扫一扫,分享给好友
板子:nanopi m2 系统:ubuntu mate , debian 问题:连接有线网卡,系统正常运行。但是ping丢包非常严重。感觉网卡断开等一会才又重新连上。 下面是截图: 下面是同网络环境下的树莓派: 下面是dmesg的内容: root@NanoPi2:~# dmesg [ 0.000000] Booting Linux on physical CPU 0 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.4.39-FriendlyARM (root@jensen) (gcc version 4.9.3 (ctng-1.21.0-229g-FA) ) #8 SMP PREEMPT Mon Feb 22 17:53:00 HKT 2016 [ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: NANOPI2 [ 0.000000] Display: HDMI selected [ 0.000000] nxp_reserve_mem: reserve CMA: size 201326592 [ 0.000000] NXP/CMA: Reserved 0x74000000/0x0c000000 for 'ion' [ 0.000000] NXP/CMA: success register cma region for 'ion' [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] CPU : iomap[ 0]: p 0xc0000000 -> v 0xf0000000 len=0x300000 [ 0.000000] CPU : iomap[ 1]: p 0xf0000000 -> v 0xf0300000 len=0x100000 [ 0.000000] CPU : iomap[ 2]: p 0xcf000000 -> v 0xf0400000 len=0x100000 [ 0.000000] CPU : iomap[ 3]: p 0x2c000000 -> v 0xf0500000 len=0x100000 [ 0.000000] CPU : iomap[ 4]: p 0x00000000 -> v 0xf0600000 len=0x100000 [ 0.000000] CPU : DMA Zone Size =16M, CORE 4 [ 0.000000] CPU : VERSION = 2 (0xE153000A), Assign Peripheral Exclusive Bus [ 0.000000] s5p4418-NanoPi2: Board initialized [ 0.000000] CPU : Clock Generator= 64 EA, DVFS = support, PLL.1 [ 0.000000] PLL : [0] = 550000000, [1] = 800000000, [2] = 800000000, [3] = 614399000 [ 0.000000] PLL1: CPU FCLK = 800000000, HCLK = 200000000 [ 0.000000] PLL2: BUS BCLK = 400000000, PCLK = 200000000 [ 0.000000] PLL2: MEM MCLK = 800000000, DCLK = 800000000, BCLK = 400000000, PCLK = 200000000 [ 0.000000] PLL0: G3D BCLK = 550000000 [ 0.000000] PLL2: MPG BCLK = 400000000, PCLK = 200000000 [ 0.000000] On node 0 totalpages: 262144 [ 0.000000] free_area_init_node: node 0, pgdat 808eb400, node_mem_map 809da000 [ 0.000000] DMA zone: 2304 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 259840 pages, LIFO batch:31 [ 0.000000] PERCPU: Embedded 8 pages/cpu @812e1000 s12288 r8192 d12288 u32768 [ 0.000000] pcpu-alloc: s12288 r8192 d12288 u32768 alloc=8*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840 [ 0.000000] Kernel command line: console=ttyAMA0,115200n8 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait init=/***in/init systemd.show_status=false g_ether.host_addr=82:cf:ce:fa:44:18 console=tty1 lcd=HDMI720P60 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] allocated 2097152 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Memory: 1024MB = 1024MB total [ 0.000000] Memory: 829648k/829648k available, 218928k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xc0800000 - 0xfee00000 ( 998 MB) [ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB) [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB) [ 0.000000] .text : 0x80008000 - 0x80846b70 (8443 kB) [ 0.000000] .init : 0x80847000 - 0x80880000 ( 228 kB) [ 0.000000] .data : 0x80880000 - 0x808fe348 ( 505 kB) [ 0.000000] .bss : 0x808fe36c - 0x809d9cc0 ( 879 kB) [ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:288 [ 0.000000] VIC @f0002000: id 0x00041192, vendor 0x41 [ 0.000000] VIC @f0003000: id 0x00041192, vendor 0x41 [ 0.000000] GPIO @f001a000: start 64, mask 0xffffffff (gpio 53) [ 0.000000] GPIO @f001b000: start 96, mask 0xffffffff (gpio 54) [ 0.000000] GPIO @f001c000: start 128, mask 0xffffffff (gpio 55) [ 0.000000] GPIO @f001d000: start 160, mask 0xffffffff (gpio 56) [ 0.000000] GPIO @f001e000: start 192, mask 0xffffffff (gpio 57) [ 0.000000] ALIVE @f0010800: start 224, mask 0x000000ff (alive 4) [ 0.000000] GIC @f0301000: start 256 (vic 31) [ 0.000000] timer.0: source, 10000000(HZ:250), mult:3355443200 [ 0.000000] timer.1: event , 10000000(HZ:250), mult:42949673 [ 0.000000] sched_clock: 32 bits at 250 Hz, resolution 4000000ns, wraps every 4294967292ms [ 0.000000] Console: colour dummy device 80x30 [ 0.000000] console [tty1] enabled [ 0.000000] Calibrating delay loop... 1594.36 BogoMIPS (lpj=3188736) [ 0.048000] pid_max: default: 32768 minimum: 301 [ 0.048000] Security Framework initialized [ 0.048000] SELinux: Initializing. [ 0.048000] SELinux: Starting in permissive mode [ 0.048000] Mount-cache hash table entries: 512 [ 0.048000] Initializing cgroup subsys debug [ 0.048000] Initializing cgroup subsys cpuacct [ 0.048000] Initializing cgroup subsys memory [ 0.048000] Initializing cgroup subsys freezer [ 0.048000] CPU: Testing write buffer coherency: