扫一扫,分享给好友
我下载了PSPICE模型.LIB文件,怎么将LIB转化为olb文件呢?下面是LIB文件里面的内容,求大神帮忙
.SUBCKT mtp10n10el 1 2 3 ************************************** * Model Generated by MODPEX * *Copyright(c) Symmetry Design Systems* * All Rights Reserved * * UNPUBLISHED LICENSED SOFTWARE * * Contains Proprietary Information * * Which is The Property of * * SYMMETRY OR ITS LICENSORS * *Commercial Use or Resale Restricted * * by Symmetry License Agreement * ************************************** * Model generated on Mar 4, 05 * MODEL FORMAT: PSpice * Symmetry POWER MOS Model (Version 1.0) * External Node Designations * Node 1 -> Drain * Node 2 -> Gate * Node 3 -> Source M1 9 7 8 8 MM L=100u W=100u * Default values used in MM: * The voltage-dependent capacitances are * not included. Other default values are: * RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0 .MODEL MM NMOS LEVEL=1 IS=1e-32 +VTO=2.01695 LAMBDA=0.0227696 KP=15.3463 +CGSO=7.12982e-06 CGDO=1e-11 RS 8 3 0.0535411 D1 3 1 MD .MODEL MD D IS=2.56672e-09 RS=0.0178012 N=1.39453 BV=100 +IBV=0.00025 EG=1 XTI=2.98993 TT=0 +CJO=8.28903e-10 VJ=0.745168 M=0.498774 FC=0.5 RDS 3 1 4e+09 RD 9 1 0.0953186 RG 2 7 20.3902 D2 4 5 MD1 * Default values used in MD1: * RS=0 EG=1.11 XTI=3.0 TT=0 * BV=infinite IBV=1mA .MODEL MD1 D IS=1e-32 N=50 +CJO=4.53501e-10 VJ=0.72742 M=0.9 FC=1e-08 D3 0 5 MD2 * Default values used in MD2: * EG=1.11 XTI=3.0 TT=0 CJO=0 * BV=infinite IBV=1mA .MODEL MD2 D IS=1e-10 N=0.423452 RS=3e-06 RL 5 10 1 FI2 7 9 VFI2 -1 VFI2 4 0 0 EV16 10 0 9 7 1 CAP 11 10 4.53501e-10 FI1 7 9 VFI1 -1 VFI1 11 6 0 RCAP 6 10 1 D4 0 6 MD3 * Default values used in MD3: * EG=1.11 XTI=3.0 TT=0 CJO=0 * RS=0 BV=infinite IBV=1mA .MODEL MD3 D IS=1e-10 N=0.423452 .ENDS mtp10n10el |
1个回答
只有小组成员才能发言,加入小组>>
如何用AD844运算放大器完成双二阶滤波器的Pspice仿真
4427 浏览 0 评论
PSPICE二极管Model,修改结电压参数Vj0后,仿真导通电压不变?
3279 浏览 1 评论
4748 浏览 3 评论
3131 浏览 2 评论
我给导线一个网络节点,命名为V2,请问为什么在直流扫描的时候识别不了呢?
3466 浏览 0 评论
Cadence capture原理图中如果有没连接的电源符号,可以通过什么方式检查出来
10227浏览 1评论
5069浏览 1评论
960浏览 0评论
新手做pspice仿真,没有找到C3M0032120K的pspice模型,改用STW56N65M2-4_TN代替,仿真出现一堆问题,求帮助
3188浏览 0评论
GMT+8, 2024-4-25 09:44 , Processed in 0.397329 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
