使用mcsdk中的edma3lld库写的edma3驱动,在omapl138的dsp核运行,但是中断函数只能进去一次,路过的朋友帮忙看看,感谢万分。代码如下:
#define PING_PONG_ACNT 1 #define PING_PONG_BCNT 8*32*40 //#define PING_PONG_BCNT 1 #define PING_PONG_CCNT 1 #define MCASP_BASEADDR 0x01D00000 #define Mcasp_RXEVENTQUE (0u) /* OPT Field specific defines */ #define OPT_SYNCDIM_SHIFT (0x00000002u) #define OPT_TCC_MASK (0x0003F000u) #define OPT_TCC_SHIFT (0x0000000Cu) #define OPT_ITCINTEN_SHIFT (0x00000015u) #define OPT_TCINTEN_SHIFT (0x00000014u) char ping_buffer[PING_PONG_BCNT]; char pong_buffer[PING_PONG_BCNT]; static void ys_edma3_init() { EDMA3_DRV_PaRAMRegs paramSet = {0,0,0,0,0,0,0,0,0,0,0,0}; EDMA3_DRV_Result result = EDMA3_DRV_SOK; EDMA3_DRV_Handle hEdma; uint32_t chId = 0; uint32_t tcc = 0; print2arm("edma3 driver init...",0); hEdma = edma3init(0,&result); if(hEdma) { print2arm("edma3init() Passed.",0); } else { print2arm("edma3init() Failed.",0); } if (result == EDMA3_DRV_SOK) { result = EDMA3_DRV_requestChannel (hEdma, &chId, &tcc, (EDMA3_RM_EventQueue)0, &edma3_isr, NULL); } if(result == EDMA3_DRV_SOK) { paramSet.srcBIdx = 0; paramSet.destBIdx = 1; paramSet.srcCIdx = 0; paramSet.destCIdx = 0; paramSet.aCnt = PING_PONG_ACNT; paramSet.bCnt = PING_PONG_BCNT; paramSet.cCnt = PING_PONG_CCNT; /* For AB-synchronized transfers, BCNTRLD is not used. */ paramSet.bCntReload = PING_PONG_BCNT; /* Src in constant mode Dest in INCR modes */ paramSet.opt &= 0xFFFFFFFDu; //paramSet.opt &= 0xFFFFFFFCu; /* Program the TCC */ paramSet.opt |= ((tcc << OPT_TCC_SHIFT) & OPT_TCC_MASK); /* Enable Intermediate & Final transfer completion interrupt */ paramSet.opt |= (1 << OPT_ITCINTEN_SHIFT); paramSet.opt |= (1 << OPT_TCINTEN_SHIFT); /* AB Sync Transfer Mode */ paramSet.opt |= (1 << OPT_SYNCDIM_SHIFT); /* Program the source and dest addresses for master DMA channel */ paramSet.srcAddr = (uint32_t)(MCASP_BASEADDR+0X029C); paramSet.destAddr = (uint32_t)(ping_buffer); /* Write to the master DMA channel first. */ result = EDMA3_DRV_setPaRAM(hEdma, chId, ¶mSet); } result = EDMA3_DRV_enableTransfer(hEdma,chId,EDMA3_DRV_TRIG_MODE_EVENT); if(result == EDMA3_DRV_SOK) { print2arm("edma3 driver init success.",0); } } EDMA3的配置就这个函数,是由MCASP接收事件触发EDMA3传输的,中断函数edma3_isr只能进去一次,请大家帮忙看看哪里有问题。。。 |
3个回答
中断退出的时候,检查中断使能位,中断标志位,总中断使能位
支持!!!!!!!!!!!!!!!
看看看看看看看看,看看看看看看看看
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式操作教程_数字信号处理_音频编解码:3-6 AAC音频解码实验
423 浏览 0 评论
数字信号处理实验操作教程:3-3 mp3音频编码实验(AD7606采集)
1313 浏览 0 评论
嵌入式DSP教学实验箱操作教程:2-20 数模转换实验(模拟SPI总线输出电压值)
1325 浏览 0 评论
目前在2837x系列用的最多的、性能最好、性价比最高的是哪一款?
1089 浏览 0 评论
国产嵌入式DSP教学实验箱_操作教程:22-AD采集DA输出实验(采集输出正弦波)
2275 浏览 0 评论
GMT+8, 2024-4-23 16:47 , Processed in 0.626689 second(s), Total 74, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