ok [ 0.048000] CPU0: thread -1, cpu 0, socket 10, mpidr 80000a00 [ 0.048000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available [ 0.048000] Setting up static identity map for 0x4060da58 - 0x4060dab0 [ 0.048000] L310 cache controller enabled [ 0.048000] l2x0: 16 ways, CACHE_ID 0x4100c4c8, AUX_CTRL 0x70470001, Cache size: 1048576 B [ 0.092000] CPU1: thread -1, cpu 1, socket 10, mpidr 80000a01 [ 0.132000] CPU2: thread -1, cpu 2, socket 10, mpidr 80000a02 [ 0.172000] CPU3: thread -1, cpu 3, socket 10, mpidr 80000a03 [ 0.176000] Brought up 4 CPUs [ 0.176000] SMP: Total of 4 processors activated (6377.47 BogoMIPS). [ 0.176000] devtmpfs: initialized [ 0.180000] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.184000] pwm: max = 50000000 hz [ 0.184000] prepare_gpio_suspend: [ 0.184000] alfn[0][0]: 0x00000000, alfn[0][1]: 0x00000000 [ 0.184000] alfn[1][0]: 0x66800000, alfn[1][1]: 0x55555566 [ 0.184000] alfn[2][0]: 0x55555555, alfn[2][1]: 0x00555555 [ 0.184000] alfn[3][0]: 0x00000000, alfn[3][1]: 0x00000000 [ 0.184000] alfn[4][0]: 0x00000000, alfn[4][1]: 0x55540000 [ 0.184000] dummy: [ 0.184000] NET: Registered protocol family 16 [ 0.184000] [Register machine platform devices] [ 0.184000] mach: add amba device uart-pl011.0 [ 0.184000] mach: add amba device uart-pl011.1 [ 0.184000] mach: add amba device uart-pl011.3 [ 0.184000] mach: add amba device uart-pl011.4 [ 0.184000] mach: add amba device pl08xdmac.0 [ 0.184000] mach: add amba device pl08xdmac.1 [ 0.184000] mach: add amba device ssp-pl022.0 [ 0.188000] mach: add device syncgen [2] [ 0.188000] mach: add device hdmi [ 0.188000] mach: add device i2c bus (array:3) [ 0.188000] mach: add device Real Time Clock [ 0.188000] mach: add device generic pwm (array:4) [ 0.188000] mach: add device generic gpio (array:6) [ 0.188000] mach: add device i2s (array:1) [ 0.188000] mach: add device spdif tx [ 0.188000] mach: add device u***_ehci [ 0.188000] mach: add device u***_ohci [ 0.188000] mach: add device u*** otg [ 0.188000] mach: add device ion-nxp [ 0.188000] mach: add device adc [ 0.188000] mach: add graphic device opengl|es [ 0.188000] [Register board platform devices] [ 0.188000] plat: board revision 5 [ 0.188000] plat: add dynamic frequency (pll.1) [ 0.188000] plat: add framebuffer [ 0.188000] plat: boot from mmc.0 [ 0.188000] plat: add device sdmmc [0] [ 0.192000] plat: add device sdmmc [1] [ 0.192000] plat: add device sdmmc [2] [ 0.192000] plat: add backlight pwm device [ 0.192000] plat: add device keypad [ 0.192000] plat: add device spdif playback [ 0.192000] plat: add device asoc-es8316 [ 0.192000] plat: add device nxp-v4l2 [ 0.196000] plat: register spidev [ 0.196000] plat: add touch(ft5x0x) device [ 0.196000] plat: add touch(it7260) device [ 0.196000] plat: add onewire ts device [ 0.196000] plat: add adxl34x device [ 0.196000] plat: add bmp085 device [ 0.196000] plat: add ds1307 device [ 0.196000] plat: add pcf8591 device [ 0.196000] plat: add device nxp-gmac [ 0.196000] plat: add device gpio_led [ 0.196000] plat: add device pwm_led [ 0.196000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.196000] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.196000] Serial: AMBA PL011 UART driver [ 0.196000] uart-pl011.0: ttyAMA0 at MMIO 0xc00a1000 (irq = 7) is a PL011 rev3 [ 0.200000] console [ttyAMA0] enabled [ 0.204000] uart-pl011.1: ttyAMA1 at MMIO 0xc00a0000 (irq = 6) is a PL011 rev3 [ 0.208000] uart-pl011.3: ttyAMA2 at MMIO 0xc00a3000 (irq = 9) is a PL011 rev3 [ 0.212000] uart-pl011.4: ttyAMA3 at MMIO 0xc006d000 (irq = 10) is a PL011 rev3 [ 0.236000] bio: create slab [ 0.240000] gpiochip_add: registered GPIOs 0 to 31 on device: nxp-gpio.0 [ 0.244000] gpiochip_add: registered GPIOs 32 to 63 on device: nxp-gpio.1 [ 0.248000] gpiochip_add: registered GPIOs 64 to 95 on device: nxp-gpio.2 [ 0.252000] gpiochip_add: registered GPIOs 96 to 127 on device: nxp-gpio.3 [ 0.256000] gpiochip_add: registered GPIOs 128 to 159 on device: nxp-gpio.4 [ 0.260000] gpiochip_add: registered GPIOs 160 to 167 on device: nxp-gpio.5 [ 0.264000] pl08xdmac pl08xdmac.0: Unbalanced pm_runtime_enable! [ 0.268000] pl08xdmac pl08xdmac.0: initialized 8 virtual memcpy channels [ 0.272000] pl08xdmac pl08xdmac.0: initialized 16 virtual slave channels [ 0.280000] pl08xdmac pl08xdmac.0: DMA: PL080 rev1 at 0xc0000000 irq 1 [ 0.284000] pl08xdmac