Linear 公司的LTCR3625/LTC3625-1是可编程超大电容充电器,能从2.7V-5.5V输入电源中给两个串联电容充电到4.8V/5.3V 或 4V/4.5V,可进行高效的降压/升压充电,并自动平衡电池的充电以免受损害。充电电流高达500mA(一个电感)或1A(两个电感),主要用在服务器,RAID系统,海量存储,大电流备份电源,固态硬驱动,无线功率表以及高峰值功率升压电源。本文介绍了LTCR3625/LTC3625-1主要特性,方框图,1A SCAP充电器,太阳能供电SCAP 充电器,以及5V和12V电源。
The LTCR3625/LTC3625-1 are programmable supercapacitor chargers designed to charge two supercapacitors in series to a fixed output voltage (4.8V/5.3V or 4V/4.5V selectable) from a 2.7V to 5.5V input supply. Automatic cell balancing prevents overvoltage damage to either supercapacitor while maximizing charge rate. No balancing resistors are required. High efficiency, high charging current, low quiescent current and low minimum external parts count (one inductor, one bypass capacitor at VIN and one programming resistor) make the LTC3625/LTC3625-1 ideally suited for small form factor backup or high peak power systems. Charging current/maximum input current level is programmed with an external resistor. When the input supply is removed and/or the EN pin is low, the LTC3625/LTC3625-1 automatically enter a low current state, drawing less than 1μA from the supercapacitors. The LTC3625/LTC3625-1 are available in a compact 12 lead 3mmx 4mmx0.75mm DFN package. LTCR3625/LTC3625-1主要特性: High Efficiency Step-Up/Step-Down Charging of Two Series Supercapacitors Automatic Cell Balancing Prevents Capacitor Overvoltage During Charging Programmable Charging Current Up to 500mA (Single Inductor), 1A (Dual Inductor) VIN = 2.7V to 5.5V Selectable 2.4V/2.65V Regulation per Cell (LTC3625) Selectable 2V/2.25V Regulation per Cell (LTC3625-1) Low No-Load Quiescent Current: 23μA IVOUT, IVIN < 1μA in Shutdown Low Profile 12-lead 3mmx 4mm DFN Package LTCR3625/LTC3625-1应用: Servers, RAID Systems, Mass Storage, High Current Backup Supplies Solid State Hard Drives Wireless Power Meters High Peak Power Boosted Supplies 图1。LTCR3625/LTC3625-1方框图 图2。LTCR3625 1A SCAP充电器 图3。LTCR3625-1 450mA 充电器 图4。LTCR3625太阳能供电SCAP 充电器 图5。LTCR3625 5V电源 图6。LTCR3625 12V电源 |
相关推荐 |
只有小组成员才能发言,加入小组>>
18193 浏览 1 评论
1416 浏览 2 评论
6056 浏览 0 评论
基于峰岹的FU6813L波轮洗衣机控制方案(原理图+PCB+源程序
47911 浏览 1 评论
59893 浏览 0 评论
70710浏览 3评论
1416浏览 2评论
124821浏览 1评论
57625浏览 1评论
80804浏览 1评论
GMT+8, 2024-3-29 09:59 , Processed in 0.810604 second(s), Total 56, Slave 40 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 深圳华秋电子有限公司
电子发烧友 (电路图) 粤公网安备 44030402000349 号 电信与信息服务业务经营许可证:合字B2-20210191 工商网监 湘ICP备2023018690号
