扫一扫,分享给好友
#define CCxxx0_IOCFG2 0x00 // GDO2 output pin configuration
#define CCxxx0_IOCFG1 0x01 // GDO1 output pin configuration #define CCxxx0_IOCFG0 0x02 // GDO0 output pin configuration #define CCxxx0_FIFOTHR 0x03 // RX FIFO and TX FIFO thresholds #define CCxxx0_SYNC1 0x04 // Sync word, high INT8U #define CCxxx0_SYNC0 0x05 // Sync word, low INT8U #define CCxxx0_PKTLEN 0x06 // Packet length #define CCxxx0_PKTCTRL1 0x07 // Packet automation control #define CCxxx0_PKTCTRL0 0x08 // Packet automation control #define CCxxx0_ADDR 0x09 // Device address #define CCxxx0_CHANNR 0x0A // Channel number #define CCxxx0_FSCTRL1 0x0B // Frequency synthesizer control #define CCxxx0_FSCTRL0 0x0C // Frequency synthesizer control #define CCxxx0_FREQ2 0x0D // Frequency control word, high INT8U #define CCxxx0_FREQ1 0x0E // Frequency control word, middle INT8U #define CCxxx0_FREQ0 0x0F // Frequency control word, low INT8U #define CCxxx0_MDMCFG4 0x10 // Modem configuration #define CCxxx0_MDMCFG3 0x11 // Modem configuration #define CCxxx0_MDMCFG2 0x12 // Modem configuration #define CCxxx0_MDMCFG1 0x13 // Modem configuration #define CCxxx0_MDMCFG0 0x14 // Modem configuration #define CCxxx0_DEVIATN 0x15 // Modem deviation setting #define CCxxx0_MCSM2 0x16 // Main Radio Control State Machine configuration #define CCxxx0_MCSM1 0x17 // Main Radio Control State Machine configuration #define CCxxx0_MCSM0 0x18 // Main Radio Control State Machine configuration #define CCxxx0_FOCCFG 0x19 // Frequency Offset Compensation configuration #define CCxxx0_BSCFG 0x1A // Bit Synchronization configuration #define CCxxx0_AGCCTRL2 0x1B // AGC control #define CCxxx0_AGCCTRL1 0x1C // AGC control #define CCxxx0_AGCCTRL0 0x1D // AGC control #define CCxxx0_WOREVT1 0x1E // High INT8U Event 0 timeout #define CCxxx0_WOREVT0 0x1F // Low INT8U Event 0 timeout #define CCxxx0_WORCTRL 0x20 // Wake On Radio control #define CCxxx0_FREND1 0x21 // Front end RX configuration #define CCxxx0_FREND0 0x22 // Front end TX configuration #define CCxxx0_FSCAL3 0x23 // Frequency synthesizer calibration #define CCxxx0_FSCAL2 0x24 // Frequency synthesizer calibration #define CCxxx0_FSCAL1 0x25 // Frequency synthesizer calibration #define CCxxx0_FSCAL0 0x26 // Frequency synthesizer calibration #define CCxxx0_RCCTRL1 0x27 // RC oscillator configuration #define CCxxx0_RCCTRL0 0x28 // RC oscillator configuration #define CCxxx0_FSTEST 0x29 // Frequency synthesizer calibration control #define CCxxx0_PTEST 0x2A // Production test #define CCxxx0_AGCTEST 0x2B // AGC test #define CCxxx0_TEST2 0x2C // Various test settings #define CCxxx0_TEST1 0x2D // Various test settings #define CCxxx0_TEST0 0x2E // Various test settings // Strobe commands #define CCxxx0_SRES 0x30 // Reset chip. #define CCxxx0_SFSTXON 0x31 // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL=1). // If in RX/TX: Go to a wait state where only