pl08xdmac.1: Unbalanced pm_runtime_enable! [ 0.288000] pl08xdmac pl08xdmac.1: initialized 8 virtual memcpy channels [ 0.292000] pl08xdmac pl08xdmac.1: initialized 15 virtual slave channels [ 0.296000] pl08xdmac pl08xdmac.1: DMA: PL080 rev1 at 0xc0001000 irq 2 [ 0.300000] nxp_ion_probe success!!! [ 0.304000] SCSI subsystem initialized [ 0.308000] ssp-pl022 ssp-pl022.0: ARM PL022 driver, device ID: 0x00041022 [ 0.312000] pl022: mapped registers from 0xc005b000 to f005b000 [ 0.316000] ssp-pl022 ssp-pl022.0: setup for DMA on RX dma1chan7, TX dma1chan6 [ 0.320000] ssp-pl022 ssp-pl022.0: will use autosuspend for runtime pm, delay 10ms [ 0.324000] u***core: registered new interface driver u***fs [ 0.328000] u***core: registered new interface driver hub [ 0.332000] u***core: registered new device driver u*** [ 0.336000] i2c-gpio i2c-gpio.3: using pins 159 (SDA) and 158 (SCL) [ 0.340000] nxp-i2c.0: 390625 hz [pclk=200000000, clk = 256, scale= 1, timeout= 500 ms] [ 0.348000] nxp-i2c.1: 97656 hz [pclk=200000000, clk = 256, scale= 7, timeout= 500 ms] [ 0.352000] nxp-i2c.2: 195312 hz [pclk=200000000, clk = 256, scale= 3, timeout= 500 ms] [ 0.356000] Linux media interface: v0.10 [ 0.360000] Linux video capture interface: v2.00 [ 0.364000] pps_core: LinuxPPS API ver. 1 registered [ 0.368000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.372000] PTP clock support registered [ 0.380000] axp_mfd 3-0034: AXP (CHIP ID: 0x06) detected [ 0.388000] axp22_ldo1: 3000 mV [ 0.396000] axp22_aldo1: 700 <--> 3300 mV at 3300 mV [ 0.404000] axp22_aldo2: 700 <--> 3300 mV at 1800 mV [ 0.412000] axp22_aldo3: 700 <--> 3300 mV at 1000 mV [ 0.420000] axp22_dldo1: 700 <--> 3300 mV at 3300 mV [ 0.428000] axp22_dldo2: No configuration [ 0.432000] axp22_dldo2: 700 <--> 3300 mV at 700 mV [ 0.436000] axp22_dldo3: No configuration [ 0.444000] axp22_dldo3: 700 <--> 3300 mV at 700 mV [ 0.448000] axp22_dldo4: No configuration [ 0.456000] axp22_dldo4: 700 <--> 3300 mV at 700 mV [ 0.464000] axp22_eldo1: 700 <--> 3300 mV at 1800 mV [ 0.472000] axp22_eldo2: 700 <--> 3300 mV at 3300 mV [ 0.476000] axp22_eldo3: No configuration [ 0.480000] axp22_eldo3: 700 <--> 3300 mV at 700 mV [ 0.488000] axp22_dc5ldo: No configuration [ 0.492000] axp22_dc5ldo: 700 <--> 1400 mV at 1200 mV [ 0.500000] axp22_dcdc1: 1600 <--> 3400 mV at 3300 mV [ 0.504000] axp22_dcdc2: 600 <--> 1540 mV at 1100 mV [ 0.512000] axp22_dcdc3: 600 <--> 1860 mV at 1100 mV [ 0.520000] axp22_dcdc4: 600 <--> 1540 mV at 1500 mV [ 0.532000] axp22_dcdc5: 1000 <--> 2550 mV at 1500 mV [ 0.536000] axp22_ldoio0: 700 <--> 3300 mV at 3800 mV [ 0.540000] axp22_ldoio1: 700 <--> 3300 mV at 3800 mV [ 0.548000] Advanced Linux Sound Architecture Driver Version 1.0.25. [ 0.552000] Bluetooth: Core ver 2.16 [ 0.556000] NET: Registered protocol family 31 [ 0.560000] Bluetooth: HCI device and connection manager initialized [ 0.564000] Bluetooth: HCI socket layer initialized [ 0.568000] Bluetooth: L2CAP socket layer initialized [ 0.572000] Bluetooth: SCO socket layer initialized [ 0.576000] cfg80211: Calling CRDA to update world regulatory domain [ 0.576000] Switching to clocksource source timer [ 0.604000] NET: Registered protocol family 2 [ 0.608000] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.616000] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.624000] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 0.632000] TCP: Hash tables configured (established 131072 bind 65536) [ 0.640000] TCP: reno registered [ 0.644000] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.648000] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.656000] NET: Registered protocol family 1 [ 0.660000] RPC: Registered named UNIX socket transport module. [ 0.668000] RPC: Registered udp transport module. [ 0.672000] RPC: Registered tcp transport module. [ 0.676000] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.684000] Disply Reset Status : On [ 0.688000] nxp_edid_init [ 0.688000] _edid_i2c_probe [ 0.688000] nxp_edid_init: success!!! [ 0.688000] nxp_hdmiphy_init [ 0.688000] nxp_hdmiphy_s_dv_preset: preset(8) [ 0.688000] Display HDMI register operation [ 0.692000] Display.0 fps=161 (6 ms), wait= 4 jiffies, Pixelclk=200000000hz [ 0.700000] audit: initializing netlink socket (disabled) [ 0.704000] type=2000 audit(0.704:1): initialized [ 0.720000] NFS: Registering the id_resolver key type [ 