Description: The ADXL377 is a small, thin, low power, complete 3-axis accelerometer with signal conditioned analog voltage outputs that has a full-scale range of ±200g for measuring more extreme changes in motion, shock or vibration. This board has broken out all the pins you’ll need to get the necessary data from the accelerometers. The breakout is perfect for applications like concussion and head trauma detection or high force event detection. Getting the ADXL377 Breakout set-up is easy. Simply supply the accelerometer with power (3.3V and GND), then hookup the X, Y, and Z lines of the sensor to ADC pins on your chosen development board and you will be good to go. Bandwidths can even be selected to suit the needed application, with a range of 0.5 Hz to 1600 Hz for X and Y axes and a range of 0.5 Hz to 550 Hz for the Z axis. It should be noted that this breakout has a maximum voltage of 3.6V. Fortunately, you won’t need a lot of power to make the accelerometers work. In normal operating mode they typically draw about 300 µA. Features: Operating Voltage: 1.8V - 3.6V GitHub (Design Files & Example Code)
ADXL377 Breakout-v10 SCH ADXL377 Breakout-v10 PCB EasyEDA项目链接:https://easyeda.com/oshw/Triple_Axis_Accelerometer_Breakout_ADXL377_Open_hardware-0u0iAtL3l EasyEDA链接:https://easyeda.com |
1 个讨论
只有小组成员才能发言,加入小组>>
GMT+8, 2024-3-29 21:21 , Processed in 0.393647 second(s), Total 44, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
