扫一扫,分享给好友
我在使用ICETEK-F28335-A实验板,以及SEED-XD560PLUS仿真器,在CCS4.2.0027 (UNLICENSED)中成功进入DEBUG,调试ti官方的例程
FILE: Example_2823xAdcSeqModeTest.c // // TITLE: DSP2823x ADC Seq Mode Test. 编译不报错无警告,但是无法完成AD转换,连随机电平都读不到,我怀疑是AD整体不工作,观察AdcRegs.ADCTRL2.bit.SOC_SEQ1及AdcRegs.ADCRESULT0,其中AdcRegs.ADCTRL2.bit.SOC_SEQ1一直为1,而AdcRegs.ADCRESULT0一直为0 上程序 #include "DSP28x_Project.h" // Device Headerfile and Examples Include File // ADC start parameters #if (CPU_FRQ_150MHZ) // Default - 150 MHz SYSCLKOUT #define ADC_MODCLK 0x3 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 150/(2*3) = 25.0 MHz #endif #if (CPU_FRQ_100MHZ) #define ADC_MODCLK 0x2 // HSPCLK = SYSCLKOUT/2*ADC_MODCLK2 = 100/(2*2) = 25.0 MHz #endif #define ADC_CKPS 0x1 // ADC module clock = HSPCLK/2*ADC_CKPS = 25.0MHz/(1*2) = 12.5MHz #define ADC_SHCLK 0xf // S/H width in ADC module periods = 16 ADC clocks #define AVG 1000 // Average sample limit #define ZOFFSET 0x00 // Average Zero offset #define BUF_SIZE 2048 // Sample buffer size // Global variable for this example Uint16 SampleTable[BUF_SIZE]; main() { Uint16 i; // Step 1. Initialize System Control: // PLL, WatchDog, enable Peripheral Clocks // This example function is found in the DSP2833x_SysCtrl.c file. InitSysCtrl(); // Specific clock setting for this example: EALLOW; SysCtrlRegs.HISPCP.all = ADC_MODCLK; // HSPCLK = SYSCLKOUT/ADC_MODCLK EDIS; // Step 2. Initialize GPIO: // This example function is found in the DSP2833x_Gpio.c file and // illustrates how to set the GPIO to it's default state. // InitGpio(); // Skipped for this example // Step 3. Clear all interrupts and initialize PIE vector table: // Disable CPU interrupts DINT; // Initialize the PIE control registers to their default state. // The default state is all PIE interrupts disabled and flags // are cleared. // This function is found in the DSP2833x_PieCtrl.c file. InitPieCtrl(); // Disable CPU interrupts and clear all CPU interrupt flags: IER = 0x0000; IFR = 0x0000; // Initialize the PIE vector table with pointers to the shell Interrupt // Service Routines (ISR). // This will populate the entire table, even if the interrupt // is not used in this example. This is useful for debug purposes. // The shell ISR routines are found in DSP2833x_DefaultIsr.c. // This function is found in DSP2833x_PieVect.c. InitPieVectTable(); // Step 4. Initialize all the Device Peripherals: // This function is found in DSP2833x_InitPeripherals.c // InitPeripherals(); // Not required for this example InitAdc(); // For this example, init the ADC // Specific ADC setup for this example: AdcRegs.ADCTRL1.bit.ACQ_PS = ADC_SHCLK; AdcRegs.ADCTRL3.bit.ADCCLKPS = ADC_CKPS; AdcRegs.ADCTRL1.bit.SEQ_CASC = 1; // 1 Cascaded mode AdcRegs.ADCCHSELSEQ1.bit.CONV00 = 0x0; //选择A2 AdcRegs.ADCTRL1.bit.CONT_RUN = 1; // Setup continuous run // Step 5. User specific code, enable interrupts: // Clear SampleTable for (i=0; i // Start SEQ1 AdcRegs.ADCTRL2.all = 0x2000; // Take ADC data and log the in SampleTable array for(;;) { for (i=0; i //=========================================================================== // No more. //=========================================================================== 感觉程序问题不大,纠结了一个多星期不知道问题出在哪儿,求帮助~~~~~~~~~~~~~要毕不了业了!!!!QQ 342811994 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式操作教程_数字信号处理_音频编解码:3-6 AAC音频解码实验
423 浏览 0 评论
数字信号处理实验操作教程:3-3 mp3音频编码实验(AD7606采集)
1327 浏览 0 评论
嵌入式DSP教学实验箱操作教程:2-20 数模转换实验(模拟SPI总线输出电压值)
1345 浏览 0 评论
目前在2837x系列用的最多的、性能最好、性价比最高的是哪一款?
1113 浏览 0 评论
国产嵌入式DSP教学实验箱_操作教程:22-AD采集DA输出实验(采集输出正弦波)
2304 浏览 0 评论
GMT+8, 2024-4-24 03:17 , Processed in 0.381833 second(s), Total 73, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