0.724000] fuse init (API version 7.18) [ 0.728000] msgmni has been set to 1620 [ 0.732000] SELinux: Registering netfilter hooks [ 0.736000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249) [ 0.740000] io scheduler noop registered [ 0.744000] io scheduler deadline registered [ 0.748000] io scheduler cfq registered (default) [ 0.756000] display.0 connected to fb.0 ... [ 0.760000] nxp-fb.0: dma addr = 0x74000000, buf[0xb3afdd00] [ 0.764000] nxp-fb.0: dma addr = 0x74384000, buf[0xb3afdec0] [ 0.816000] hdmi_stop entered [ 0.820000] nxp-fb 0: out[0], 1280 * 720 - 32 bpp (phys:74000000 virt:0xc0831000 max:7372800) [ 0.844000] Console: switching to colour frame buffer device 160x45 [ 0.872000] uart-pl011 uart-pl011.0: no DMA platform data [ 0.880000] uart-pl011 uart-pl011.1: no DMA platform data [ 0.884000] uart-pl011 uart-pl011.3: no DMA platform data [ 0.892000] uart-pl011 uart-pl011.4: no DMA platform data [ 0.900000] loop: module loaded [ 0.904000] tun: Universal TUN/TAP device driver, 1.6 [ 0.908000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com> [ 0.916000] -- nxpmac initialize -- [ 0.920000] stmmac - user ID: 0x37, Synopsys ID: 0x37 [ 0.924000] Ring mode enabled [ 0.928000] DMA HW capability register supported [ 0.932000] Enhanced/Alternate descriptors [ 0.936000] Enabled extended descriptors [ 0.940000] RX Checksum Offload Engine supported (type 2) [ 0.944000] TX Checksum insertion supported [ 0.956000] Wake-Up On Lan supported [ 0.964000] Enable RX Mitigation via HW Watchdog Timer [ 1.008000] stmmac: probed [ 1.016000] eth0: PHY ID 001cc915 at 0 IRQ 215 (stmmac-0:00) [ 1.024000] eth0: PHY ID 001cc915 at 7 IRQ 215 (stmmac-0:07) active [ 1.036000] PPP generic driver version 2.4.2 [ 1.044000] PPP BSD Compression module registered [ 1.052000] PPP Deflate Compression module registered [ 1.064000] PPP MPPE Compression module registered [ 1.072000] NET: Registered protocol family 24 [ 1.080000] u***core: registered new interface driver asix [ 1.092000] u***core: registered new interface driver cdc_ether [ 1.100000] u***core: registered new interface driver net1080 [ 1.112000] u***core: registered new interface driver cdc_subset [ 1.120000] u***core: registered new interface driver zaurus [ 1.132000] u***core: registered new interface driver cdc_ncm [ 1.140000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.152000] nxp-ehci nxp-ehci: SLsi Synopsys EHCI Host Controller [ 1.160000] nxp-ehci nxp-ehci: new USB bus registered, assigned bus number 1 [ 1.172000] nxp-ehci nxp-ehci: irq 50, io mem 0xc0030000 [ 1.192000] nxp-ehci nxp-ehci: USB 0.0 started, EHCI 1.00 [ 1.200000] u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.212000] u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.220000] u*** u***1: Product: SLsi Synopsys EHCI Host Controller [ 1.232000] u*** u***1: Manufacturer: Linux 3.4.39-FriendlyARM ehci_hcd [ 1.244000] u*** u***1: SerialNumber: nxp-ehci [ 1.252000] hub 1-0:1.0: USB hub found [ 1.260000] hub 1-0:1.0: 3 ports detected [ 1.268000] dwc_otg: version 3.00a 10-AUG-2012 (platform bus) [ 1.476000] Core Release: 2.93a [ 1.484000] Setting default values for core params [ 1.492000] Finished setting default values for core params [ 1.580000] u*** 1-1: new high-speed USB device number 2 using nxp-ehci [ 1.688000] HDMI HPD State 0x0 [ 1.708000] Using Descriptor DMA mode [ 1.716000] Dedicated Tx FIFOs mode [ 1.720000] u*** 1-1: New USB device found, idVendor=05e3, idProduct=0610 [ 1.720000] u*** 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 1.720000] u*** 1-1: Product: USB2.0 Hub [ 1.720000] hub 1-1:1.0: USB hub found [ 1.720000] hub 1-1:1.0: 4 ports detected [ 1.772000] dwc_otg: Microframe scheduler enabled [ 1.772000] dwc_otg dwc_otg: DWC OTG Controller [ 1.780000] dwc_otg dwc_otg: new USB bus registered, assigned bus number 2 [ 1.792000] dwc_otg dwc_otg: irq 49, io mem 0x00000000 [ 1.800000] u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.812000] u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.824000] u*** u***2: Product: DWC OTG Controller [ 1.832000] u*** u***2: Manufacturer: Linux 3.4.39-FriendlyARM dwc_otg_hcd [ 1.844000] u*** u***2: SerialNumber: dwc_otg [ 1.852000] hub 2-0:1.0: USB hub found [ 1.860000] hub 2-0:1.0: 1 port detected [ 1.868000] dwc_otg: FIQ disabled [ 1.868000] dwc_otg: NAK holdoff enabled [ 1.868000] dwc_otg: