The CJC5340 is a complete analog-to-digital converter for digital audio systems. It performs sampling, analogto-digital conversion, and anti-alias filtering, generating 24-bit values for both left and right inputs in serial format sample rates up to 200 kHz per channel. The CJC5340 uses a 5th-order, multi-bit Delta-Sigma modulator followed by digital filtering and decimation,which removes the need for an external anti-alias filter.The CJC5340 is available in a 16-pin TSSOP package for Commercial (-10° to +70° C) and Automotive grades (-40° to +85° C). The CJC5340 is ideal for audio systems requiring wide dynamic range, negligible distortion and low noise, such as set-top boxes, DVD-karaoke players, DVD recorders, A/V receivers, and automotive applications. ♦ Advanced Multi-bit Delta-Sigma Architecture ♦ 24-bit Conversion ♦ Supports All Audio Sample Rates Including 192 kHz ♦ -92 dB THD+N ♦ 90 mW Power Consumption ♦ High-Pass Filter to Remove DC Offsets ♦ Analog/Digital Core Supplies from 2.4 V to 3.6V ♦ Supports Logic Levels from 2.4V to 3.6 V ♦ Auto-detect Mode Selection in Slave Mode ♦ Auto-Detect MCLK Divider |
性能
双列贴片TSSOP16脚封装。24位到192KHz两通道立体声ADC,3.3V-5V电压工作,取样频率从32KHz到192KHz,动态范围为101dB,失真+噪声(THD+N)为95dB,单端输入结构,线性相位数字抗混淆滤波,高通滤波滤掉DC失调。 深圳锦宏科技 技术支持 151 1247 6010 莫先生 CJC5340是一个完全为数字音频系统从模拟到数字转换的IC,它完成取样、数模转换、抗共模滤波、为串行格式取样率达200KHz每通道的左右通道输入信号生成24比特值。它有两个模式(主模式和从模式),主模式就是只需要一个主时钟就可以工作了;从模式则需要主时钟和左右时钟和位时钟。 CJC5340是音频系统要求宽动态范围、低失真和低噪声的理想器件,应用于机顶盒、DVD卡拉OK播放器、DVD***接收器和车载电器。 二、特点 1、先进的多位Delta-Sigma体系 2、24比特转换 3、支持所有音频取样率包括192KHz 4、5V电源时动态范围101dB 5、—94dB TDH+N 6、高通滤波免去直流偏置 7、3.3V-5V的模数核心供电 8、支持逻辑电平值在1.8V到5V间 9、低潜伏时间数字滤波器 10、自动模式选择 |
3268 浏览 0 评论
5342 浏览 0 评论
《电子工程师必备——九大系统电路识图宝典》之浅读负反馈以及四种组态
4042 浏览 0 评论
2039 浏览 0 评论
59495 浏览 0 评论
GMT+8, 2024-4-19 10:20 , Processed in 0.365929 second(s), Total 41, Slave 30 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
