扫一扫,分享给好友
运行代码如下:
INFO:iMPACT - Digilent Plugin: Plugin Version: 2.4.4 INFO:iMPACT - Digilent Plugin: no JTAG device was found. AutoDetecting cable. Please wait. *** WARNING ***: When port is set to auto detect mode, cable speed is set to default 6 MHz regardless of explicit arguments supplied for setting the baud rates PROGRESS_START - Starting Operation. Connecting to cable (U*** Port - USB21). Checking cable driver. Driver file xu***_xlp.sys found. Driver version: src=1029, dest=1029. Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170. Invalid device driver license. Cable connection failed. Connecting to cable (Parallel Port - LPT1). Checking cable driver. Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170. Cable connection failed. Connecting to cable (Parallel Port - LPT2). Checking cable driver. Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170. Cable connection failed. Connecting to cable (Parallel Port - LPT3). Checking cable driver. Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170. Cable connection failed. Connecting to cable (Parallel Port - LPT4). Checking cable driver. Driver windrvr6.sys version = 11.7.0.0. WinDriver v11.7.0 Jungo Connectivity (c) 1997 - 2014 Build Date: Oct 26 2014 X86 32bit SYS 09:05:06, version = 1170. Cable connection failed. PROGRESS_END - End Operation. Elapsed time = 31 sec. Cable autodetection failed. WARNING:iMPACT:923 - Can not find cable, check cable setup !Enumerating cables. Please wait. 下载器上的绿灯是绿着的。 我不太理解为啥会说Invalid device driver license.有人跟我说是ISE版本问题,我重装了还这样。 另外我不插任何设备时执行 initialize chain 也是这个提示 试过重装xilink驱动,重装windriver,重装ISE 14.7 都是老样子。
7个回答
把xcf04s这个芯片里面擦一下试试,我之前也是你说的这个原因,擦了一下FLASH就好了
解决了吗 楼主 求教去一下 我也遇到这个问题了
重新装一下驱动,实在不行装个驱动精灵来装驱动也行,最后再不行上digilent官网下驱动
win7 64位系统,安装没有问题,驱动安装也没有问题,重启电脑和软件,也拔插过jtag多次,不能解决问题,请问各位怎么解决?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
800 浏览 0 评论
354 浏览 0 评论
1070 浏览 0 评论
374 浏览 0 评论
FPGA零基础学习系列精选:半导体存储器和可编程逻辑器件简介
1001 浏览 0 评论
1421 浏览 35 评论
GMT+8, 2024-4-23 15:06 , Processed in 0.405939 second(s), Total 48, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