FIQ split fix disabled [ 1.868000] Module dwc_common_port init [ 1.868000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 1.876000] nxp-ohci nxp-ohci: SLsi Synopsys OHCI Host Controller [ 1.888000] nxp-ohci nxp-ohci: new USB bus registered, assigned bus number 3 [ 1.900000] nxp-ohci nxp-ohci: irq 50, io mem 0xc0020000 [ 1.968000] u*** u***3: New USB device found, idVendor=1d6b, idProduct=0001 [ 1.976000] u*** u***3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.988000] u*** u***3: Product: SLsi Synopsys OHCI Host Controller [ 2.000000] u*** u***3: Manufacturer: Linux 3.4.39-FriendlyARM ohci_hcd [ 2.012000] u*** u***3: SerialNumber: nxp-ohci [ 2.020000] hub 3-0:1.0: USB hub found [ 2.028000] hub 3-0:1.0: 3 ports detected [ 2.036000] Initializing USB Mass Storage driver... [ 2.048000] u***core: registered new interface driver u***-storage [ 2.056000] USB Mass Storage support registered. [ 2.068000] g_ether gadget: using random self ethernet address [ 2.076000] u***0: MAC c2:d3:e3:ca:30:9f [ 2.084000] u***0: HOST MAC 82:cf:ce:fa:44:18 [ 2.096000] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008 [ 2.108000] g_ether gadget: g_ether ready [ 2.116000] mousedev: PS/2 mouse device common for all mice [ 2.124000] input: Nexell Keypad as /devices/platform/nxp-keypad/input/input0 [ 2.136000] u***core: registered new interface driver xpad [ 2.148000] i2c-core: driver [IT7260-ts] using legacy suspend method [ 2.160000] i2c-core: driver [IT7260-ts] using legacy resume method [ 2.172000] touchscreen-1wire initialized [ 2.180000] backlight-1wire initialized [ 2.188000] input: fa_ts_input as /devices/virtual/input/input1 [ 2.200000] ts-if initialized [ 2.208000] [RTC] day=2016.01.01 time=08:00:00 [ 2.216000] nxp-rtc nxp-rtc.0: rtc core: registered nxp-rtc as rtc0 [ 2.228000] i2c /dev entries driver [ 2.236000] lirc_dev: IR Remote Control driver registered, major 248 [ 2.248000] IR NEC protocol handler initialized [ 2.256000] IR RC5(x) protocol handler initialized [ 2.264000] IR RC6 protocol handler initialized [ 2.276000] IR JVC protocol handler initialized [ 2.284000] IR Sony protocol handler initialized [ 2.292000] IR RC5 (streamzap) protocol handler initialized [ 2.304000] IR SANYO protocol handler initialized [ 2.312000] IR LIRC bridge handler initialized [ 2.324000] gspca_main: v2.14.0 registered [ 2.332000] nxp_v4l2_probe entered [ 2.332000] ...................................ov5640_probe 2234 [ 2.344000] ...................................ov5640_video_probe 2193 [ 2.356000] Fail, noack i2c.0 addr [0x78] data[0x78], trans[ 0: 2] [ 2.364000] i2c.0 addr 0x78 (try:1) [ 2.372000] Fail, noack i2c.0 addr [0x78] data[0x78], trans[ 0: 2] [ 2.384000] i2c.0 addr 0x78 (try:2) [ 2.392000] Error: i2c.0, addr:78, trans len:-11(2), try:2 [ 2.404000] Fail, noack i2c.0 addr [0x78] data[0x78], trans[ 0: 2] [ 2.412000] i2c.0 addr 0x78 (try:1) [ 2.424000] Fail, noack i2c.0 addr [0x78] data[0x78], trans[ 0: 2] [ 2.432000] i2c.0 addr 0x78 (try:2) [ 2.440000] Error: i2c.0, addr:78, trans len:-11(2), try:2 [ 2.452000] Fail, noack i2c.0 addr [0x78] data[0x78], trans[ 0: 2] [ 2.464000] i2c.0 addr 0x78 (try:1) [ 2.472000] Fail, noack i2c.0 addr [0x78] data[0x78], trans[ 0: 2] [ 2.484000] i2c.0 addr 0x78 (try:2) [ 2.492000] Error: i2c.0, addr:78, trans len:-11(2), try:2 [ 2.500000] ov5640 0-003c: reg_read: i2c read error, reg: 300a [ 2.512000] OV5640 read error!!!!!!!!!!!!!!! [ 2.520000] ov5640_initialize_ctrls.............1794........... [ 2.532000] create_nxp_out [ 2.532000] register_nxp_out [ 2.536000] u***core: registered new interface driver uvcvideo [ 2.544000] USB Video Class driver (1.1.1) [ 2.552000] Driver for 1-wire Dallas network protocol. [ 2.564000] device-mapper: uevent: version 1.0.3 [ 2.576000] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 2.588000] Bluetooth: HCI UART driver ver 2.2 [ 2.596000] Bluetooth: HCI H4 protocol initialized [ 2.608000] DVFS: ASV[0] IDS(10mA, 8) Ro(110, 97) [ 2.616000] ASV 0 = 1400000 khz, 1280 mV [ 2.616000] ASV 1 = 1200000 khz, 1200 mV [ 2.616000] ASV 2 = 1000000 khz, 1140 mV [ 2.616000] ASV 3 = 800000 khz, 1100 mV [ 2.616000] ASV 4 = 700000 khz, 1080 mV [ 2.616000] ASV 5 = 600000 khz, 1040 mV [ 2.616000] ASV 6 = 500000 khz, 1040 mV [ 2.616000] ASV 7 = 400000 khz, 1040 mV [ 2.620000] DVFS: regulator vdd_arm_1.3V [ 2.628000] DVFS: cpu DVFS