 0 IDATALEN EQU 80H ; the length of IDATA memory in bytes. ; XDATASTART EQU 0H ; the absolute start-address of XDATA memory XDATALEN EQU 0H ; the length of XDATA memory in bytes. ; PDATASTART EQU 0H ; the absolute start-address of PDATA memory PDATALEN EQU 0H ; the length of PDATA memory in bytes. ; ; Notes: The IDATA space overlaps physically the DATA and BIT areas of the ; 8051 CPU. At minimum the memory space occupied from the C51 ; run-time routines must be set to zero. ;------------------------------------------------------------------------------ ; ; Reentrant Stack Initilization ; ; The following EQU statements define the stack pointer for reentrant ; functions and initialized it: ; ; Stack Space for reentrant functions in the SMALL model. IBPSTACK EQU 0 ; set to 1 if small reentrant is used. IBPSTACKTOP EQU 0FFH+1 ; set top of stack to highest location+1. ; ; Stack Space for reentrant functions in the LARGE model. XBPSTACK EQU 0 ; set to 1 if large reentrant is used. XBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1. ; ; Stack Space for reentrant functions in the COMPACT model. PBPSTACK EQU 0 ; set to 1 if compact reentrant is used. PBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1. ; ;------------------------------------------------------------------------------ ; ; Page Definition for Using the Compact Model with 64 KByte xdata RAM ; ; The following EQU statements define the xdata page used for pdata ; variables. The EQU PPAGE must conform with the PPAGE control used ; in the linker invocation. ; PPAGEENABLE EQU 0 ; set to 1 if pdata object are used. PPAGE EQU 0 ; define PPAGE number. ; ;------------------------------------------------------------------------------