the synthesizer is // running (for quick RX / TX turnaround). #define CCxxx0_SXOFF 0x32 // Turn off crystal oscillator. #define CCxxx0_SCAL 0x33 // Calibrate frequency synthesizer and turn it off // (enables quick start). #define CCxxx0_SRX 0x34 // Enable RX. Perform calibration first if coming from IDLE and // MCSM0.FS_AUTOCAL=1. #define CCxxx0_STX 0x35 // In IDLE state: Enable TX. Perform calibration first if // MCSM0.FS_AUTOCAL=1. If in RX state and CCA is enabled: // Only go to TX if channel is clear. #define CCxxx0_SIDLE 0x36 // Exit RX / TX, turn off frequency synthesizer and exit // Wake-On-Radio mode if applicable. #define CCxxx0_SAFC 0x37 // Perform AFC adjustment of the frequency synthesizer #define CCxxx0_SWOR 0x38 // Start automatic RX polling sequence (Wake-on-Radio) #define CCxxx0_SPWD 0x39 // Enter power down mode when CSn goes high. #define CCxxx0_SFRX 0x3A // Flush the RX FIFO buffer. #define CCxxx0_SFTX 0x3B // Flush the TX FIFO buffer. #define CCxxx0_SWORRST 0x3C // Reset real time clock. #define CCxxx0_SNOP 0x3D // No operation. May be used to pad strobe commands to two // INT8Us for simpler software. #define CCxxx0_PARTNUM 0x30 #define CCxxx0_VERSION 0x31 #define CCxxx0_FREQEST 0x32 #define CCxxx0_LQI 0x33 #define CCxxx0_RSSI 0x34 #define CCxxx0_MARCSTATE 0x35 #define CCxxx0_WORTIME1 0x36 #define CCxxx0_WORTIME0 0x37 #define CCxxx0_PKTSTATUS 0x38 #define CCxxx0_VCO_VC_DAC 0x39 #define CCxxx0_TXBYTES 0x3A #define CCxxx0_RXBYTES 0x3B #define CCxxx0_PATABLE 0x3E #define CCxxx0_TXFIFO 0x3F #define CCxxx0_RXFIFO 0x3F |
4个回答
上面是 寄存器配置
接收程序的代码 进中断
u8 halRfReceivePacket(void) { u8 status[2]={0}; u8 packetLength=0; if ((halSpiReadStatus(CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) //如果接的字节数不为0 { packetLength = halSpiReadReg(CCxxx0_RXFIFO);//读出第一个字节,此字节为该帧数据长度 if (packetLength <= length) //如果所要的有效数据长度小于等于接收到的数据包的长度 { halSpiReadBurstReg(CCxxx0_RXFIFO, RxBuf, packetLength); //读出所有接收到的数据 length = packetLength; //把接收数据长度的修改为当前数据的长度 // Read the 2 appended status bytes (status[0] = RSSI, status[1] = LQI) halSpiReadBurstReg(CCxxx0_RXFIFO, status, 2); //读出CRC校验位 halSpiStrobe(CCxxx0_SFRX); //清洗接收缓冲区 Rx_flag =TRUE; return ((status[1] & CRC_OK)); //如果校验成功返回接收成功 } else { length = packetLength; halSpiStrobe(CCxxx0_SFRX); //清洗接收缓冲区 return 0; } } else return 0; } |
if (packetLength <= length) //如果所要的有效数据长度小于等于接收到的数据包的长度 length这个参数需要修改一下。。。 |
只有小组成员才能发言,加入小组>>
物联网工程师必备:怎么选择不同的无线连接技术,本指南帮你忙!
2921 浏览 1 评论
【DFRobot TinkerNode NB-IoT 物联网开发板试用连载】WIFI功能测试
3589 浏览 0 评论
【DFRobot TinkerNode NB-IoT 物联网开发板试用连载】Arduino的替代SublimeText3+STino
3119 浏览 0 评论
使用端口扩展器轻松高效地向IIoT端点添加具有成本效益的子节点
3613 浏览 1 评论
19992 浏览 11 评论
2606浏览 1评论
245浏览 1评论
Banana Pi BPI-Centi-S3 是一个板载1.9英寸彩屏的小尺寸ESP32-S3开发板
1053浏览 0评论
8019浏览 0评论
8092浏览 0评论
GMT+8, 2024-4-25 21:11 , Processed in 0.890887 second(s), Total 82, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