with PLL.1 [tables=8] [ 2.640000] cpuidle: using governor ladder [ 2.648000] cpuidle: using governor menu [ 2.656000] Synopsys Designware Multimedia Card Interface Driver [ 2.664000] dw_mmc dw_mmc.0: Using internal DMA controller. [ 2.676000] mmc0: no vmmc regulator found [ 2.680000] dw_mmc dw_mmc.0: Using external card detect irq 225 (io 161) [ 2.692000] dw_mmc dw_mmc.0: Version ID is 250a [ 2.700000] dw_mmc dw_mmc.0: DW MMC controller at irq 43, 32 bit host data width, 32 deep fifo hw timeout 500 ms [ 2.708000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 2.724000] dw_mmc dw_mmc.1: Using PIO mode. [ 2.732000] mmc1: no vmmc regulator found [ 2.740000] dw_mmc dw_mmc.1: Version ID is 250a [ 2.748000] dw_mmc dw_mmc.1: DW MMC controller at irq 44, 32 bit host data width, 32 deep fifo hw timeout 500 ms [ 2.760000] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0) [ 2.760000] mmc0: new high speed SDHC card at address 1234 [ 2.760000] mmcblk0: mmc0:1234 SA08G 7.21 GiB [ 2.760000] mmcblk0: p1 p2 [ 2.796000] dw_mmc dw_mmc.2: Using internal DMA controller. [ 2.796000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 2.816000] mmc2: no vmmc regulator found [ 2.824000] dw_mmc dw_mmc.2: Using external card detect irq 152 (io 88) [ 2.832000] dw_mmc dw_mmc.2: Version ID is 250a [ 2.840000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 2.856000] dw_mmc dw_mmc.2: DW MMC controller at irq 45, 32 bit host data width, 32 deep fifo hw timeout 500 ms [ 2.868000] Registered led device: led1 [ 2.868000] Registered led device: led2 [ 2.868000] u***core: registered new interface driver u***hid [ 2.880000] u***hid: USB HID core driver [ 2.884000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 2.900000] ADC: CHs 8, 200000(1000000 ~ 130208) sample rate, polling mode, scale=166(bit 6) [ 2.912000] snd pcm: register sound platform 'nxp-pcm' [ 2.920000] snd i2s: ch 0, master, iis mode, 48000(47999)hz, 32 FBITs, MCLK=12287980hz, RFS=256 [ 2.936000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 3.048000] ==enable jack switch for linux== [ 3.068000] asoc: ES8316 HiFi <-> nxp-i2s.0 mapping ok [ 3.088000] input: I2S-ES8316 Headphone Jack as /devices/platform/es8316-audio.0/sound/card0/input2 [ 3.108000] spdif-tx: 48000(47348)Hz, MCLK=12121212hz HDMI out [ 3.128000] asoc: dit-hifi <-> nxp-spdif-tx mapping ok [ 3.140000] GACT probability NOT on [ 3.152000] Mirror/redirect action on [ 3.160000] u32 classifier [ 3.164000] Actions configured [ 3.172000] Netfilter messages via NETLINK v0.30. [ 3.180000] nf_conntrack version 0.5.0 (12963 buckets, 51852 max) [ 3.188000] ctnetlink v0.93: registering with nfnetlink. [ 3.200000] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 3.208000] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 3.220000] xt_time: kernel timezone is -0000 [ 3.228000] ip_tables: (C) 2000-2006 Netfilter Core Team [ 3.236000] arp_tables: (C) 2002 David S. Miller [ 3.244000] TCP: cubic registered [ 3.252000] Initializing XFRM netlink socket [ 3.260000] NET: Registered protocol family 10 [ 3.268000] Mobile IPv6 [ 3.276000] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 3.284000] IPv6 over IPv4 tunneling driver [ 3.292000] NET: Registered protocol family 17 [ 3.300000] NET: Registered protocol family 15 [ 3.308000] Bluetooth: RFCOMM TTY layer initialized [ 3.316000] Bluetooth: RFCOMM socket layer initialized [ 3.324000] Bluetooth: RFCOMM ver 1.11 [ 3.332000] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 3.340000] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 3.348000] NET: Registered protocol family 35 [ 3.356000] Registering the dns_resolver key type [ 3.364000] Registering SWP/SWPB emulation handler [ 3.376000] axp22_dcdc5: incomplete constraints, leaving on [ 3.384000] axp22_dcdc4: incomplete constraints, leaving on [ 3.392000] axp22_dcdc3: incomplete constraints, leaving on [ 3.404000] axp22_dcdc2: incomplete constraints, leaving on [ 3.412000] axp22_dcdc1: incomplete constraints, leaving on [ 3.420000] axp22_dc5ldo: incomplete constraints, leaving on [ 3.428000] axp22_eldo2: incomplete constraints, leaving on [ 3.436000] axp22_eldo1: incomplete constraints, leaving on [ 3.448000] axp22_dldo1: incomplete constraints, leaving on [ 3.456000] axp22_aldo3: incomplete constraints, leaving on [ 3.464000] axp22_aldo2: incomplete constraints, leaving on [ 3.472000] axp22_aldo1: incomplete constraints, leaving on [ 3.484000] otg_wakelock_init: No USB transceiver found [ 3.488000] nxp-rtc nxp-rtc.0: setting system clock to 2016-01-01 08:00:01 UTC (1451635201) [ 3.500000] ALSA device list: [ 3.504000] #0: I2S-ES8316 [ 3.508000] #1: SPDIF-Transciever [ 13.556000] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 128029 [ 13.556000] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 128024 [ 13.556000] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 128023 [ 13.556000] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 128016 [ 13.556000] EXT4-fs (mmcblk0p2): ext4_orphan_cleanup: deleting unreferenced inode 128011 [ 13.556000] EXT4-fs (mmcblk0p2): 5 orphan inodes deleted [ 13.568000] EXT4-fs (mmcblk0p2): recovery complete [ 14.700000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 14.716000] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 14.732000] Freeing init memory: 228K [ 14.744000] Write protecting the kernel text section 80008000 - 80818000 [ 14.752000] rodata_test: attempting to write to read-only section: [ 14.760000] write to read-only section trapped, success [ 15.148000] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 15.168000] systemd[1]: Detected architecture 'arm'. [ 15.184000] systemd[1]: Set hostname to [ 15.576000] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 15.592000] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 15.608000] systemd[1]: Expecting device dev-ttyAMA0.device... [ 15.624000] systemd[1]: Starting Remote File Systems (Pre). [ 15.632000] systemd[1]: Reached target Remote File Systems (Pre). [ 15.640000] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch. [ 15.652000] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [ 15.660000] systemd[1]: Starting Paths. [ 15.668000] systemd[1]: Reached target Paths. [ 15.676000] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point. [ 15.684000] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point. [ 15.696000] systemd[1]: Starting Encrypted Volumes. [ 15.704000] systemd[1]: Reached target Encrypted Volumes. [ 15.712000] systemd[1]: Starting Swap. [ 15.720000] systemd[1]: Reached target Swap. [ 15.728000] systemd[1]: Starting Root Slice. [ 15.732000] systemd[1]: Created slice Root Slice. [ 15.740000] systemd[1]: Starting User and Session Slice. [ 15.748000] systemd[1]: Created slice User and Session Slice. [ 15.756000] systemd[1]: Starting /dev/initctl Compatibility Named Pipe. [ 15.768000] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [ 15.776000] systemd[1]: Starting Delayed Shutdown Socket. [ 15.784000] systemd[1]: Listening on Delayed Shutdown Socket. [ 15.792000] systemd[1]: Starting Journal Socket (/dev/log). [ 15.804000] systemd[1]: Listening on Journal Socket (/dev/log). [ 15.812000] systemd[1]: Starting udev Control Socket. [ 15.820000] systemd[1]: Listening on udev Control Socket. [ 15.828000] systemd[1]: Starting udev Kernel Socket. [ 15.836000] systemd[1]: Listening on udev Kernel Socket. [ 15.844000] systemd[1]: Starting Journal Socket. [ 15.852000] systemd[1]: Listening on Journal Socket. [ 15.860000] systemd[1]: Starting System Slice. [ 15.868000] systemd[1]: Created slice System Slice. [ 15.876000] systemd[1]: Starting system-getty.slice. [ 15.884000] systemd[1]: Created slice system-getty.slice. [ 15.892000] systemd[1]: Starting system-serialx2dgetty.slice. [ 15.900000] systemd[1]: Created slice system-serialx2dgetty.slice. [ 15.908000] systemd[1]: Starting Increase datagram queue length... [ 15.920000] systemd[1]: Mounted Huge Pages File System. [ 15.928000] systemd[1]: Mounted POSIX Message Queue File System. [ 15.940000] systemd[1]: Starting Create list of required static device nodes for the current kernel... [ 15.956000] systemd[1]: Mounting Debug File System... [ 16.008000] systemd[1]: Started Set Up Additional Binary Formats. [ 16.016000] systemd[1]: Starting Load Kernel Modules... [ 16.028000] systemd[1]: Starting udev Coldplug all Devices... [ 16.036000] systemd[1]: Starting Slices. [ 16.044000] systemd[1]: Reached target Slices. [ 16.052000] systemd[1]: Mounted Debug File System. [ 16.092000] systemd[1]: Started Increase datagram queue length. [ 16.124000] dhd_module_init: in [ 16.124000] ======== bcm_wlan_set_plat_data ======== [ 16.124000] host_oob_irq: 145 [ 16.124000] host_oob_irq_flags = 414 [ 16.124000] dhd_wifi_platform_load: Enter [ 16.124000] Power-up adapter 'DHD generic adapter' [ 16.124000] wifi_platform_set_power = 1 [ 16.124000] ======== PULL WL_REG_ON HIGH! ======== [ 16.124000] wifi_pm: bcmdhd: 1 [ 16.156000] systemd[1]: Started Create list of required static device nodes for the current kernel. [ 16.168000] systemd[1]: Starting Create Static Device Nodes in /dev... [ 16.180000] systemd[1]: Starting Syslog Socket. [ 16.188000] systemd[1]: Listening on Syslog Socket. [ 16.196000] systemd[1]: Starting Journal Service... [ 16.204000] systemd[1]: Started Journal Service. [ 16.348000] systemd-udevd[109]: starting version 215 [ 16.440000] wifi_platform_bus_enumerate device present 1 [ 16.456000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 16.516000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 16.584000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 16.652000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 16.932000] systemd-journald[108]: Received request to flush runtime journal from PID 1 [ 17.640000] failed to power up DHD generic adapter, 1 retry left [ 17.656000] wifi_platform_set_power = 0 [ 17.656000] ======== PULL WL_REG_ON LOW! ======== [ 17.656000] wifi_pm: bcmdhd: 0 [ 17.728000] eth0: device MAC address 16:82:da:12:71:24 [ 17.768000] wifi_platform_bus_enumerate device present 0 [ 17.768000] failed to power up DHD generic adapter, max retry reached** [ 17.768000] unregister wifi platform drivers [ 17.768000] wifi_platform_bus_enumerate device present 0 [ 17.768000] dhd_module_init: Failed to load the driver, try cnt 1 [ 17.768000] ======== bcm_wlan_set_plat_data ======== [ 17.768000] host_oob_irq: 145 [ 17.768000] host_oob_irq_flags = 414 [ 17.768000] dhd_wifi_platform_load: Enter [ 17.768000] Power-up adapter 'DHD generic adapter' [ 17.768000] wifi_platform_set_power = 1 [ 17.768000] ======== PULL WL_REG_ON HIGH! ======== [ 17.768000] wifi_pm: bcmdhd: 1 [ 18.084000] wifi_platform_bus_enumerate device present 1 [ 18.100000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) [ 18.164000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 300000Hz, actual 297619HZ div = 84) [ 18.232000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 200000Hz, actual 200000HZ div = 125) [ 18.308000] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 100000Hz, actual 100000HZ div = 250) [ 19.284000] failed to power up DHD generic adapter, 1 retry left [ 19.300000] wifi_platform_set_power = 0 [ 19.300000] ======== PULL WL_REG_ON LOW! ======== [ 19.300000] wifi_pm: bcmdhd: 0 [ 19.412000] wifi_platform_bus_enumerate device present 0 [ 19.412000] failed to power up DHD generic adapter, max retry reached** [ 19.412000] unregister wifi platform drivers [ 19.412000] wifi_platform_bus_enumerate device present 0 [ 19.416000] dhd_module_init: Failed to load the driver, try cnt 0 [ 19.416000] dhd_module_init: Failed to load driver max retry reached** [ 19.416000] dhd_module_init: Exit err=-19 [ 21.032000] PHY: stmmac-0:07 - Link is Up - 1000/Full [ 26.812000] ADDRCONF(NETDEV_UP): u***0: link is not ready [ 51.988000] EXT4-fs (mmcblk0p1): recovery complete [ 51.996000] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null) 看不出有啥问题,请大神指点一下。 |
7个回答
出现这种问题也是有可能的,对于nanopi来说,他的有效网口是千兆网络,其信号速度不一样,信号完整性要求也就高了,建议你换一根好点的网线,起码5元一米的那种,换线后问题应该能解决
grarrow 发表于 2016-3-20 16:35 谢谢你的回答。 不过,网线是网件WDNR7500配的,至少也是七类网线了。 而且我除了树莓派是百兆,其他设备统统是千兆。环境肯定不会有问题。今天又看了一会,系统层面感觉都没有问题,应该是硬件问题了。 你的说法一开始我也怀疑了,还专门拿了一台ar9331芯片的百兆设备,接口变成百兆了,但是依然一样的问题。 |
先用 dmesg | grep "not ready"
看看是不是有很多斷線然後 PHY 又重啟的訊息, [xxxxxx] ADDRCONF(NETDEV_UP): u***0: link is not ready 我之前是有時候會這樣,網路斷個幾秒,估計是散熱問題。在散熱片上再黏上一片散熱片,好像沒再出現。 补充内容 (2016-3-20 22:08): dmesg | grep "Link is Down" [ xxxxx.xxxxx] PHY: stmmac-0:07 - Link is Down [ xxxxx.xxxxx] PHY: stmmac-0:07 - Link is Up - 1000/Full |
十分感谢!! 1,立马启动立马测试,不至于过热。而且我已经贴了官方卖的散热片了。 2,看了很多次系统消息,网络是正常的。u***0那个是虚拟网卡的,没插肯定是not ready。 下面截图消息,你看下: 唯一的解释就是网卡芯片坏了,或者网口的网络变压器坏了。设计问题应该不至于,不然就所有人都这样了。 |
只有小组成员才能发言,加入小组>>
352个成员聚集在这个小组
加入小组NanoPi m3适合刷什么系统,刚接触玩,我刷了一个比较卡
2424 浏览 1 评论
6913 浏览 1 评论
4615 浏览 1 评论
【NanoPC-T4试用体验】4、手把手教你从单片机移植驱动到ARM Linux上
7344 浏览 1 评论
【NanoPC-T4试用体验】NanoPC-T4控制步进电机
24287 浏览 1 评论
2441浏览 1评论
232浏览 0评论
GMT+8, 2024-4-24 21:32 , Processed in 1.279715 second(s), Total 85, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
